POV-Ray : Newsgroups : povray.binaries.images : Re: bug: crackle metric 1 (9kbbu) Server Time
22 Sep 2025 19:00:52 EDT (-0400)
  Re: bug: crackle metric 1 (9kbbu) (Message 1 to 1 of 1)
Subject: Re: bug: crackle metric 1 (9kbbu)
Date: 18 Sep 2000 11:22:53
Message: <slrn8scdiv.3s4.ron.parker@fwi.com>
>Anton Sherwood wrote:
>> crackle solid metric 0.9, 1.0, 1.1
>	Shouldn't metric be always an integer? metric 1 looks like what I would
>expect anyway...
There is no reason why metric must be an integer, though using values other
than 1 or 2 can slow down the rendering.  Metric 1 looks like it's broken,
and in fact it is:
    VSub(dv, TPat->Vals.Crackle.cv[i], tv);
        if ( UseSquare ) {
            sum  = VSumSqr(dv);
                if ( Offset ) sum += Offset*Offset;
    else if ( UseUnity ) {
            sum = dv[X] + dv[Y] + dv[Z];
            if ( Offset ) sum += Offset;
    else {
            sum = pow( fabs( dv[X] ), Metric ) +
                      pow( fabs( dv[Y] ), Metric ) +
                          pow( fabs( dv[Z] ), Metric );
            if ( Offset ) sum += pow( Offset, Metric );
Note that in the metric=1 case (UseUnity) it doesn't take the absolute
values of the components of dv, whereas in the default case it does.  The
default case is the correct one.  This same fix must be made in the case
of the three minimum distance calculations before the loop.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 18 Sep 2000 11:49:00
Message: <39C63AC8.B537847B@enst.fr>
	Point. I only looked at the image and didn't see anything amiss in the
metrics 1 case (I'm completely unable to say what the others should look
like anyway...)
Date: 30 Sep 2000 14:26:44
Message: <39D63201.19836DFA@pobox.com>
Ron Parker wrote:
	[code]
okay, what file is this in?
Anton Sherwood  --  br0### [at] p0b0xcom  --  http://ogre.nu/
Date: 30 Sep 2000 14:29:33
Message: <39D632AB.B76DB5F1@pobox.com>
> should look like anyway...)
The point of the image was that cases 0.9 and 1.1 strongly resemble each
other while 1.0 looks nothing like them.
Date: 1 Oct 2000 20:42:45
Message: <slrn8tfnek.fnl.ron.parker@fwi.com>
On Sat, 30 Sep 2000 11:33:37 -0700, Anton Sherwood wrote:
>Ron Parker wrote:
>	[code]
pattern.c
Proudly not helping RIAA and SDMI steal my rights --
  http://www.eff.org/Misc/EFF/Newsletters/EFFector/HTML/effect13.08.html
Date: 2 Oct 2000 10:46:07
Message: <39D89FAE.C2C1C7B@enst.fr>
	Yes, but the case 1.0 looks exactly like I'd expect so if there is a
problem, it's likely in the others (but I don't think so, changing
metrics is not a continuous operation...)
