POV-Ray : Newsgroups : povray.binaries.images : Atm0sphere vs. Media Method 3 Server Time
16 Jan 2026 12:17:41 EST (-0500)
  Atm0sphere vs. Media Method 3 (Message 1 to 7 of 7)
Subject: Atm0sphere vs. Media Method 3
Date: 2 Apr 2000 16:17:50
Message: <38E7AB01.A55E546E@pacbell.net>
With the official release of POV-Ray v3.0 was an example scene file
from Dan Farmer illustrating the new atmosphere feature. The scene
file is called "Matches". When the POV-Team dropped the atmosphere
feature in favor of the media feature in POV-Ray v3.1 they had to
discontinue distributing that file because it was not compatible.
With the addition of the method 3 media in MegaPov I thought I would
see if I could revive that long lost file and below you will find the
results of my efforts. While there are some very minor differences I
am for the most part satisfied with results. The surprising part was
how little time it took me to modify the scene to work with media. I
would say my development time was not much more than about 45 min. and
most of that was time spent in the render -> evaluate cycles.
Render time 3 hrs. 640x480 aa 0.3 on a 200 Mhz pentium
I don't have the render stats for the atmoshphere version but it was
at least as long if not longer.
MatchesA.jpg = with Atmosphere
MathcesM.jpg = with Media Method 3
Download 'matchesa.jpg' (41 KB) Download 'matchesm.jpg' (36 KB)
Preview of image 'matchesa.jpg'
Preview of image 'matchesm.jpg'
Subject: Re: Atm0sphere vs. Media Method 3
Date: 2 Apr 2000 16:47:55
Message: <38E7B15F.255BB05E@netvision.net.il>
Interesting.
Can you explain the difference in the "shadow" caused by the left-most match,
in each system? In the Atmosphere, it looks as is light travels in curves, and
in the media it makes the thing look a bit fake.
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
>  [Image]  [Image]
Date: 2 Apr 2000 16:48:03
Message: <38E7B239.7FE77A50@christianmayer.de>
Hm, the picture with the media has a shadow in the flame... If that
could be made go away it'd look the same for me.
CU,
Christian
Date: 2 Apr 2000 18:11:13
Message: <38E7C53C.FDBDAF92@faricy.net>
I like the atmosphere one better, but it may just be a matter of tweaking.
___     _______________________________________________
 | \     |_          <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine        http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
Date: 3 Apr 2000 04:31:53
Message: <38e856f9@news.povray.org>
Lighting is dimmed or something in the media version, those missing sections in
the flame don't look right.  It is a smooth flame though compared.  I see that
there were 17 lights used in that for the flame, I had thought that was using
'halo'.  I know everyone keeps saying you don't need to specify more than
'intervals 1' but I've seen it can help anyhow if it's increased.
"Ken" <tyl### [at] pacbellnet> wrote in message
news:38E7AB01.A55E546E@pacbell.net...
| http://home.pacbell.net/tylereng/index.html http://www.povray.org/links/
Subject: Re: Atmo. vs. Media [my try at it: ~22KB]
Date: 3 Apr 2000 07:03:12
Message: <38e87a70@news.povray.org>
I gave this a try too.  At first I couldn't get any of the media to show up but
when it did it looked okay.  So from there I figured what it needed for the
flames lighting to show up better on the neighboring matches was to use
radiosity.
You might want to do a correct aspect ratio render Ken.  It makes a big
difference as you will see here, I made this 270 width by 300 height for the 9
by 10 ratio suggested in the scene file.  The media was:
  media {
    method 3
    intervals 3
    samples 3,3
absorption <.15,.1,.05>*.025
    scattering {1,rgb 0.234 extinction 0.0133}
Under 16 minutes to render with +QR +a0.25 +r2 +am2 on a PIII 500MHz
Download 'match_mp.jpg' (16 KB)
Preview of image 'match_mp.jpg'
Date: 3 Apr 2000 12:08:02
Message: <slrn8egvtv.aoj.sjlen@zero-pps.localdomain>
Nice work Ken.  Hope you're gonna share the media code.
 11:14am  up 2 days, 19:50,  4 users,  load average: 1.15, 1.12, 1.04
