POV-Ray : Newsgroups : povray.binaries.images : LOTW UPDATES Server Time
25 Feb 2026 10:47:57 EST (-0500)
  LOTW UPDATES (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: LOTW UPDATES
Date: 26 Jun 2004 13:52:04
Message: <cldrd0hipkh6aedh99mljv2l5jstk055e5@4ax.com>
On Sat, 26 Jun 2004 20:03:16 +1000, "Nathan O'Brien"
<pov### [at] no13net> wrote:
>Hi all
>more images using the second texture pack for the LOTW. I've also made
>some changes to the source code to make it easier to use, as well as
>adding some light groups. The trees are from Gilles Tran's makecloud code.
>Full source code posted to PBSF.
>Nathan O'Brien
Brilliant stuff.
I was wondering if there was a way to somehow obtain a scene file
containing the actual code that a given seed generates which could be
tweaked or added to ?
Rob
Date: 26 Jun 2004 17:39:56
Message: <opr9704rweqe14i4@user-uzkaejdv52>
On Sat, 26 Jun 2004 18:51:49 +0100, Rob Richards <ari### [at] btinternetcom>
wrote:
Hi Rob,
after the scene file has parsed it writes to the message screen the
various seed numbers used for the different components of the landscape,
Landform, sun position etc. You can tweak a landscape by individually
defining a seed for each of these, thus being able to change the sky etc.
On the next issue I intend to add some scene tweaks as well, so you can
shift the landscape around a little without anything else being redefined.
+ a set of macros that will let you easily insert objects from outside the
LOTW core code.
> Cheers
> Rob
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Date: 26 Jun 2004 17:40:54
Message: <opr97053drqe14i4@user-uzkaejdv52>
Just another one I ran befor going to sleep. It took 58 minutes to render.
Download 'lotw-92117477.jpg' (56 KB)
Preview of image 'lotw-92117477.jpg'
Date: 26 Jun 2004 17:42:32
Message: <opr970841mqe14i4@user-uzkaejdv52>
The halo is due to the tress being media contained inside a sphere
interacting with the media atmosphere. I'll probably be using a different
tree code next time round.
On Sat, 26 Jun 2004 17:31:59 +0200, SomeOne <ask### [at] yahoocouknospam>
wrote:
> "Nathan O'Brien" <pov### [at] no13net> schreef in bericht
> news:opr964vqfhqe14i4@user-uzkaejdv52...
> | Hi all
> code.
> I like this very much. One remark: on the second image (lotw-101?) the
> trees on
> the mountainridges show some kind of spherical halo. This is especially
> visible
> for the trees on the mountain top in the far left. Surely this was not
> your
> intention?
Date: 26 Jun 2004 18:12:21
Message: <40ddf4c5$1@news.povray.org>
Showed it to my wife, and she said "Where's that? We should go there on
vacation!"
Date: 27 Jun 2004 04:09:16
Message: <40de80ac$1@news.povray.org>
i thought very californian, but then again i'm english
stephen
Date: 27 Jun 2004 07:34:53
Message: <j9btd0h27juksikngqrhslvpfsd9egfq1j@4ax.com>
On Sun, 27 Jun 2004 07:39:53 +1000, "Nathan O'Brien"
>wrote:
>Hi Rob,
>LOTW core code.
Sounds great. this whole concept is fantastic.
I guess my question was a bit out of place. I was thinking that IMHO
it would be good to be able to see the actual final raw Povray code
that is rendered i.e. generated by the LOTW code or any other macro
generated scene  itself. I think this would be useful from a learning
point of view. For example to see and learn from the raw Povray code
generated , how a particular element of the scene is defined.
Does this make sense ? I guess it's really a question for another
group !
Rob
Date: 27 Jun 2004 14:16:48
Message: <40df0f10$1@news.povray.org>
> Hi all
> Nathan O'Brien
I really like the 1st one especially the sunset light on mounts tops.
I'm a little less fond of displaying media trees containers but it was
already discussed sooner in this thread :)
Marc
Date: 27 Jun 2004 14:19:58
Message: <40df0fce$1@news.povray.org>
opr97053drqe14i4@user-uzkaejdv52...
 You should go to sleep more often ;-)
 this one is really incredibly beautifull
Interacting clouds shadows and ground and rolling hills fading in haze are
great
Marc
Date: 27 Jun 2004 17:36:31
Message: <40df3ddf$1@news.povray.org>
> Hi all
> code.  Full source code posted to PBSF.
   This is evolving really good. I like the boulders, specially the
scattering on the previous update... I must add this feature to my LOTW.
   For the trees I'm using cheap isosurfaces with double_illuminate,
wich works decently, but it's not really good for the near terrain.
Yours are perhaps suffering from fog interaction with media containers?
   I'm downloading your last zip, to see what more ideas I can borrow. :)
Jaime
