POV-Ray : Newsgroups : povray.binaries.images : Shay's CSG challenge: the CGSphere Server Time
21 Aug 2025 19:17:49 EDT (-0400)
  Shay's CSG challenge: the CGSphere (Message 1 to 5 of 5)
Subject: Shay's CSG challenge: the CGSphere
Date: 10 Oct 2013 08:51:32
Message: <op.w4qoqbyl6b35ac@linux-dc58.site>
Anti-aliasing, area light + blurred reflection + depth of field + photons
+ radiosity + lots of 4th order polynomials (tori) make for long render
times.
To reduce the slowdown by the object itself, I clipped (intersected) some
of the tori using boxes instead of planes.  The revised code was posted in
p.b.s-f on September 23.  I also experimented with slicing up the base of
the object, but that led to equivocal results, so that is not included in
the revised code.
I did the photon mapping and radiosity in separate preliminary passes,
then added the anti-aliasing, area light, blurred reflection and DOF for
the final pass.  Alas, after 33 hours, I looked at how much had been
rendered, and estimated that it would take about 3 weeks to complete.
(Later testing revealed that the bottom of the "sphere" renders more
slowly than the top, so 3 weeks was likely an underestimate!)  A drastic
change of plan was in order.
After testing various options, I decided on 19 3rd pass renders each
without DOF or micronormal averaging, but instead jittering the camera and
the micronormal for each run.  The 19 frames were then averaged.
Here's a lesson learned:  When averaging several frames in which an object
has strong metallic highlights, it is best to use one of the HDR formats
for the frames.  With traditional formats, hyper-white highlights get
clipped before averaging (analogous to POV 3.5 anti-aliasing), resulting
in an anemic final highlight.
sams_shay.20131009.jpg is my submission to CGSphere.  The render time was
21h 19m 18s over 19 frames, plus 25 seconds to combine them.
sams_shay.single.jpg is one of my test runs, with DOF but no micronormal
averaging.  Surprisingly, there isn't much difference in appearance.  The
render time was 20h 25m 15s.
In addition to the above render times, the photons pass took 1h 24m 21s
and the radiosity pass took 2h 7m 26s.  All renders were done on 8 cores
with nice -n 19.
There is something that puzzles me, which perhaps CLipka could clear up.
For DOF I used an aperture which translates to 7 mm.  For the 19 frames I
initially jittered the camera within a 3.5 mm radius, but that ended up
way blurrier than the DOF run!  I eventually cut the jitter radius by half
(and also moved the focal point closer to the surface of the "sphere").
Why does DOF give different results than manually jittering the camera
within the same aperture?
Credits:
- CGSphere environment by Trevor G. Quayle.
- Blurred reflection by RC3Metal.
- Sky (apart from the clouds) by Scott Boham, although it doesn't show
   well with the blurred reflection.
- Inspiration, of course, by Samuel T. Benge and Shay.
<Insert witty .sig here>
Download 'sams_shay.20131009.jpg' (151 KB) Download 'sams_shay.single.jpg' (160 KB)
Preview of image 'sams_shay.20131009.jpg'
Preview of image 'sams_shay.single.jpg'
Subject: Re: Shay's CSG challenge: the CGSphere
Date: 10 Oct 2013 15:48:40
Message: <52570498$1@news.povray.org>
Sleek! Looks like something a princess might drop into a well ;)
Date: 14 Oct 2013 04:38:33
Message: <525bad89@news.povray.org>
Now seems a sort of flower...very nice!
Paolo
Date: 10 Nov 2013 16:02:40
Message: <527ff470$1@news.povray.org>
Am 10.10.2013 14:52, schrieb Cousin Ricky:
> up.  For DOF I used an aperture which translates to 7 mm.  For the 19
> frames I initially jittered the camera within a 3.5 mm radius, but that
> ended up way blurrier than the DOF run!  I eventually cut the jitter
> radius by half (and also moved the focal point closer to the surface of
> the "sphere").  Why does DOF give different results than manually
> jittering the camera within the same aperture?
That's because...
... um...
... damn, I haven't the slightest clue.
Date: 10 Nov 2013 17:46:14
Message: <52800cb6$1@news.povray.org>
Am 10.11.2013 22:02, schrieb clipka:
> That's because...
> .... um...
> .... damn, I haven't the slightest clue.
There does indeed seem to be a factor of 0.5 buried /somewhere/ in the
code that I never noticed.
Thus, I have been wrong all the time: The aperture value doesn't give
the diameter of the camera lens. Instead, it is an entirely artificial
value that /happens/ to be /twice/ the diameter of the lens.
(That still doesn't mean that jittering the camera position to simulate
focal blur will get you exactly the same results; one effect that is to
be considered especially when using strong focal blur is that jittering
the camera also tilts the image plane, while the jittering used in the
focal blur code leaves the image plane unchanged. But that shouldn't be
relevant for the amount of focal blur you used.)
