POV-Ray : Newsgroups : povray.binaries.images : Alley Sunflower Final Server Time
19 Feb 2026 11:40:12 EST (-0500)
  Alley Sunflower Final (Message 15 to 24 of 24)
Subject: Re: Alley Sunflower Final
Date: 17 Jun 2010 06:58:16
Message: <op.vefx230aufxv4h@go-dynamite>
On Wed, 16 Jun 2010 21:01:08 +0200, Samuel Benge <stb### [at] hotmailcom>
wrote:
> "Nekar Xenos" <nek### [at] gmailcom> wrote:
>> Comments welcome.
> It looks good! Too bad about the aa problems, though.
Do you think luminous bloom will help here? I've never used it before.
-Nekar Xenos-
Date: 20 Jun 2010 17:57:35
Message: <4c1e8ecf@news.povray.org>
You mean to reduce aliasing or help the scene in general? You can use
luminous bloom with a small radius to hide the aliasing where bright
colors cause trouble, but it might blow out the rest of the colors too
much. A low lb_exponent would be advised here. If you use it lightly
just to spread the light a bit, it couldn't hurt. When used carefully,
it could enhance the realism imperceptibly.
Date: 21 Jun 2010 02:19:55
Message: <op.vemzvctuufxv4h@go-dynamite>
On Sun, 20 Jun 2010 23:57:36 +0200, stbenge <myu### [at] hotmailcom>
Yes, both. Thanks for the info on lb_exponent.
I tried putting an hdr render of this scene through the luminous bloom
code and I got rather strange artifacts. The bricks had a red "wash"
overlaid with horizontal white stripes. A normal png didn't get those
artifacts at all.
-Nekar Xenos-
Date: 21 Jun 2010 11:40:58
Message: <4c1f880a$1@news.povray.org>
> artifacts at all.
Hmm, could you post an example portion of the result? Or an .hdr version
of your image so I can try it?
How intense are the brightest areas of light in the original image? I
personally wouldn't use values much higher than rgb <2,2,2> for
light_sources, fog and such. I know that really small (<.1) lb_exponent
values will increase the chance of an image developing artifacts. This
is made worse by values which are too bright. If this the case with your
scene, you probably don't want to re-render the whole thing simply to
make some glare. A color-normalizing file shouldn't be too difficult to
put together; perhaps I should consider making one. Hopefully it works.
Date: 22 Jun 2010 01:38:24
Message: <op.veosl4ntufxv4h@xena>
On Mon, 21 Jun 2010 17:40:58 +0200, stbenge <myu### [at] hotmailcom>
>> artifacts at all.
I've used extremely high rgb (400+) values for my light source - so I
guess that's the problem.
The first try was on the default settings and many other settings with the
same results.
I'm quite happy with the current result without hdr.
There is one other problem: I've noticed the edge pixels don't fit in with
the rest of the scene - but you don't notice it if the image is on a light
background.
-Nekar Xenos-
"The spoon is not real"
Date: 22 Jun 2010 10:14:23
Message: <op.vepgh7hmufxv4h@go-dynamite>
>> artifacts at all.
I posted an hdr image on povray.binaries.misc for you to test on.
-Nekar Xenos-
Date: 22 Jun 2010 13:15:08
Message: <4c20ef9c$1@news.povray.org>
> the same results.
Wow, that's a bright light_source.
Cool :)
> with the rest of the scene - but you don't notice it if the image is on
> a light background.
I think this might be an internal problem with POV-Ray itself. It's a
bad line of pixels around the edge and arises when warp{repeat n flip n}
is used on an image_map. Heck, it's probably an image_map problem, and I
wouldn't be surprised if it was somehow related to the interpolation
shifting problems clipka was exploring.
OK, I'll grab it.
Date: 22 Jun 2010 16:26:07
Message: <4c211c5f@news.povray.org>
stbenge wrote:
> OK, I'll grab it.
The preliminary results don't look very promising. I tried remapping the
color values to create a new range of intensity. When the colors are
remapped 0 - 1, the result in luminous bloom is exactly the same as if a
.png or .tga image had been used. When remapped 0 - 2 or greater, the
shadows become too light, changing the light level for the entire image.
I think your best bet, if you plan to use luminous bloom, would be to
render your scenes with reasonably low light_source intensities, or just
use pngs or tgas.
Now, about that bad line of pixels around the edge. It's definitely a
problem with POV-Ray. It exists whether the "once" keyword was used or
not, and always when repeat/flip warps are used. To alter my code to fix
the problem is not really a good solution, as there is a possibility
that the render times will rise significantly. I'll try posting a bug
report, and hopefully it will be fixed soon. For now, maybe you can just
remove the outer layer of pixels?
Date: 22 Jun 2010 16:59:32
Message: <4c212434$1@news.povray.org>
New update. I tried adding "once" to the image_map, and now the problem
/appears/ to be gone. I could swear I had tried this before without
success. It only happens when an image is interpolated and given a
repeat/flip warp so it's definitely an interpolation issue, but probably
not a real bug.
I'll do some more testing, and when I am satisfied with the result, an
updated version of luminous bloom will be issued.
Date: 23 Jun 2010 05:05:02
Message: <op.veqwuhwoufxv4h@go-dynamite>
On Tue, 22 Jun 2010 22:26:08 +0200, stbenge <myu### [at] hotmailcom>
wrote:
> stbenge wrote:
>>  OK, I'll grab it.
> use pngs or tgas.
I'll stick to png. I onlys used hdr because you docs said it would be
better :)
Thanks,
-Nekar Xenos-
