POV-Ray : Newsgroups : povray.binaries.images : Stars of the night sky Server Time
16 Mar 2026 04:13:10 EDT (-0400)
  Stars of the night sky (Message 1 to 10 of 20)
Subject: Stars of the night sky
Date: 27 Nov 2011 15:45:57
Message: <op.v5mhajnt6b35ac@rickycallwood.vipowernet.net>
Data are from the _Bright Star Catalogue_, 4th Edition, using the J2000
coordinates.
An extinction of magnitude 6.5 is subtracted from the stars.  I used an
extinction for aesthetic reasons because plotting the stars at their full
brightness showed a discordantly abrupt cutoff at the magnitude limits of
the survey.  I chose magnitude 6.5 because a histogram of the data reveals
a drop-off in the number of stars after approximately that magnitude.
Clearly, the survey of the dimmer magnitudes is incomplete, and I chose to
eliminate those stars rather than give the impression that those were all
the stars of their magnitudes.  In addition, I omitted 14 novae and
non-stellar objects.  The resulting images show 8352 of the 9110 objects
in the catalog.
I desaturated the colors of the dimmer stars, reflecting (in a
non-rigorous manner) the insensitivity of our cones to dim light.
The star delta Scorpii has brightened dramatically since the BSC4 was
published.  I fudged the datum accordingly.
Interestingly enough, proper motion makes a difference, even at this low
resolution!  At first, I mistakenly calculated 1 year of proper motion
instead of the 11.9 years that have elapsed since J2000.  The corrected
JPEG of the southern polar region differed from the old by 21 bytes--not
enough to see, but still calculable.
<Insert witty .sig here>
Download 'bsc42.jpg' (43 KB) Download 'bsc41.jpg' (225 KB) Download 'bsc43.jpg' (47 KB)
Preview of image 'bsc42.jpg'
Preview of image 'bsc41.jpg'
Preview of image 'bsc43.jpg'
Subject: Re: Stars of the night sky
Date: 27 Nov 2011 16:18:59
Message: <4ed2a943@news.povray.org>
> coordinates.
WOW!  Very impressive, I might have to include these in a wallpaper
rotation. :)
Jim
Date: 27 Nov 2011 19:02:26
Message: <4ed2cf92@news.povray.org>
The stars look great, is the glow due to media?
A bit confusing though as I'm more used to a cutoff at
magnitude 4.5 to 5 in the city ;) Higher resolution would
be nice so the pleiades don't clump together so much.
Also I'm not quite sure what you mean by subtracting an
extinction of 6.5, unless magnitude 13 happens to be the
range where your magnitude to rgb mapping turns black.
The colors of the bright stars are probably still more intense
than what you can see with the naked eye, but its visually more
appealing this way.
> The corrected JPEG of the southern polar region differed from
> the old by 21 bytes -- not enough to see, but still calculable.
Try comparing the lossless png versions by blinking the two images,
even tiny differences should catch your eye then.
Date: 27 Nov 2011 20:15:01
Message: <web.4ed2e079a6a67a4085de7b680@news.povray.org>
Yes.
I converted magnitude to a linear brightness, then subtracted the linear
equivalent of magnitude 6.5.
Actually, it just occurred to me that anti-alias jitter could account for the
difference.  It would be a bear to find out, because for some reason my -J flag
isn't working.  (I *could* do it by rendering with -A +W3360 +H3360 and waiting
all night, or by rewriting all my #fors and reverting to 3.6.)
Date: 27 Nov 2011 21:55:00
Message: <web.4ed2f754a6a67a4085de7b680@news.povray.org>
I can get away from the city to about magnitude 6.0 before I run out of land.
(I live on a small island.)
Taurus attached, with a bit of Orion to the lower left.  Of course, the limited
data set and limited dynamic range don't do justice to the Pleiades.  If you've
never seen an open star cluster through a telescope, they are razor-sharp,
glittery pinpricks of light.  I describe them as diamond dust on velvet.
I would like to get more extensive data from other sources, but I haven't
figured out the best options yet.  I tried Hipparcos a few years ago, but I
noticed some prominent stars missing from M7 and M42.  I've since forgotten
where star chart software programs get their data.
Download 'taurus.jpg' (31 KB)
Preview of image 'taurus.jpg'
Date: 27 Nov 2011 22:09:52
Message: <4ed2fb80$1@news.povray.org>
Hi(gh)!
> coordinates.
Awesome! Where I compare this to my puny 900 stars collection from the
"Karkoschka" sky atlas I did some years ago... but I still plan to use
the Hipparcos catalogue in a more advanced version!
A question: did you define the stars as object pattern on a sky_sphere?
If so, I wonder how you got the glows working...
See you in Khyberspace!
Yadgar
Date: 28 Nov 2011 16:20:01
Message: <web.4ed3f9e3a6a67a4085de7b680@news.povray.org>
The stars are emissive media containers.  Slow, but I can't think of another way
in POV-Ray to get additive color from overlapping stars.
The background is just the default.  I used the orthographic camera and did the
projection math myself.
Date: 28 Nov 2011 17:18:40
Message: <4ed408c0@news.povray.org>
sweet
Try NOMAD
http://www.usno.navy.mil/USNO/astrometry/optical-IR-prod/nomad
Date: 22 Dec 2011 04:00:16
Message: <4ef2f1a0$1@news.povray.org>
> land. (I live on a small island.)
> limited
> you've never seen an open star cluster through a telescope, they are
> razor-sharp,
> I
> forgotten where star chart software programs get their data.
You could have a look at ftp://cdsarc.u-strasbg.fr/pub/cats/I/317/
That is 38GB to download (148GB unpacked)
I would like to create a Hires full-sphere star sky out of that data (usable
in a HD animation) but don't have a real idea on how to do that.
Ger
Date: 24 Dec 2011 18:31:02
Message: <4ef660b6$1@news.povray.org>
> coordinates.
> in the catalog.
I'm wondering how you calculated the color/brightness/size of the stars.
Ger
