POV-Ray : Newsgroups : povray.binaries.images : IRTC Space entry continued Server Time
22 Apr 2026 21:36:12 EDT (-0400)
  IRTC Space entry continued (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: IRTC Space entry continued
Date: 28 Jan 2010 15:47:50
Message: <4b61f7f6$1@news.povray.org>
> I've tried different wave types and I still have the same problem,
> everywhere were there is transparency on the rings with the planet
> showing through, the cloud media is gone, as if the max-trace level is
> too low. I have max_trace_level 256.
A disk is not just a surface. It is in fact the intersection of a plane
and an infinite cylinder, showing only the cap. Anything under or behind
it is considered inside. Media can't exist inside an object like a plane.
Add hollow to your disk and the media problem should go away.
Date: 29 Jan 2010 03:38:35
Message: <op.u7acx7j3ufxv4h@go-dynamite>
s
e
nd
ne.
It is hollow with double_illuminate as well. This is done in beta 35b.
Maybe I should check if there's a difference when rendered with Ver 3.6
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Date: 30 Jan 2010 18:35:01
Message: <web.4b64c14ad97a3e2883581d060@news.povray.org>
You allow a criticism, I hope constructively.
Technically the picture is outstanding, this done entirely with POV? As an IRTC
I suppose, a great job.
However, the criticism is in design: the image is too heavy, has too many
things.
The images of deep space have to give the impression that we are looking at
infinity, we look to the void, this picture gives the contrary impression, we
are in the midst of a crowded city. At least in my view should not be.
I could remove the second planet ring (red), he excess, and the ship in the
left, the image stays the same technique and outstanding, but less saturated
with things.
Another possible solution would be to use an image size larger to get the same
items, with this you get a spacious feeling without losing the things that you
created, or reduce slightly the size of the elements.
As for realism, is not possible, by the gravitational forces involved, have a
multiple system of planets like the ring samples, the rings are formed by
gravitational stability (they are like dust settled) in a system with several
massive bodies, these rings would end shredded sooner or later.
I hope these words do not detract your great work, a greeting.
Date: 31 Jan 2010 09:51:37
Message: <4b6598f9@news.povray.org>
The clouds on the earth-like planet look nice. The rings feel
out of place on terrestial-mass planets, and they most certainly
can't be stable in such a close binary system. Also, the four
astronomical bodies seem a bit artificially lined up, as do
the perfectly parallel tilts of the two planets.
BTW the rings look like they're perfectly edge-on to the
sun (spring/autumn equinox) and probably wouldn't cast any
shadow at all (the average thickness of Saturns rings is
only on the order of tens of meters on average).
Date: 31 Jan 2010 12:19:57
Message: <op.u7eqfeupufxv4h@xena>
s
e
nd
ne.
> Alain
I've finally fixed it by adding hollow to the isosurface surface of the
vulcanic planet. I'm not sure why it works, but it does. I think it migh
t
be a bug because the problem does not appear when using ver 3.62, only o
n
3.7 beta.
Another thing: Should I put the materializing enemy craft in again or do
es
it look better without it?
-Nekar Xenos-
"The spoon is not real"
Date: 31 Jan 2010 12:32:36
Message: <op.u7eq0h10ufxv4h@xena>
On Sun, 31 Jan 2010 01:31:22 +0200, Agustin Britait Molina
> an IRTC
> things.
> at
> impression, we
> the
> saturated
> with things.
> the same
> that you
> have a
> several
Thank you for your input, I was looking for critique :)
Maybe I should move the camera more backwards, to give the impression of
infinity. I will play around with the scale of the planets and rings some
more.
-Nekar Xenos-
Date: 31 Jan 2010 12:49:18
Message: <op.u7ersch4ufxv4h@xena>
On Sun, 31 Jan 2010 16:53:47 +0200, Christian Froeschlin <chr### [at] chrfrde>
I think I'll remove the second moon and play around with the scale of the
planets. Hmm, I like planet rings, but the realistic option would be more
like Avatar's Pandora and I wouldn't want to copy... ;)
Maybe I should take the planets even further apart, and add thicker
atmospheres to both planets, so that it becomes a mixture of terrestrial
and gas planet? Do you think there is a viable way to make a figure 8
ringed binary system work or at least seem more realistic? Hmm... I
remember Grey Knight worked it all out long ago on this group and came to
the conclusion that there would be a "ring-storm" every 13-years if the
planets were the size of earth and they were as far apart from each other
as the moon is from the earth...
BTW the rings are discs, so in this case they _are_ infinitely thin. The
sun is at a slight angle which is why you can see the shadow.
-Nekar Xenos-
Date: 31 Jan 2010 16:32:57
Message: <4b65f709$1@news.povray.org>
Normaly, when you have binary systems like that, you expect the two to
have parallel axis. After all, they where formed at the same time, from
probably be tidaly locked as such a close proximity.
There is no known lower limit to the radius of a planet that would
prevent it from having a ring system. They feel out of place because our
planet don't have any perseptible ring, but we do have an extremely thin
one composed of fine, very diffuse, silt like, dust. It's TOTAL mass is
estimated to be no more that 10 tons spread in a ring over 2000km whide
in an area above that of the geostationary satellites (about 30 to 48
hours orbital period).
Looking at the rings, they are not perfectly edge on to the sun, just a
few day before or after the equinox. Otherwise, the rings would be much
darker as they would self shadow.
Date: 31 Jan 2010 17:59:06
Message: <4b660b3a$1@news.povray.org>
True, but the alignment wouldn't be exact as they get pummeled by
collisions in the early stages and there are also other effects such
as precession.
> They would very probably be tidaly locked as such a close proximity.
Yes. Interesting point, I never thought about whether tidal locking
changes the axis of rotation in addition to just slowing it down.
You're right.
Date: 1 Feb 2010 21:27:26
Message: <4b678d8e$1@news.povray.org>
> as precession.
Statisticaly, the colisions on both planets would be the same, the shift
would be less than a few second arc, maybe less than 1 second. That's
not perceptible as it's only shift the axis by something like 1 to 4 km
at most.
As for precession, it only causes a wobble, and will affect both planets
equaly.
Tidal lock makes the axis parallel.
>> a few day before or after the equinox.
> You're right.
