Attached image was achived with iso_csg library. This time isosurface use
function with following syntax:
#local f_V=IC_Intersection2 (
IC_Threshold( IC_Char("V") , .4 ) ,
IC_Scale( IC_Threshold( function{pattern{brick}} , .5 ) , .1 )
Threshold around character was used to move surface of letter outside of
shape. Rounded version of iso_csg was used so edges after threshold are
rounded. Threshold around pattern was used to show value of pattern used as
surface. Simple yellow pigment used. Calculated max_gradient was 3999.456 but
884 used.
Any comments ?
ABX
Download 'V.jpg' (173 KB)
Preview of image 'V.jpg'
Very interesting, thank you for sharing.
You should submit all of these examples to the POV team as part of the
documentation.
> as surface. Simple yellow pigment used. Calculated max_gradient was
> 3999.456 but 884 used.
> Any comments ?
> ABX
