POV-Ray : Newsgroups : povray.binaries.images : megapov 1.0 has a bug... - attached files (1/1) Server Time
18 Oct 2024 06:11:49 EDT (-0400)
  megapov 1.0 has a bug... - attached files (1/1) (Message 1 to 9 of 9)
Subject: megapov 1.0 has a bug... - attached files (1/1)
Date: 16 May 2004 12:49:36
Message: <kurtzlepirate-682111.18492816052004@news.povray.org>
In article <c87c4g$2bp$1@chho.imagico.de>,
 Christoph Hormann <chr### [at] gmxde> wrote:
> I can't find any argument in your post that indicates a bug in MegaPOV.
>   The criteria for a good bug report are quite the same as with official
> POV-Ray BTW: post a minimal test scene clearly showing the problem (this
> scene is neither minimal nor clearly shows a difference nor comes with
> source).
> And also read the posting rules in p.a.f-a-q.  You should not post
> binaries in a non-binary group.
> Christoph
begin in "povray.macintosh", here source code and 2 images showing the problem
with this simple object.
the 2 render where made with the same settings : 640x480, png, aa on with
original method, threshold=0.30, recursion=2 and jitter=0.
Source :
#declare useMegaPov = true;
#if(useMegaPov)
  #version unofficial MegaPov 1.0;
#else
  #version 3.5;
//  --- INCLUDES -------------------------------------------------------------
#include "myMacros.inc"
#declare displayAxis = false;
#declare useOtherLights = false;
#declare bestQuality = true;
#declare useAreaLights = bestQuality;
#declare quickTexture = !bestQuality;
//  --- SCENE ----------------------------------------------------------------
global_settings {
  assumed_gamma 1.80
  max_trace_level 10
  location p2r(20, 30, 300,false)
  look_at <0, 25, 0>
  angle 36
light_source {
  // <400, 320, 400>
  p2r(60, 35, 650,false)
  color White
  #if(useAreaLights)
    area_light 100, 100, 5, 5
    adaptive 1
    jitter
    orient
    circular
#if(useOtherLights)
  #declare index=0;
  #while (index<8)
    light_source {
      <35.00, 20.00, 0.00>
      color White/6
      rotate 45*index*y
    #set index=index+1;
background {
  color White
plane {
  y,0
  pigment { color White }
  finish { ambient 0.70 diffuse 0.30 }
#if (displayAxis)
  drawAxis (140, 0.40)
//  --- DIMENSIONS -----------------------------------------------------------
#declare semelleCote = 60.00;
#declare semelleHauteur = 12.00;
#declare semelleRayon = 17.00;
#declare semelleArrondi = 3.00;
#declare positionCoin = 60.00;
#declare tubeRayonExterieur = 25.00;
#declare tubeRayonInterieur = 21.00;
#declare tubeHauteur = 80.00;
#declare tubeTore = (tubeRayonExterieur-tubeRayonInterieur)*0.50;
#declare goussetLargeur = 24.00;
#declare goussetArrondi = 1.50;
#declare goussetRadius = (goussetLargeur*0.50)-goussetArrondi;
#declare goussetLongueur = semelleCote;
#declare goussetHauteur = semelleCote;
#declare rayonPercage = 3.00;
#declare rayonLamage = 8.00;
#declare profondeurLamage = 2.00;
//  --- CONSTRUCTION ---------------------------------------------------------
#declare coinArrondi =  union {
  cylinder { <0.00, 0.00, 0.00> <0.00, semelleHauteur-semelleArrondi, 0.00>
semelleRayon }
  cylinder { <0.00, 0.00, 0.00> <0.00, semelleHauteur, 0.00>
semelleRayon-semelleArrondi }
  torus { semelleRayon-semelleArrondi semelleArrondi translate
(semelleHauteur-semelleArrondi)*y }
#declare goussetBase = union {
  cylinder { <+(semelleCote-semelleArrondi), 0.00, 0.00>
<+(semelleCote-semelleArrondi), semelleHauteur+goussetArrondi, 0.00>
(goussetLargeur*0.50) }
  box { <0.00, 0.00, -goussetLargeur*0.50> <semelleCote-semelleArrondi,
semelleHauteur+goussetArrondi, +goussetLargeur*0.50> }
  rotate 45*y
#declare gousset = union {
  difference {
    torus { goussetRadius goussetArrondi }
    plane { x, 0 }
  cylinder { <0.00, 0.00, +goussetRadius> <-goussetLongueur, 0.00,
+goussetRadius> goussetArrondi}
  cylinder { <0.00, 0.00, -goussetRadius> <-goussetLongueur, 0.00,
-goussetRadius> goussetArrondi}
  difference {
    cylinder { <0.00, 0.00, 0.00> <0.00, -goussetHauteur, 0.00>
goussetRadius+goussetArrondi }
    cylinder { <0.00,+1.00, 0.00> <0.00, -goussetHauteur-1, 0.00>
goussetRadius-goussetArrondi }
    plane { x, 0 }
  box { <0.00, 0.00, +goussetLargeur*0.50> <-goussetLongueur, -goussetHauteur,
goussetRadius-goussetArrondi> }
  box { <0.00, 0.00, -goussetLargeur*0.50> <-goussetLongueur, -goussetHauteur,
-(goussetRadius-goussetArrondi)> }
  translate <-goussetRadius, 0.00, 0.00>
  rotate -30*z
  translate <+goussetRadius, 0.00, 0.00>
  translate <+(semelleCote-semelleRayon)*sqrt(2), semelleHauteur+goussetArrondi,
0.00>
  rotate 45*y
#declare percages = union {
  cylinder { <0.00, -1.00, 0.00> <0.00, semelleHauteur+goussetArrondi+1.00,
0.00> rayonPercage }
  cylinder { <0.00, semelleHauteur+goussetArrondi-profondeurLamage, 0.00> <0.00,
semelleHauteur+goussetArrondi+1.00, 0.00> rayonLamage }
  translate <(semelleCote-semelleRayon)*sqrt(2), 0.00, 0.00>
  rotate 45*y
#declare support = difference {
  union {
    difference {
      union {
        box { <semelleCote, 0.00, semelleCote-semelleRayon> <-semelleCote,
semelleHauteur-semelleArrondi, -(semelleCote-semelleRayon)> }
        box { <semelleCote-semelleArrondi, 0.00, semelleCote-semelleRayon>
<-(semelleCote-semelleArrondi), semelleHauteur, -(semelleCote-semelleRayon)> }
        box { <semelleCote-semelleRayon, 0.00, semelleCote>
<-(semelleCote-semelleRayon), semelleHauteur-semelleArrondi, -semelleCote> }
        box { <semelleCote-semelleRayon, 0.00, semelleCote-semelleArrondi>
<-(semelleCote-semelleRayon), semelleHauteur, -(semelleCote-semelleArrondi)> }
        object { coinArrondi translate <+(semelleCote-semelleRayon), 0.00,
+(semelleCote-semelleRayon)> }
        object { coinArrondi translate <-(semelleCote-semelleRayon), 0.00,
<+(semelleCote-semelleArrondi), semelleHauteur-semelleArrondi,
+(semelleCote-semelleRayon)> semelleArrondi }
        cylinder { <-(semelleCote-semelleArrondi),
<-(semelleCote-semelleArrondi), semelleHauteur-semelleArrondi,
        cylinder { <+(semelleCote-semelleRayon), semelleHauteur-semelleArrondi,
+(semelleCote-semelleArrondi)> <-(semelleCote-semelleRayon),
semelleHauteur-semelleArrondi, +(semelleCote-semelleArrondi)> semelleArrondi }
-(semelleCote-semelleArrondi)> <-(semelleCote-semelleRayon),
semelleHauteur-semelleArrondi, -(semelleCote-semelleArrondi)> semelleArrondi }
        cylinder { <0.00, 0.00, 0.00> <0.00, tubeHauteur-tubeTore, 0.00>
tubeRayonExterieur }
        torus { tubeRayonExterieur-tubeTore tubeTore translate
(tubeHauteur-tubeTore)*y }
        torus { tubeRayonExterieur semelleArrondi translate semelleHauteur*y }
      torus { tubeRayonExterieur+semelleArrondi semelleArrondi translate
(semelleHauteur+semelleArrondi)*y }
    object { goussetBase }
    object { goussetBase rotate 90*y }
    object { goussetBase rotate 180*y }
    object { goussetBase rotate 270*y }
    object { gousset }
    object { gousset rotate 90*y }
    object { gousset rotate 180*y }
    object { gousset rotate 270*y }
  // --- percages ---------------------------------------------------------------
  cylinder { <0.00, -1.00, 0.00> <0.00, tubeHauteur+1, 0.00> tubeRayonInterieur }
  object { percages }
  object { percages rotate 90*y }
  object { percages rotate 180*y }
  object { percages rotate 270*y }
//  --- OBJECT ---------------------------------------------------------------
object {
  support
  #if (quickTexture)
    pigment { color Red }
    finish { ambient 0.40 diffuse 0.60 phong 0.80 }
  #else
      rgb <0.859998, 0.859998, 0.869993>
    normal {
      granite 0.05
      triangle_wave
      scale 2
    finish {
      ambient 0.40
      diffuse 0.60
      specular 1.0
      roughness 0.0005
      metallic on
Download 'supportMegaPov.jpg' (35 KB) Download 'supportPovRay.jpg' (31 KB)
Preview of image 'supportMegaPov.jpg'
Preview of image 'supportPovRay.jpg'
Subject: Re: megapov 1.0 has a bug... - attached files (1/1) - supportMegaPov.jpg (1/1)
Date: 16 May 2004 13:20:43
Message: <kurtzlepirate-F77989.19204116052004@news.povray.org>
hoops... first image has a problem...
reposte here
Download 'supportMegaPov.jpg' (14 KB)
Date: 16 May 2004 13:57:47
Message: <40a7ab9b@news.povray.org>
"Kurts" <kur### [at] yahoofr> wrote in message
news:kurtzlepirate-F77989.19204116052004@news.povray.org...
> reposte here
Time for a scratch and dent sale :)
Date: 16 May 2004 14:00:15
Message: <40a7ac2f@news.povray.org>
> reposte here
  Nope, no problem. I can see both images and the code that you
posted.
  ~Steve~
Date: 16 May 2004 14:04:38
Message: <40a7ad36@news.povray.org>
Yep, I've experienced the same thing. You can solve it by using the sturmian
root solver. Eventually the problem will be fixed in future releases.
Hugo
Date: 17 May 2004 13:44:58
Message: <kurtzlepirate-9378F4.19445917052004@news.povray.org>
Date: 18 May 2004 04:50:38
Message: <1hjja05f7j5fscp9phkise2clrgd1cfea6@4ax.com>
> your 're right ! using sturmian seems to solve this problem. macmegapov has a
> problem in rendering torus...
There was misconfigured polynomial solver in MegaPOV 1.0 due to implementing
other patch. This is already fixed for the next release thanks to earlier
reports.
ABX
Date: 25 May 2004 20:33:11
Message: <40b3e5c7$1@news.povray.org>
implementing
> reports.
> ABX
When is the next patch coming out?
        == John ==
Date: 26 May 2004 02:05:44
Message: <7sc8b014103qt1t7esajabrf8n49bmhsa4@4ax.com>
On Tue, 25 May 2004 17:45:03 -0700, "John D. Gwinner"
> > reports.
> > ABX
Most probably some time after 3.6.
ABX
