POV-Ray : Newsgroups : povray.binaries.images : uv-mapped 3D isomaze Server Time
3 May 2026 17:29:43 EDT (-0400)
  uv-mapped 3D isomaze (Message 11 to 16 of 16)
Subject: Re: uv-mapped 3D isomaze
Date: 3 Nov 2001 05:34:25
Message: <3oh7ut8v93rfppdodrhv6kufml0ebtp33i@4ax.com>
<abx### [at] babilonorg> wrote:
>something like this ?
Wow! Very Matrix-ish!
Source... if it's not a problem? And what about the render time?
(can you guess I am thinking about changing my wallpaper -- and mine
hasn't even finished rendering yet... Sigh! When am I going to get
*that* good?)
Peter Popov ICQ : 15002700
Date: 3 Nov 2001 13:41:04
Message: <3BE439A1.75B956AA@skynet.be>
> On Fri, 2 Nov 2001 11:23:21 +0200, "Nekar Xenos" <j-p### [at] citywalkcoza> wrote:
> > Maybe a  diamond-shaped function pigment or something like cells rotate 45 deg
> > and squashed. Then add a normal...
Woaw !  Does it takes long to render ?  I mean : an animated flytrough
could look fantastic.
Fabien.
Date: 5 Nov 2001 02:59:43
Message: <tlhcutco4038eu8t9h5st4ka7tc0ml05b7@4ax.com>
On Fri, 2 Nov 2001 17:36:00 -0500, "Slime" <noo### [at] hotmailcom> wrote:
> Can you show us the function you're using? This is really cool.
I try to write little tutorial with images about it.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 5 Nov 2001 03:08:09
Message: <gohcutkfn657r7bquu3864vaklnb6u10tj@4ax.com>
I'll make little turorial.
around two hours with this deformed surface on PII 233 with NT and POV 3.5;
ABX
Date: 5 Nov 2001 05:17:57
Message: <onpcutct31qk1h3gb3038mittepn71ba9m@4ax.com>
On Sat, 03 Nov 2001 19:38:25 +0100, Fabien Mosen <fab### [at] skynetbe> wrote:
I wait for animation with rotation of the camera since friday. 30 minutes per
frame 160x120.
ABX
Date: 5 Nov 2001 09:46:06
Message: <bg9dutomnq2j41cvlfk884plsml5o1tt1t@4ax.com>
On Fri, 2 Nov 2001 19:37:02 -0500, "Halbert" <hal### [at] compudrivelcom> wrote:
> We would love for you to share your maze3d function with the rest of the
> class. :)
tutorial just sended to povray.text.tutorial
ABX
