POV-Ray : Newsgroups : povray.binaries.images : Radiosity test question - radtest.jpg (0/1) Server Time
5 Mar 2026 07:08:59 EST (-0500)
  Radiosity test question - radtest.jpg (0/1) (Message 11 to 13 of 13)
Subject: Re: Radiosity test question - radtest.jpg (0/1)
Date: 9 Sep 2000 02:15:00
Message: <39b9d564@news.povray.org>
You know you have been tracing too long when you mentally tear every image,
object, and thing down to Pov primitives, which is what I did when I saw
your image.
The pipe thingie looks as though it were extruded along an imperfect path. I
could extrude along a spline, but I would probably use a union of primitives
and a torus (or two). Blobs could be used as well.
I model complex objects with a modeller myself, but this scene has a simpler
look to it. No offense intended. The colors and composition make the image
worthwhile!
Grim
Date: 9 Sep 2000 03:18:42
Message: <5nojrs0vvbc22t3cqucsh30nqhi79esrlv@4ax.com>
On Sat, 9 Sep 2000 01:38:09 -0500, "GrimDude" <gri### [at] netzerocom>
>your image.
>worthwhile!
>Grim
No offence taken...the scene was *definitely* not an example of my
modeling skills. I was simply doing a radiosity test, trying to figure
out what setting do worked. The colors were chosen cause they would
bleed nicely from one to another so I could actually see the radiosity
working. The pipes curve was not imperfect, I think that it was that I
didn't use set Rhino to use enough poly's for the export. Either that
or it was a radiosity issue....I guess I could simply spotlight it (no
rad) and re-render and see if it shows up again. Might it be a
(flipped) normal problem? blah blah blah need caffeine. Thanks for the
feedback.
---Oldstench---
Avoid herd mentality.
Date: 9 Sep 2000 03:32:28
Message: <39b9e78c$1@news.povray.org>
Oldstench wrote in message <6p7hrskl39ducrkr3k3fb6t0h9rtbr6nch@4ax.com>...
>BTW I am interested in seeing how you would code that tube thingy.
sphere_sweep{
    b_spline_sphere_sweep
    4,
    <0,0,0>, 1
    <2,0,0>, 1
    <0,0,4>, 1
    <2,0,4>, 1
+ appropriate CSG to make the end caps
Mark
