Subject: Re: Star Trek inspired Starship - anim.png (4/4)
Date: 22 Jul 2003 04:50:16
Message: <3f1cfac8@news.povray.org>
If you're using Outlook Express, you've got to
highlight all four posts (1/4), (2/4), ... and click
on something like "Stitch together and decode",
I've only got the German version which says
"Zusammenfassen und Decodieren".
Other newsreader might handle this by themselves
or have a different routine for "compiling" a mutli-post.
Tim
Tim Nikias v2.0
> Whatcha doin' ?
> DigitalTwilight
> #homepage: http://www.digitaltwilight.de
> #email: kin### [at] gmx net
Version: 6.0.501 / Virus Database: 299 - Release Date: 14.07.2003
Date: 22 Jul 2003 06:48:51
Message: <3f1d1693$1@news.povray.org>
Ahhhhh, cool. I've found it.
thx
DigitalTwilight
Version: 6.0.502 / Virus Database: 300 - Release Date: 18.07.2003
Subject: Re: Star Trek inspired Starship - anim.png (1/4)
Date: 22 Jul 2003 11:37:35
Message: <3f1d5a3f$2@news.povray.org>
Dawn McKnight wrote:
> This is sort of an alpha-test version fo this ship. It's only about
> 50% complete... all sorts of textures to improve on and greeblies to
> add... but it's been months since I actually made any changes to it
> and other projects have come up, so I thought I better go ahead and
> post it, or it wouldn't ever be seen.
Looks good so far, but you really need to work on the textures - I would
look into image maps & UV for this one.
btw, more people will look at and comment on your posts if you make the file
size a litle smaller - try using jpg's for wip images - and turn off
multipart postings!
Kitty5 NewMedia http://Kitty5.com
TEL : +44 (01270) 501101 - ICQ : 15776037
PGP Public Key
Date: 23 Jul 2003 04:22:04
Message: <3f1e45ac@news.povray.org>
Beautiful design! Impressive use of POV primitives. Perhaps THIS should have
been the Enterprise NX-01 (NOT that I want to join the choir of fans who
complain about ST: Enterprise) but the design looks a bit older, and
therefore would fit the timeline perfectly. I really like it!
Star Trek is a passion of mine, and the only reason why I have a TV.. Nice
to see some good Trek pictures around here.
Hugo
In article <3f1d5a3f$2@news.povray.org>,
I have to confess that I don't really understand UV. I know that a lot
of people who do Trek models in other programs (most seem to be using
3DS) talk about it, but I'm not smart enough to pick up from context
what it means.
> multipart postings!
I'm new to this newsreader program. Please forgive.
In article <3f1e45ac@news.povray.org>, "Hugo Asm" <hua### [at] post3 tele dk>
Thanks, Hugo.
Frankly, I have to use primitives, 'cause I'm not smart enough to figure
out meshes with hundreds, even thousands of triangles. I'd be sure to
goof it up and have a corrugated starship hull, which isn't apealing at
all!
> all!
corrugated starship hull...held together with duct tape. and the
nacelles are on cinder blocks.
Tim Cook
Version: 3.12
Date: 23 Jul 2003 14:50:15
Message: <3f1ed8e7@news.povray.org>
> what it means.
I'd like to try and help you. I'm not an UV expert, to say the least. But I
know how it works:
Take any real-life object in your hand. Now, what do we learn about it?
Well, it has a surface. Lets say you want to apply a texture to that
surface. There are 2 ways to do it: 1) Take a pencil and begin to paint the
object. 2) Take a piece of paper, paint the paper, and glue that paper
around the object.
UV mapping is exactly like option 2. You paint on a piece of paper (the
coordinates of the paper is always <0,0,0> to <1,1,1>) and glue the paper
around the object. You can also cut up the paper in several pieces, to
better fit the object, just like you would probably do in real life. You can
even use the same pieces of the paper at several locations, by giving them
the same UV coordinates.
Usually UV coords are used in combination with meshes that consist of
triangles. As you know, each triangle has 3 corners that are positioned in
3D-space by 3 vectors. In POV-Ray (and many other programs) you can give
each of these vectors an additional information: A 2D coordinate, called an
UV. It only needs to be 2D because it refers to your texture, in other words
the piece of paper.. and the paper is flat.
This explanation hopefully covers the basics. If you want to become an UV
master you need practice of course. As do I... I certainly don't want to
discourage you from modelling with POV primitives in POV-Ray since they are
useful in many situations, they are fun, and not as hungry for memory.
Besides, your starship demonstrates that certain tools lead to certain
results. You are doing the job different that the people in Hollywood that
are using ... triangles, I suppose. That's why I said your starship looks
"older" than the Enterprise NX-01. It looks like it's been build by tools
that are "limited". That has a beauty, when done right (as your modelling
is).
However, if you decide you want to play with UV seriously, you need to
switch to meshes instead of primitives. Well, at least POV-Ray doesn't have
an efficient way of combining many primitives with UV coords.
If you have trouble with triangle-based applications, just as I always had
trouble with them, I suggest you try a freeware application that I've found:
Wings3d. It has a great user interface that is simple but efficient.
www.wings3d.com
Best regards,
Hugo
>You paint on a piece of paper (the coordinates of the paper
Argh! Of course not, since a paper is flat.
So it goes <0,0,0> to <1,1,0>
Sorry.
In article <3f1ecb74$1@news.povray.org>,
Rednecks in... spaaaaaaaaaaaaaace!
