POV-Ray : Newsgroups : povray.binaries.images : One-way glass - onewayglass.png (1/1) Server Time
16 Oct 2024 12:17:19 EDT (-0400)
  One-way glass - onewayglass.png (1/1) (Message 1 to 7 of 7)
Subject: One-way glass - onewayglass.png (1/1)
Date: 2 Mar 2005 10:30:54
Message: <cjameshuff-7A235D.10304802032005@news.povray.org>
How: use CSG to give the front and back faces different textures, the
front in this case is 90% reflective, with 10% transmission, and the
back face is simply 50% filtering. When seen from the front, objects
behind the glass are filtered through both layers while reflections are
unfiltered. When seen from the back, objects behind the glass pass
through the same layers, but the reflections are filtered twice. Here's
the code for the objects:
difference {
    sphere {< 0, 1, 0>, 1
            pigment {color rgb 1 transmit 0.1}
            finish {ambient 0 diffuse 0 reflection 0.9}
    sphere {< 0, 1, 0>, 1 scale < 1, 1, 0.8>
            pigment {color rgb 1 filter 0.5}
            finish {ambient 0 diffuse 0}
    plane {-z, 0 pigment {color rgb 0}}
    scale < 1, 1, 0.2>
Christopher James Huff <cja### [at] gmailcom>
http://tag.povray.org/
Download 'onewayglass.png' (109 KB)
Preview of image 'onewayglass.png'
Subject: Re: One-way glass - onewayglass.png (1/1)
Date: 2 Mar 2005 12:30:50
Message: <4225f84a@news.povray.org>
Nobody ever pays attention to my posts.  :P
A while back I demonstrated that POV can do one-way mirrors the same way
they're done in the real world; make a material 50% transparent and 50%
reflective, with one side being lit far more than the other.  That's all
it takes.
Tim Cook
Version: 3.12
Date: 2 Mar 2005 13:15:46
Message: <cjameshuff-7318E4.13154602032005@news.povray.org>
In article <4225f84a@news.povray.org>, Tim Cook <z99### [at] bellsouthnet>
> it takes.
That's not the way they are in the real world...that's just a
half-silvered mirror. This is a half-silvered mirror with a filtering
layer on the less reflective side. Both sides are equally bright in this
case...having the viewing side be darker makes the effect stronger, but
is not necessary. This is a fairly accurate way to model real-world
one-way mirrors.
Date: 2 Mar 2005 13:53:34
Message: <42260bae$1@news.povray.org>
If it makes you feel any better, I remember your post. :)
-Xplo
Date: 2 Mar 2005 14:30:32
Message: <42261458$1@news.povray.org>
news:42260bae$1@news.povray.org...
But if it makes you feel even better, I don't rember your post at all :p
Marc
Date: 2 Mar 2005 14:40:02
Message: <42261692$1@news.povray.org>
> one-way mirrors.
That seems to be the way those obnoxious reflective sunglasses are made,
but IIRC, two-way mirrors are a bit different.
And couldn't the 50/50 effect be acheived with conserve_energy?
~Mike
Things! Billions of them!
Date: 2 Mar 2005 15:19:50
Message: <cjameshuff-1E8876.15194902032005@news.povray.org>
In article <42261692$1@news.povray.org>,
The conserve_energy option is mainly useful with variable reflection. I
only used constant reflection, and with the settings I used energy is
conserved, though a more realistic scene would use reflection and
transmission that total to less than 100% since in practice we can't
make a surface that doesn't absorb any light.
We once had a one-way mirror on a porch door. It was really one way, if
you held it open so both sides faced the same environment, you could see
through it one way but not the other. When the mirrored layer scratched
off, you could see that there was a dark layer under it, so from one
side reflections were filtered twice while from the other they were
unfiltered. If you put it between two equally lit rooms, only one would
easily see the other. A dark room would see a light room through it both
ways, but one of the ways would work much better.
