POV-Ray : Newsgroups : povray.binaries.images : A new way of blobbing isosurfaces... - blob isosurface.jpg (1/1) Server Time
7 May 2026 08:51:42 EDT (-0400)
  A new way of blobbing isosurfaces... - blob isosurface.jpg (1/1) (Message 1 to 3 of 3)
Subject: A new way of blobbing isosurfaces... - blob isosurface.jpg (1/1)
Date: 30 Jan 2000 21:43:49
Message: <chrishuff_99-DDFE71.21442030012000@news.povray.org>
Since MegaPOV 0.4 includes my blob pattern, it is quite simple to make
blobs using isosurfaces. Of course, they are currently limited to
cylinders and spheres, but I am still planning to add additional types
of components, and the "blobs" used in the pattern are a bit more
flexible than standard ones. Also, you can use turbulence or other warps
more easily than you could if you make the blob out of functions. And it
might be a little faster, I haven't checked.
My object and proximity patterns are also included in this version, the
object pattern doesn't work very well in isosurfaces(because of the
sharp boundary between it's two values instead of a smoothly changing
value, it is harder to find the intersection point) and I haven't even
tried the proximity pattern with isosurfaces yet.
Here is the code for this isosurface:
#declare DensityFunc = 0;
#declare falloffAmt = 3;
#declare TestFunction =
function {
      blob {
         cylinder {<3, 2.4, 0>, < -3, 2.4, 0>, 1.0, 1
            density_function DensityFunc,falloffAmt
            rotate z*1*120
            rotate z*2*120
         sphere {< 0, 0, 0>, 2.75, 1
            density_function DensityFunc,  falloffAmt
         threshold 1
         max_density 0
      ramp_wave
      color_map {
         [0 color Black]
         [1 color White]
      warp {turbulence 0.2}
      scale 0.25
isosurface {
   normal on
   function {
      TestFunction(x, y, z)
   accuracy 0.01
   threshold 0.1
   contained_by {box {<-1.5, -1.5, -1>, <1.5, 1.5, 1>}}
   open
   eval
      pigment {color White}
      finish {brilliance 3}
   translate y*1.2
Chris Huff
e-mail: chr### [at] yahoocom
Download 'blob isosurface.jpg' (22 KB)
Preview of image 'blob isosurface.jpg'
Subject: Re: A new way of blobbing isosurfaces... - blob isosurface.jpg (1/1)
Date: 30 Jan 2000 22:21:35
Message: <3894ffbf@news.povray.org>
Isoblobs are already in MegaPOV...
Date: 31 Jan 2000 07:24:46
Message: <chrishuff_99-EEC227.07253131012000@news.povray.org>
In article <3894ffbf@news.povray.org>, "TonyB"
This isn't an isoblob(I think those have been in since MegaPOV 0.1). It
is an ordinary isosurface using a pigment with my blob pattern, which
was just added. A little bit of turbulence was used to make the surface
bumpy.
Chris Huff
