POV-Ray : Newsgroups : povray.binaries.images : IsoCactus - IsoCacti.JPG (1/1) Server Time
6 May 2026 23:09:15 EDT (-0400)
  IsoCactus - IsoCacti.JPG (1/1) (Message 16 to 25 of 25)
Subject: Re: IsoCactus - IsoCacti.JPG (1/1)
Date: 24 Feb 2000 21:23:26
Message: <38B5EA14.BC81C7D6@aol.com>
I like it! Tricky trace work there. I just recently found out that using
just method 2 and eval with a very low accuracy (about .001) gives the best
results. I hope to work on my tutorial soon :)
Chris Huff wrote:
> Here is my first attempt at a cactus in MegaPOV(inspired by some
> discussions in the thread "A clock"), it uses trace() and an isosurface.
> The texturing still needs a lot of work...
> Chris Huff
> e-mail: chr### [at] yahoocom
> Web page: http://chrishuff.dhs.org/
Samuel Benge
E-Mail: STB### [at] aolcom
Visit the still unfinished isosurface tutorial:
http://members.aol.com/stbenge
Date: 25 Feb 2000 07:11:21
Message: <chrishuff_99-D3B161.07124725022000@news.povray.org>
In article <38B5EA14.BC81C7D6@aol.com>, "SamuelT." <STB### [at] aolcom>
> using just method 2 and eval with a very low accuracy (about .001)
> gives the best results. I hope to work on my tutorial soon :)
Hmm, actually, that is a pretty high accuracy. :-)
Maybe this keyword should be changed to something like "allowable_error"
in the official version...
I confess that I haven't tweaked the settings for this isosurface at
all...it rendered as wanted and wasn't too slow, so I just didn't
bother. I just typed in the equation, liked the results, gave it a plain
green pigment, and began playing with trace().
Chris Huff
Date: 25 Feb 2000 18:46:04
Message: <38b7143c@news.povray.org>
Bravo!!!
Eric
"The whole problem with the world is that fools and fanatics are always so
certain of themselves, but wiser people so full of doubts."
--Bertrand Russel
Date: 25 Feb 2000 18:50:38
Message: <38b7154e@news.povray.org>
"Chris Huff" <chr### [at] yahoocom> wrote in message
news:chrishuff_99-00EEB8.15435524022000@news.povray.org...
> function {
>    sqrt(
>       sqr(x)
>       + sqr(y-sqrt(sqr(x/2)+sqr(z/2))*1.5)
>       + sqr(z)
>    ) - 1
>    - (sin(TH(x, y, z)*18)*0.1)//This is what makes the ridges
How did you come up with this?  Luck?  Patience?  Or did you say, "hmm...
the formula for a cactus should be blah blah blah" and just whip it up?
Even tho I've had a couple semesters of calculus and physics (20 years ago)
I have no clue how to take an idea and make an iso-surface out of it.
Eric
--Bertrand Russel
Date: 25 Feb 2000 19:19:09
Message: <chrishuff_99-3B26BF.19203525022000@news.povray.org>
In article <38b7154e@news.povray.org>, "Eric Freeman"
> ago)
No calculus or physics required. If there were, I wouldn't be able to
accomplish anything. I am still in Algebra II.
Well, the cactus is approximately spherical, with an indentation in the
middle and radial ridges.
I started from the equation for a sphere:
function {
   sqrt(
      sqr(x)
      + sqr(y)
      + sqr(z)
   ) - 1
To indent the top of the cactus and extend the bottom, I modified the y
portion of the equation like this:
This subracts a certain amount from the y value which depends on the
distance from the y axis. The /2 and *1.5 were just to "tune" it to the
right proportions. Subtracting from the y value has the effect of
raising that portion of the surface, since a higher initial value is
required to reach the threshold value. This modification really raises
the sides of the cactus, although a variant of it could be made to
depress the middle.
Then to add the "ridges", I subtracted a value depending on the sine of
a multiple of the angle around the y axis from the total density:
   - (sin(atan2(x, z)*18)*0.1)
(note that while this is slightly different from the other version, it
is really just a different way of calling the same function.)
The angle around the y axis can be calculated by atan2(x,z), which
returns the angle in radians. This is ok, since the sin() function takes
radians. I then multiply by 18 to get 18 "cycles" for a full revolution.
Since the sin() function returns values between -1 and 1, I multiplied
it's result by 0.1 to get shallower ridges. This makes the ridges extend
from about 0.1 units "below" the surface of the original sphere-like
shape to about 0.1 units "above" it. Because the function returns both
positive and negative values equally, I could just have easily used
addition to incorporate it into the equation.
I probably did a very poor job of explaining it, but that is how I came
up with this equation. I tend to have more success visualizing the
isosurface as a density function with a "skin" at a certain density
level(the threshold value). I start with a basic shape and progressively
"sculpt" the density pattern by tweaking the function, adding
characteristics to the function, and adding other density functions into
the mix.
Chris Huff
Date: 26 Feb 2000 03:53:35
Message: <8EE663839seed7@204.213.191.228>
Chris Huff wrote:
>I probably did a very poor job of explaining it, ...
No you didn't, I can visualize the process.
Can you, or somebody else add this, and more like this, to a Iso-tutorial?
Ingo
Date: 26 Feb 2000 18:22:53
Message: <38b8604d@news.povray.org>
Hey - that looks healthier than the one I got on the windowsill in front of me.
Great pic. Don't over-water it :-/
Alf
http://www.peake42.freeserve.co.uk/
http://ourworld.compuserve.com/homepages/Alf_Peake/
Chris Huff <chr### [at] yahoocom> wrote in message
news:chrishuff_99-9D37D5.05283324022000@news.povray.org...
> Chris Huff
Date: 26 Feb 2000 21:58:40
Message: <slrn8bh29p.1f5.sjlen@zero-pps.localdomain>
>Ingo
I'd like to second that.
 11:23pm  up 19:14,  7 users,  load average: 2.16, 2.29, 2.26
Date: 27 Feb 2000 23:55:15
Message: <38B9FF0B.53A68F18@faricy.net>
My cacti said water every 2 weeks, but then my succulent in the same pot shrivelled
up. Now there's only 6 in the pot instead of 7 :-( But the six are doing quite
well. :-)
___     ______________________________________________________
 | \     |_                 <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine               http://www.faricy.net/~davidf/
"Sitting on a cornflake, waiting for the van to come" -Beatles
Date: 28 Feb 2000 00:35:05
Message: <38ba0909$1@news.povray.org>
news:chrishuff_99-3B26BF.19203525022000@news.povray.org...
> that is how I came up with this equation.
Not at all.  This makes more sense than any other explanation of
iso-surfaces I've found.  Thanx.
Eric
--Bertrand Russel
