POV-Ray : Newsgroups : povray.binaries.images : Glow lights 2(~40K) - glowlits.jpeg (1/1) Server Time
5 May 2026 10:05:19 EDT (-0400)
  Glow lights 2(~40K) - glowlits.jpeg (1/1) (Message 3 to 12 of 32)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Glow lights 2(~40K) - glowlits.jpeg (1/1)
Date: 20 Nov 2000 20:15:30
Message: <3A19CCF8.95B87EE4@peak.edu.ee>
Chris Huff wrote:
> A modified version of a demo scene for glows. A total of 5052 glows in
> this scene...5000 of which are a half-hearted attempt at a starfield.
[snip]
The overall effect is very cool. Some of the glows seem to terminate too
abruptly (especially the stars); would this be easy to control/fix?
Margus Ramst
Date: 20 Nov 2000 20:32:40
Message: <chrishuff-98D469.20330220112000@news.povray.org>
In article <3A19CCF8.95B87EE4@peak.edu.ee>, Margus Ramst
> Some of the glows seem to terminate too abruptly (especially the
That is because I specified a cutoff radius for those glows. It
basically performs just enough calculations to figure out the distance
from the glow and stops if outside that radius...not quite bounding or
clipping, but with similar results. If it isn't specified, the glows are
essentially infinite.
I actually specified a radius for the stars that was too large, I want
to constrain the effect of the "stars" to a very small area, even though
it will give an abrupt edge. The closer glows in the area of the sphere
do not have this cutoff radius.
Christopher James Huff
Date: 20 Nov 2000 23:25:07
Message: <d3uj1tkriq3e2scfg0n5jrbdrdo1b5iodb@4ax.com>
  It's beautiful for a demo scene, Chris. If I had a faster machine I'd
love to render an animation with the starfield rotating around the
vertical axis of the reflective sphere. Gave me the impression of
Christmas lights in the night sky <s>.
  Which version of MegaPOV or MegaPOVplus are you using for this scene,
or is this a development version of your glows patch?
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 21 Nov 2000 00:41:47
Message: <3A1A0AB0.BA2E29D6@faricy.net>
Shouldn't the disco ball be faceted? :)
Date: 21 Nov 2000 03:49:36
Message: <3A1A3721.BDECF50F@ij.net>
	Screw a starfield, put those lights on a christmas tree. :)
	Not realistic but very a "christmas card" image. You could probably
sell it.
Israeli settlements in the West Bank and Gaza are
war crimes.
	-- The Iron Webmaster, 208
Date: 21 Nov 2000 05:29:59
Message: <chrishuff-1127E8.05302121112000@news.povray.org>
In article <d3uj1tkriq3e2scfg0n5jrbdrdo1b5iodb@4ax.com>, Alan Kong
It is a development version of MegaPOVPlus, with a convert_color()
function, an updated glow patch, and a few other things.
Date: 21 Nov 2000 05:41:16
Message: <chrishuff-91829E.05413921112000@news.povray.org>
In article <3a19c55b@news.povray.org>, "Tony[B]"
<ben### [at] panamac-comnet> wrote:
Could you translate that into C for me? English will also do fine...
Hmm, reading it as Portuguese, Babelfish says:
How pretty!
As Spanish, it says:
That pretty!
Well, thanks.
Bien, merci.
Gut Dank.
Bene, grazie.
Bien, gracias.
Date: 21 Nov 2000 06:12:29
Message: <3a1a589d@news.povray.org>
Chris Huff <chr### [at] maccom> wrote in message
news:chrishuff-1127E8.05302121112000@news.povray.org...
Based on 0.6a?
You gonna give us any hints?
Gail
* gsh### [at] monotixcoza              * System.dat not found.         *
* http://www.rucus.ru.ac.za/~gail/ * Reformat hard drive Y)es O)k  *
* If at first you don't succeed, call it version 1.0               *
Date: 21 Nov 2000 06:29:51
Message: <3A1A5CC1.2339977@skynet.be>
Ah, ah, ah, ah, staying alive, staying alive...
Ah, ah, ah, ah, staying aliiiiii-iiiii-iiii..
Fabien.
Date: 21 Nov 2000 06:42:38
Message: <chrishuff-A176A4.06430121112000@news.povray.org>
In article <3A1### [at] skynetbe>, Fabien Mosen
Umm, are you ok?
Ok, calm down. There are some men in white coats coming, they will give
you a nice clean jacket with long sleeves. Don't give them any
resistance, they only want to help, they will not hurt you.
