POV-Ray : Newsgroups : povray.binaries.images : Improved blobs - attached files (1/1) Server Time
28 Feb 2026 06:19:08 EST (-0500)
  Improved blobs - attached files (1/1) (Message 1 to 7 of 7)
Subject: Improved blobs - attached files (1/1)
Date: 18 Oct 2002 13:48:23
Message: <chrishuff-A2F898.12595018102002@netplex.aussie.org>
I've been doing more work on better blobs, here's the results. These
blobs are as easy to control, since they use a bounded function, unlike
the exponential blobs where adding one blob affects the whole object.
They are quite a bit slower as an isosurface with user-defined
functions, I plan to make a pattern patch though. Being compiled alone
will make it much faster, and it will make some optimizations possible.
I have no idea how to add it to the blob object, or even if it is
practical, but an object with the isosurface solving method could still
make more optimizations than a simple pattern.
The smooth ones are the isosurface versions. I tried to duplicate the
"open" one with blobs, but it would require a fifth blob component at
the center, so I went back and tried to duplicate the real blob with the
new blob function instead. As you can see, there are definite
differences, you can't just throw it in as a replacement, but it is
close.
http://tag.povray.org/
Download 'smoothblob1.png' (16 KB) Download 'smoothblob2.png' (17 KB) Download 'blob.png' (15 KB)
Preview of image 'smoothblob1.png'
Preview of image 'smoothblob2.png'
Preview of image 'blob.png'
Subject: Re: Improved blobs - attached files (1/1)
Date: 18 Oct 2002 13:51:52
Message: <ibi0ruoakuga1i9ret2alv8bhp92u1voon@4ax.com>
On Fri, 18 Oct 2002 12:59:50 -0400, Christopher James Huff <chr### [at] maccom>
For sure: they are no blobs like in iso csg library ? That's different
solution ?
ABX
Date: 18 Oct 2002 14:13:20
Message: <chrishuff-C843E6.14082318102002@netplex.aussie.org>
In article <ibi0ruoakuga1i9ret2alv8bhp92u1voon@4ax.com>,
> solution ?
These are isosurfaces using a new field function for components that
smooths out the second derivative discontinuities. I'm working on a new
version of the blob pattern that uses this function, which will make
using isosurface "blobs" with this function easier and faster, and will
probably try a new blob primitive as well.
Date: 18 Oct 2002 14:18:57
Message: <3DB05091.E213FCA@gmx.de>
The nice thing about isosurface blobs is that you can use arbitrary shapes
as components.  This would probably be difficult with a pattern.
Date: 18 Oct 2002 15:15:09
Message: <chrishuff-DFC613.15101318102002@netplex.aussie.org>
In article <3DB### [at] gmxde>,
I don't quite understand what you mean. The pattern will support
whatever shapes I add to it, which will be a lot more than the
isosurface primitive supports. It could even include a function
primitive. But the main point of doing it this way is that it will be
much faster then user defined functions...of course they will always be
more flexible.
I've got spherical components working, BTW. However, I'm finding some
very ugly stuff in the function and pattern code...don't look for it too
soon.
Date: 18 Oct 2002 15:20:55
Message: <3DB05F16.95DFDADC@gmx.de>
> more flexible.
If you can use an arbitrary function/shape as a blob component it would
not be bounded and therefore much less efficient.  The lack of bounding is
the great disadvantage of isosurface blobs.
Date: 18 Oct 2002 15:58:40
Message: <chrishuff-886F85.15534418102002@netplex.aussie.org>
In article <3DB05F16.95DFDADC@gmx.de>,
They wouldn't be the only kind of component. Functions would not be
automatically bounded, but it wouldn't make it impossible to bound the
other components, and they could also be manually bounded.
