POV-Ray : Newsgroups : povray.binaries.images : G Lissajous - gpovtest.jpg (1/1) Server Time
13 Sep 2025 17:51:51 EDT (-0400)
  G Lissajous - gpovtest.jpg (1/1) (Message 1 to 4 of 4)
Subject: G Lissajous - gpovtest.jpg (1/1)
Date: 27 Oct 2002 17:18:56
Message: <chrishuff-7F4D0F.16412127102002@netplex.aussie.org>
This was done with the G patch I've been talking about on some of the
other groups. I thought I'd test out G functions with a simple Lissajous
figure. It currently works, but the G code has to be in a separate file,
I'm thinking of possible ways to fix that. This demonstrates the use of
G functions as user-defined vector functions, I'll be working on a way
to use them in pigments as well, maybe as full-blown shaders.
Here's the G code used (in the file gpovtest.g):
function vector Position(scalar in) {
    scalar t = in*2*pi;
    return [sin(t*9), cos(t*7), cos(t*5)];
function vector Color(vector pt) {
    return [sin(pt.x*5)*cos(pt.x*9), sin(pt.x*5)*cos(pt.y*8),
sin(pt.z*11)*cos(pt.z*7)];
And here's the POV code:
global_settings {
    assumed_gamma 1
    location < 0, 0,-5>
    look_at < 0, 0, 0>
    angle 45
light_source {<-50, 50,-50>, color rgb 1}
light_source {< 0, 0,-5>, color rgb 0.1}
plane {-z, -1
        pigment {checker color rgb 0, color rgb 1}
        finish {ambient 0 diffuse 1}
//Compile the G code
g "gpovtest.g"
//hook up POV functions to the G functions
//this just tells POV the name, return type, and parameter types
#declare pointFn = function {g vector Position(scalar)}
#declare colorFn = function {g vector Color(vector)}
#declare J = 0;
#declare N = 3000;
#while(J < N)
    #declare ptA = pointFn(J/N);
    #declare ptB = pointFn((J+1)/N);
    union {
        sphere {ptA, 0.035}
        cylinder {ptA, ptB, 0.05}
//            pigment {color rgb ptA/2 + 0.5}
            pigment {color rgb colorFn(ptA.x, ptA.y, ptA.z)}
            finish {
                ambient 0 diffuse 1
                specular 1 roughness 0.01
    #declare J = J + 1;
http://tag.povray.org/
Download 'gpovtest.jpg' (31 KB)
Preview of image 'gpovtest.jpg'
Subject: Re: G Lissajous - gpovtest.jpg (1/1)
Date: 28 Oct 2002 15:23:00
Message: <3dbd9ca4$1@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
        Nice to see a Lissajous knot again.
          ~Steve~
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 28 Oct 2002 15:55:45
Message: <3dbda450@news.povray.org>
Heh, very nice. I know it is a bit early and doing things at parse-time
isn't what G is targeted for, but could you say something about the speed
differences between #macros and compiled G functions, for instance in your
above example?
Date: 28 Oct 2002 17:54:48
Message: <chrishuff-858EAE.17473628102002@netplex.aussie.org>
In article <3dbda450@news.povray.org>,
> above example?
Actually, this was all done at parse time. They do work at render time,
though I haven't made many tests of this.
About the speed: probably a lot closer to the existing POV functions
than to parsing. It doesn't do any optimization, but evaluating the
opcodes will be far faster than interpreting scene code directly. A
simple loop got about half a million iterations per second on my system,
POV gets closer to a few thousand (it was just a simple do-nothing loop
though, so no real measure of speed, and will be faster when increment
and decrement operations are added).
Replacing macros with G functions for math calculations could gain a lot
of speed, but you can't manipulate things like POV objects (not yet, at
least). Also, G functions should handle recursion with no problems (this
is untested, though). And since POV functions can't take vector
parameters, you have to split vectors into three float parameters to
pass them to G functions (since G functions are accessed through POV
functions).
So compared to POV: very fast. Compared to the existing POV VM: probably
quite slow for simple things, but since it allows things that can
eliminate a lot of duplicate computations necessary in POV functions, it
could be a lot faster for some problems.
