POV-Ray : Newsgroups : povray.binaries.images : More portal images - attached files (1/1) Server Time
4 Mar 2026 05:24:08 EST (-0500)
  More portal images - attached files (1/1) (Message 1 to 6 of 6)
Subject: More portal images - attached files (1/1)
Date: 21 Jan 2001 17:36:53
Message: <chrishuff-7CBC3C.17374621012001@news.povray.org>
In the first image, the portal is the sphere in the middle...the "far
end" of the portal is just a larger sphere surrounding the scene.
The second image is a small, closed room with a portal to an open area.
The room is lit entirely by light from the portal. As you see, no direct
light can pass through the portal...one of the limitations of my patch.
Christopher James Huff
Download 'Portal pigment 2.jpeg.jpg' (16 KB) Download 'Portal pigment 3.jpeg.jpg' (5 KB)
Preview of image 'Portal pigment 2.jpeg.jpg'
Preview of image 'Portal pigment 3.jpeg.jpg'
Subject: Re: More portal images - attached files (1/1)
Date: 21 Jan 2001 20:36:05
Message: <3A6B8D2C.CA606E84@faricy.net>
This'd be great for doing cubist work.
Date: 22 Jan 2001 16:31:59
Message: <MPG.14d6c1f6ec6928e9896d3@NEWS.POVRAY.ORG>
[This followup was posted to povray.binaries.images and a copy was sent
to the cited author.]
In article <chrishuff-7CBC3C.17374621012001@news.povray.org>,
chr### [at] maccom says...
Could you please explain to a mere mortal person what is shown in your
'portal' images??
What is a portal?
I have the feeling I miss something important here :)
Regards,  Sander
Date: 22 Jan 2001 17:13:28
Message: <chrishuff-F48A36.17143522012001@news.povray.org>
In article <MPG### [at] NEWSPOVRAYORG>, Sander Stols
> 'portal' images??
> What is a portal?
Hmm...well, you know what a wormhole is? And I'm not talking about the
kind made by slimy burrowing invertebrates...I mean the relative to
black holes.
The portal pigment basically links one area of space to another...kind
of a "magic mirror" effect. You can see into a different area by looking
into the portal, and you can set things up so you see the portal itself
through the portal, producing a "hall of mirrors" effect. However, this
is done by changing the color of a pigment to what would be visible
through that point on the portal.
You will also be able to set it up to act like a video monitor showing
output from a camera, a less interesting but probably more practical
application.
If you have trouble visualizing it, don't worry...it gives me headaches,
and I'm still not quite sure why type 0 works. Or sure that it does.
Date: 23 Jan 2001 17:08:10
Message: <MPG.14d81f083414425e9896d4@NEWS.POVRAY.ORG>
In article <chrishuff-F48A36.17143522012001@news.povray.org>,
Yes
> black holes.
I don't see where the pigment comes in. How can a pigment link one thing
to another?
> application.
Perhaps a very simple piece of example code could work??
Regards,  Sander
Date: 24 Jan 2001 19:03:48
Message: <chrishuff-151C60.19044524012001@news.povray.org>
> to another?
The color of the pigment at each point is the color of the part of the
scene seen through that point.
> > headaches,
The headaches came from a misunderstanding of a POV function...and it
works perfectly.
I doubt it...the syntax is just "portal_pigment {TYPE, PARAMETERS
TRANSFORMS}", with the simplest syntax being "portal_pigment". You apply
the pigment to the object, set the ambient to 1 if you don't want the
pigment to be shaded, and transform the object and far end of the portal
to the desired positions (unless you are using a camera portal), and
that's it.
