POV-Ray : Newsgroups : povray.binaries.images : Shifting Portal - Shifting Portal.jpeg (1/1) Server Time
4 May 2026 20:01:06 EDT (-0400)
  Shifting Portal - Shifting Portal.jpeg (1/1) (Message 1 to 4 of 4)
Subject: Shifting Portal - Shifting Portal.jpeg (1/1)
Date: 23 Jan 2001 16:18:12
Message: <chrishuff-711AFA.16185523012001@news.povray.org>
I added another small enhancement which allows the end of the portal to
be transformed from within the portal_pigment {} statement, and made a
pigment_map of two portal pigments to get this image. I animated a
slightly different version with the portal shifting from the chrome
sphere world to the purple world, the animation is available here
(again, as a QuickTime Movie):
http://homepage.mac.com/chrishuff/pov/ShiftingPortal.mov
There are three "worlds", each one is actually a union of it's objects
and light sources and a 1000-unit-radius sphere for the sky, I then
translate each world far enough that it is outside the spheres of the
other worlds. This technique lets me set up each individual world
centered around the origin and could be combined with declared
transformations to make managing the separate worlds quite easy. The
only restriction with this technique is that you can't use shadowless
lights, because they will affect objects in other worlds.
Christopher James Huff
Download 'Shifting Portal.jpeg.jpg' (19 KB)
Preview of image 'Shifting Portal.jpeg.jpg'
Subject: Re: Shifting Portal - Shifting Portal.jpeg (1/1)
Date: 23 Jan 2001 16:24:59
Message: <3a6df6ab$1@news.povray.org>
You could place them far enough away from each other that your
fade_distances make up for that... Or if there's a way to make lights affect
only certain objects.
Date: 23 Jan 2001 16:35:22
Message: <chrishuff-93C283.16361823012001@news.povray.org>
In article <3a6df6ab$1@news.povray.org>, "Ben Lauritzen"
With a lot of lights there could still be a noticeable effect...and I
didn't bother using fade_distance. I never use shadowless lights
anyway...
> Or if there's a way to make lights affect only certain objects.
Yes, with light_groups...I think it would be possible to set them up to
only affect the world they belong to, with little effort.
Date: 23 Jan 2001 16:38:48
Message: <3a6df9e8@news.povray.org>
That looks cool too btw
