POV-Ray : Newsgroups : povray.binaries.images : Tortured Tetrahedrons - attached files (1/1) Server Time
5 May 2026 01:29:54 EDT (-0400)
  Tortured Tetrahedrons - attached files (1/1) (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Tortured Tetrahedrons - attached files (1/1)
Date: 9 Jan 2001 13:29:21
Message: <chrishuff-E5B14D.13305909012001@news.povray.org>
In article <3A5A958A.468F9B79@faricy.net>, David Fontaine
<dav### [at] faricynet> wrote:
> It has that kind of video-game polygon-terrain look, but with enough
> detail to be appreciable. The effect is nice at that scale.
Terrain? Um, how? I can see the "video game" part, but terrain?
I admit that I don't play video games very much, but I've never seen a
video game landscape with the general shape of a sphere, or which looks
anything like a tetrahedron...
Christopher James Huff
Date: 9 Jan 2001 13:35:18
Message: <3A5B59E7.CE989B48@gmx.de>
Chris Huff wrote:
> Playing around with macro-generated meshes...and yes, these used to be
> 4-sided polyhedrons.
That looks great, what kind of formula generates those surfaces?
IMO they would look nice when made transparent, with refraction, photons,
Date: 9 Jan 2001 13:50:26
Message: <chrishuff-9A840C.13520609012001@news.povray.org>
In article <3A5B59E7.CE989B48@gmx.de>, Christoph Hormann
It simply recursively divides the triangles into 3 triangles with a new
point at the center, and moves the center point in a direction along the
normal of the triangle. The two vaguely sphere-like objects had a
positive displacement, the one that looks like an engraved tetrahedron
had a small negative displacement.
Another method, which I am going to try soon, would divide the triangles
into 4 parts, one center and 3 corner triangles, but the method I used
for these keeps the edges of the original shape intact.
I almost did that...but I was focusing more on the geometry than the
surroundings and texturing.
Date: 9 Jan 2001 14:08:37
Message: <3A5B61B4.70A401B9@gmx.de>
Sounds interesting, looks a bit like something wrapped with plastic.
That method could look much like heightfields generated with subdivision
algorithms like Terrain maker. Structures then much depend on how you
calculate the displacements.
Date: 9 Jan 2001 16:18:17
Message: <chrishuff-601D30.16195509012001@news.povray.org>
In article <3A5B61B4.70A401B9@gmx.de>, Christoph Hormann
Hmm, I guess it does sort of resemble the way Saran wrap wrinkles around
corners...I had thought it resembled cut glass more.
A similar algorithm is sometimes used, I think...I actually did
something using an algorithm that was almost exactly the same(except
using squares instead of triangles, and a randomized displacement), but
the many straight lines resulted in a very ugly landscape.
Date: 9 Jan 2001 18:19:01
Message: <3A5B9B44.88972637@faricy.net>
I just mean the general pointy randomized look.
Date: 9 Jan 2001 20:16:17
Message: <chrishuff-E61A7A.20175609012001@news.povray.org>
In article <3A5B9B44.88972637@faricy.net>, David Fontaine
Oh, I see...
BTW, there is actually no random component to these shapes...though the
complexity of some of them kind of leads to a lack of obvious order.
Date: 9 Jan 2001 20:20:01
Message: <3A5BB802.5091CF50@online.no>
Bags full of alien popcorns ?
Congratulations with a well done torture session !
Can you also make the edges and the corners smooth ?
Btw.: Didn't someone (Warp ?) make a program that could
round off the edges within a mesh ?
Tor Olav
mailto:tor### [at] hotmailcom
Date: 9 Jan 2001 21:42:57
Message: <chrishuff-6B6E97.21443609012001@news.povray.org>
In article <3A5BB802.5091CF50@online.no>, Tor Olav Kristensen
I don't want to even think about that...I would probably have to write
the mesh to a file and use some other tool on it.
I think Chris Colefax's compressed mesh macro package, which uses Warp's
compressed mesh format, can do that kind of thing.
Date: 10 Jan 2001 10:13:29
Message: <f87o5ts3pos3v28ql1n6f70ihecevdfu68@4ax.com>
On Tue, 09 Jan 2001 21:44:36 -0500, Chris Huff <chr### [at] maccom>
Or maybe John VanSickle's Surface Subdivision Suite?
Peter Popov ICQ : 15002700
