POV-Ray : Newsgroups : povray.binaries.images : isoteapot Server Time
21 Oct 2024 16:25:30 EDT (-0400)
  isoteapot (Message 1 to 10 of 18)
Subject: isoteapot
Date: 13 Jan 2003 05:27:28
Message: <bq452vgbjar919o5h6p6kccbculd64qdf1@4ax.com>
isosurface from mesh from official sample files
do not ask how long rendered
ABX
Download 'f_teapot.png' (84 KB)
Preview of image 'f_teapot.png'
Subject: Re: isoteapot
Date: 13 Jan 2003 05:32:22
Message: <3e2295b6$1@news.povray.org>
Render time? ; )
Date: 13 Jan 2003 05:39:55
Message: <jo552vs74rk5sbo8hkgdcfc6ppc2jjqkef@4ax.com>
On Mon, 13 Jan 2003 11:29:43 +0100, "Daniel Prien"
> Render time? ; )
about 0,5 weeks
of course using IC_Triangle from IsoCSG Library
ABX
Date: 13 Jan 2003 06:36:19
Message: <Xns930280191FA27raf256com@204.213.191.226>
ABX <abx### [at] abxartpl> wrote in
news:jo552vs74rk5sbo8hkgdcfc6ppc2jjqkef@4ax.com
> about 0,5 weeks
Imho it would a good idea to invent some optimizations for isosurfaces, and
for displacment. I have a few ideas, maybe some of them would be usefull :)
Date: 13 Jan 2003 06:56:44
Message: <rv952vckkflqsalno9vj8m7rb95kg43aq4@4ax.com>
On 13 Jan 2003 06:36:19 -0500, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
> > about 0,5 weeks
To optimize anything you should know it internally. To know something
internally you should know already implemented optimizations and solutions. Do
you know optimizations already implemented in isosurfaces as well as used
algorithms? Would you like to list them so community could get advantages from
your knowledge?
ABX
Date: 13 Jan 2003 09:30:10
Message: <web.3e22cd325f2ddff9b29393de0@news.povray.org>
ABX wrote:
<snip>
>your knowledge?
>ABX
I'll second that request, ABX.
IMNSHO the whole purpose of publishing on a newsgroup such as this is to
share knowledge as opposed to publishing just to demonstrate how "amazing"
you are.
John
Run Fast
Run Free
Run Linux
Date: 13 Jan 2003 12:31:40
Message: <Xns9302BC563194Araf256com@204.213.191.226>
news:rv952vckkflqsalno9vj8m7rb95kg43aq4@4ax.com
but if I have only a concept how isosurface work, I can still make
suggestions, even if they are not good - they can 'inspiere' someone with
better knowlage of isosurface code
Date: 13 Jan 2003 12:47:52
Message: <aju52vkn21i8o83452s558bq1p00t9ot05@4ax.com>
On 13 Jan 2003 12:31:40 -0500, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
> suggestions
Sure, you can. So what is the first? I have also some isosurface related ideas
and I would like to listen your proposition before coding anything.
ABX
Date: 13 Jan 2003 19:39:06
Message: <Xns930310AB16E24raf256com@204.213.191.226>
news:aju52vkn21i8o83452s558bq1p00t9ot05@4ax.com
> related ideas and I would like to listen your proposition before
> coding anything.
Most simple - to buid complex bounding boxes, or rather bounding shapes.
And to use 2 shapes. Bound and InnerBound.
Best scene to ilustrate this speed up is :
  + simple isusurface (i.e. sphere, torus, blob etc)
  + but with displaced surface (i.e. +f_noise3d(x*10,y*10,z*10)*.1)
  + casting a big shadow (i.e. on plane under surface)
  + with area light
Shape A is stanart bounding_box - it covers MINIMU area where MIGTH be our
isosurface
Shape B (inner-bounding) is a simple shape that coverw MAXIMUM area where
MUST be our isosurface.
When ray (or shadow-ray) hits shape B - it is 100% shure that shadow is
there (we do not have to do isosurface calculations). If it hits neither
boxes - there is no shadow (this is now - standart bounding box).
Example :
        * light
   ..........  <-- isosurface
----------------- plane
        * light
  ..XXXXXXX..
  ..XXXXXXX.    X-the inner bounding box
   .XXXXXXX..
 12345678901234 - this 14 spots neede shado ray tests. most of them hit X,
so we have about 80% less isosurfaces tests.
In some cases determinating inner-bounding-box shape is simple, i.e.:
isosurface {
  #local e=0.1;
  function {  x*x+y*y+z*z - 1 + f_noise3d(x,y,z)*e }
  contained_by { sphere { 0 1+e } }
   inner_bound { sphere { 0 1-e } }
Date: 13 Jan 2003 19:43:49
Message: <Xns93031177E7E74raf256com@204.213.191.226>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in
news:Xns### [at] 204213191226
contained_by { sphere { 0 1 } }
-or-
function {  x*x+y*y+z*z - 1 - f_noise3d(x,y,z)*e }
 inner_bound { sphere { 0 1 } }
oh and I forgot, Imho for shapes where calculations are *very* expensive
(like isosurfaces) we whould use comples shapes to bound them, or even
hierarchies, like :
isosurface is bounded with:
  ..a very complex mesh (10,000 faces[1])
    ..and this compelx mesh is bounded with simple mesh (100 faces)
     ..and simple mesh is finaly bounded by box
[1] - this complex mesh can be builded automaticly i.e. by trace funcion,
and results may be saved to some file and re-calculated only when
isosurface will change.
