POV-Ray : Newsgroups : povray.binaries.images : User defined Cube Camera Server Time
26 Sep 2024 19:20:51 EDT (-0400)
  User defined Cube Camera (Message 1 to 1 of 1)
Subject: User defined Cube Camera
Date: 19 Jan 2019 14:01:44
Message: <XnsA9DCCBC086D23seed7@news.povray.org>
Yet another ugly test image of a not so usefull camera.
Most cube map renderes don't support this format, it was mostly an
excercise in moving segments of a scene to certain positions in the
image. Gets messy quickly with all the selects,
ingo
#version 3.8;
global_settings {assumed_gamma 1}
#macro CubeCamCross(Loc)
  Renders cross shaped image for cube map.
  Image aspect ratio 4:3
  //+w800 +h600 +a0.1 +am3 +ua
  Loc: location of the camera.
  #local Map05 = function(x,y,z){((x-y)/(z-y))-0.5};
  #local CadreX = function(u,v){
    select(//+Y
      (v>1/6 & u>-0.25 & u<0),
      0,
      select(
        (v<1/6 & v>-1/6),
        0,
        select(//-Y
          (v<1/6 & u>-0.25 & u<0),
          0,
          0,
          Map05(u,0,-0.25) //-Y true
        select(//-X
          (u<-0.25),
          0,
          select(//-Z
            (u>-0.25 & u<0),
            0,
            select(//+X
              (u>0 & u<0.25),
              0,
              select(//+Z
                (u>0.25),
                0,
                0,
                Map05(u,0.25,0.5)//+Z true
              -0.5//-X true
            Map05(u,0,-0.25)//-Z true
          0.5//+X true
      Map05(u,0,-0.25)//+Ytrue
  #local CadreY = function(u,v){
    select(//+Y
      0,
      select(
        (v<1/6 & v>-1/6),
        0,
        select(//-Y
          0,
          0,
          -0.5//-Y true
        select(//-X
          (u<-0.25),
          0,
          select(//-Z
            (u>-0.25 & u<0),
            0,
            select(//+X
              (u>0 & u<0.25),
              0,
              select(//+Z
                (u>0.25),
                0,
                0,
                Map05(v,-1/6,1/6)//+Z true
              Map05(v,-1/6,1/6)//+X true
            Map05(v,-1/6,1/6)//-Z true
          Map05(v,-1/6,1/6)//-X true
      0.5//+Y true
  #local CadreZ = function(u,v){
    select(//+Y
      0,
      select(
        (v<1/6 & v>-1/6),
        0,
        select(//-Y
          0,
          0,
          Map05(v,-1/6,-0.5)//-Y true
        select(//-X
          (u<-0.25),
          0,
          select(//-Z
            (u>-0.25 & u<0),
            0,
            select(//+X
              (u>0 & u<0.25),
              0,
              select(//+Z
                (u>0.25),
                0,
                0,
                0.5//+Z true
              Map05(u,0,0.25)//-X true
            -0.5//-Z true
          Map05(u,-0.25,-0.5) //+X true
      Map05(v,1/6,0.5)//+Ytrue
  camera{
    user_defined
    location Loc
    direction {
      function{CadreX(u,v)}
      function{CadreY(u,v)}
      function{CadreZ(u,v)}
CubeCamCross(<0,0,0>)
background{rgb 1}
light_source {<0,0,0> rgb 1}
sphere{< 2,0  ,0>,0.5 pigment{rgb x}}  //X:<1,v,u> +X
sphere{<-2,0  ,0>,0.5 pigment{rgb x+z}}
sphere{< 0, 2,0>,0.5 pigment{rgb y}}   //Y:<u,1,v>
sphere{< 0,-2,0>,0.5 pigment{rgb y+z}}
sphere{<0,0  , 2>,0.5 pigment{rgb z}}   //Z:<u,v,1>  +Z
sphere{<0,0  ,-2>,0.5 pigment{rgb x+y}} //           -Z
#declare Radius = 2;
#for(I,1,18,1)
 torus{1,0.04 sturm rotate<90,0,0> rotate<0,I*10,0> pigment{rgb I/36}  }
box{-0.3,0.3 translate < 1,-1, 1> pigment{rgb x}}
box{-0.3,0.3 translate <-1,-1, 1> pigment{rgb y}}
box{-0.3,0.3 translate < 1,-1,-1> pigment{rgb z}}
box{-0.3,0.3 translate <-1,-1,-1> pigment{rgb .5}}
box{-0.3,0.3 translate < 1, 1, 1> pigment{rgb x+y}}
box{-0.3,0.3 translate <-1, 1, 1> pigment{rgb x+z}}
box{-0.3,0.3 translate < 1, 1,-1> pigment{rgb y+z}}
box{-0.3,0.3 translate <-1, 1,-1> pigment{rgb 1}}
Download 'cube_camx.jpg' (39 KB)
Preview of image 'cube_camx.jpg'
