POV-Ray : Newsgroups : povray.binaries.images : pattern ideas Server Time
18 Mar 2026 09:21:11 EDT (-0400)
  pattern ideas (Message 1 to 1 of 1)
Subject: pattern ideas
Date: 30 Oct 2003 13:08:42
Message: <Xns9424C2BAB2646seed7@netplex.aussie.org>
This is related to the posting:
Newsgroups: povray.unofficial.patches
Message-ID: <Xns### [at] netplexaussieorg>
Date: 28 Oct 2003 13:58:36 -0500
Xref: news.povray.org povray.unofficial.patches:8969
I tried to visualise one of the ideas of the posting mentioned above.
The first images shows the difference of a plane with spheres. The
spheres have a 'spherical' pattern and the 'cutaway_textures' keyword
makes it show.
The first image shows the result when the spheres are randomly
positioned within a 1x1x1 unit box. The radius of the speres is equal to
the minimum distance to the wall of the box, measured from the random
point. Actually this 'pattern' looks less exciting than I imagined. This
may be caused by the amount of small spheres, so ....
... the second image was created. Here a Gauss distribution, around the
center of the box, is used, instead of complete randomness. Also all
'spheres' are put on z=0.5, no randomness here. The standard deviation
of the distribution is set with the second parameter in the Rand_Gauss
macro.
To show something (simple) that could be done with such a pattern, the
third example is attached. Here only the color_map is changed. Other
things I tried is using a radial pattern (rotated 90*x) and a 'boxed'
pattern. Both with and without the color_map. The scene below is easy to
change, so no images of the latter two.
#version 3.5;
#include "rand.inc"
global_settings {assumed_gamma 1.0}
#declare Spheres = union {
  #declare Seed=seed(7);
  #declare DimX=15;
  #declare DimY=15;
  #declare DimZ=1;
  #declare I=0;
  #while (I<DimX)
    #declare J=0;
    #while (J<DimY)
      #declare K=0;
      #while (K<DimZ)
        #declare Centeroid=<rand(Seed),rand(Seed),rand(Seed)>;
        /*#declare Centeroid=<Rand_Gauss(0.5, 0.15, Seed),
                            Rand_Gauss(0.5, 0.0, Seed)>;*/
        #declare Rx=0.5-abs(Centeroid.x-0.5);
        #declare Ry=0.5-abs(Centeroid.y-0.5);
        #declare Rz=0.5-abs(Centeroid.z-0.5);
        #if (Rx <= Ry )
          #declare Radius = Rx;
        #else
          #declare Radius = Ry;
        #if (Rz < Radius)
          #declare Radius = Rz;
        sphere {
          0,1
            spherical
            /*colour_map {
              [0.2, rgb 0]
              [0.2, rgb 1]
              [0.6, rgb 1]
              [0.6, rgb 0]
          scale Radius
          translate Centeroid+<I,J,K>
        #declare K=K+1;
      #declare J=J+1;
    #declare I=I+1;
difference {
  object {Spheres translate <0,0,-0.5>}
  union {
    box {<-DimX,-DimY,-DimZ>,<DimX,DimY,0>}
    box {<-DimX,-DimY,0.0001>,<DimX,DimY,DimZ>}
  bounded_by{box{<0,0,0>,<DimX,DimY,0.0001>}}
  cutaway_textures
  location  <DimX/2, DimY/2, -400>
  look_at   <DimX/2, DimY/2,  0.0>
  angle 2.5
light_source {<0,0, -300>  rgb 1}
Ingo
Download 'rnd_leopard_03.png' (20 KB) Download 'rnd_leopard_02.png' (53 KB) Download 'rnd_leopard_01.png' (11 KB)
Preview of image 'rnd_leopard_03.png'
Preview of image 'rnd_leopard_02.png'
Preview of image 'rnd_leopard_01.png'
