POV-Ray : Newsgroups : povray.binaries.images : painter's palette (88 Kbytes) - 1 attachment Server Time
14 Apr 2026 23:03:41 EDT (-0400)
  painter's palette (88 Kbytes) - 1 attachment (Message 11 to 14 of 14)
Subject: Re: painter's palette (88 Kbytes) - 1 attachment
Date: 29 Jul 2003 13:58:29
Message: <Xns93C78D36BD51Cbadhabit07hotmaildot@204.213.191.226>
Hi!
Zio Pera <fiz### [at] lombardiacomit> wrote in
news:Xns### [at] 204213191226:
> You're too kind ! And sure... I'm posting the source in
> povray.binaries.scene-files.
Thank you very much for sharing your source with us. I rendered it @ 1600
X 1200 AA.03 and it took almost 2H40M on my P4 2.7Ghz 1Ghz RDRAM. I'll
append the stats @ the end of this msg. If you want, I can post the image
here or send it to you via email since you said it takes more than 17
hours to you for the render.
Ciao!
Mart
Here is the stats results:
Statistics for C:\Documents and Settings\Martin Belair\My Documents\POV
Devel\Ublob4\ublob4.pov, Resolution 1600 x 1200
Pixels:         1921600   Samples:         3774784   Smpls/Pxl: 1.96
Rays:         229266507   Saved:          98736036   Max Level: 5/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Blob                         172049711        45560350     26.48
Blob Component              2387488686      1688943458     70.74
Blob Bound                 18820100833      6387217121     33.94
Plane                        120070462        35356949     29.45
Sphere                        99426292        95386780     95.94
Bounding Box                 646208352       351551385     54.40
Light Buffer                 155319240       109456259     70.47
Vista Buffer                  23060480        21505282     93.26
Roots tested:             92232234   eliminated:            38513699
Calls to Noise:           38127157   Calls to DNoise:      654894154
Shadow Ray Tests:         67334560   Succeeded:             14068419
Reflected Rays:          225491723
Smallest Alloc:                 25 bytes   Largest:          1800024
Peak memory used:         24089253 bytes
Time For Parse:    0 hours  0 minutes   1.0 seconds (1 seconds)
Time For Trace:    2 hours 37 minutes   3.0 seconds (9423 seconds)
    Total Time:    2 hours 37 minutes   4.0 seconds (9424 seconds)
CPU time used: kernel 0.75 seconds, user 9404.45 seconds, total 9405.20
seconds
Render averaged 204.14 PPS over 1920000 pixels
POV-Ray finished
Date: 29 Jul 2003 17:42:40
Message: <Xns93C7B3389F47badhabit07hotmaildot@204.213.191.226>
Hum....
Martin Belair <bad### [at] hotmailDOTcom> wrote in
Before someonelse point it, I meant 1GB RDRAM.... ;)
Mart
Date: 29 Jul 2003 17:56:15
Message: <3f26ed7f$1@news.povray.org>
Thanks. I've got a new background! -Flu
"Zio Pera" <fiz### [at] lombardiacomit> wrote in message
> "Flu" <wflu at att dot net> wrote in news:3f25d9fb$1@news.povray.org:
> > Any chance of getting the source code for this? It's fantastic...
> > -Flu
Subject: Re: painter's palette (88 Kbytes) - 1 attachment - 1 attachment
Date: 31 Jul 2003 03:29:06
Message: <Xns93C9610578EAAfizbanlombardiacomit@204.213.191.226>
Ok, here is my best attempt in placing the camera. The horizon (which was
actually a bit cluttered) is not on sight anymore, and I think that this
keep the focus on the marbles and the blob.
I've compressed the .jpg file a little less than the previous image so the
result is sharper (and the file is bigger ;-).
Happy povving.
Download 'ublob4a.jpg' (136 KB)
Preview of image 'ublob4a.jpg'
