POV-Ray : Newsgroups : povray.binaries.images : Diamonds - 3 attachments Server Time
29 Oct 2024 23:53:34 EDT (-0400)
  Diamonds - 3 attachments (Message 1 to 7 of 7)
Subject: Diamonds - 3 attachments
Date: 3 Sep 2002 21:52:19
Message: <Xns927EDDD4B3E93MIKAJustMeInc@204.213.191.226>
This sucker took 22 hours to render on a 1ghz.
They look impressive but not quite what one would expect from a real
diamond.
A diamond is know to have 58 factes (cuts) but the girdle (diameter) of
the diamond also has either 16 or 32 cuts, in my case I used 32 giving
90 cuts total.  Each cut is a plane intersection.
Picture 1 - Plain textured diamonds
Picture 2 - The next to real thing
Picture 3 - The real thing
Download 'diamond.plain.jpg' (27 KB) Download 'diamond.jpg' (82 KB) Download 'diamond.picture10.jpg' (48 KB)
Preview of image 'diamond.plain.jpg'
Preview of image 'diamond.jpg'
Preview of image 'diamond.picture10.jpg'
Subject: Re: Diamonds - 3 attachments
Date: 3 Sep 2002 22:09:59
Message: <3d756b77$1@news.povray.org>
> diamond.
I'm curious about the settings you used, particularly the
max_trace_level and the photons (since in both cases it appears you may
not be using high enough values).
I would also guess that you may be using too much dispersion, as your
render is noticibly more rainbowy than the photo.
You might consider making the surface the diamonds are resting on
non-reflective if it results in a significant speed increase.
-Xplo
Date: 3 Sep 2002 22:12:47
Message: <3d756c1f$1@news.povray.org>
And how about posting the source? :)
Aaron
Aaron Gillies
New York City
x3rxes[!]yahoo.com
Date: 3 Sep 2002 22:24:08
Message: <Xns927EE34B6804CPOVMIKA@204.213.191.226>
Xplo Eristotle <xpl### [at] infomagicnet> wrote in
news:3d756b77$1@news.povray.org:
>> diamond.
> -Xplo
Took a couple of days to put the diamond together using math (no GUI, plain
text)
This was a test run (aren't they all..)
The diamonds are 1 POV unit in diameter.
global_settings {
  photons { spacing 0.08 count 5000 }
  max_trace_level 60
light_source { < -11, 40, -7 >, White*2 parallel point_at <0,0,0> }
Box under diamonds
finish  { ambient .05 diffuse .6 reflection .1 }
photons { target 1 refraction off reflection off }
Diamonds
finish { ambient  0    diffuse    0.2
         specular 0.8  roughness  0.003
         phong    1    phong_size 400
         reflection { 0.15, 0.05 fresnel metallic }
interior { ior 2.417  dispersion 1.044 dispersion_samples 30 }
photons { target 1 refraction on reflection on }
Date: 3 Sep 2002 22:25:18
Message: <Xns927EE37E370B7MIKAJustMeInc@204.213.191.226>
"Aaron Gillies" <no### [at] spamcom> wrote in news:3d756c1f$1@news.povray.org:
> Aaron
> Aaron Gillies
> New York City
> x3rxes[!]yahoo.com
Let me play with my toy a bit :)
Soon enough, no problem.
Date: 3 Sep 2002 23:20:24
Message: <3d757bf8@news.povray.org>
> global_settings {
You need only specify a spacing or a count; they're essentially two
different ways to get the same effect. I don't know offhand what sort of
results spacing .08 would give, but count 5000 is far too low; try half
a million for good results.
>   max_trace_level 60
60 should be plenty. Guess I was wrong about that.
I don't know proper values for diamond offhand, but these sound
plausible to me. I guess I was 1 for 3. Still, try increasing the number
of photons (and comment out dispersion for test renders!).
-Xplo
Date: 4 Sep 2002 08:34:38
Message: <Xns927F56A9CAA90POVMIKA@204.213.191.226>
news:3d757bf8@news.povray.org:
>>>may not be using high enough values).
>> global_settings {
> of results spacing .08 would give, but count 5000 is far too low; try
> half a million for good results.
>>   max_trace_level 60
> number of photons (and comment out dispersion for test renders!).
The ior and disoersion values are what the real world say they are,
as usual, we must compensate in the virtual world, try, try, try...
I'm not finished playing with this one yet, i'll be posting some more
as it evolves.
(MIKA) Marc Champagne
marcch.AT.videotron.DOT.ca
Montreal, CANADA
