POV-Ray : Newsgroups : povray.binaries.images : magnifying glass - 1 attachment Server Time
28 Feb 2026 21:22:41 EST (-0500)
  magnifying glass - 1 attachment (Message 1 to 7 of 7)
Subject: magnifying glass - 1 attachment
Date: 22 Jul 2002 01:11:01
Message: <Xns925348684210raf256com@204.213.191.226>
It took 1,5 h on Athlon 1,7 with photons spacing 0.05, probalby because
computer run out of it's 256 RAM (some memory was used by other process)
and it was swapping all the time do disc. 30 min took shooting photons.
I will try to render it again on ~1 Ghz with 1024 RAM, with spacing 0.02
and this time - with radiosity
How we can see some photons artefacts are in middle-botom of image. Maybe
just adding jitter instead of increasing spacing will help ?
If yes - maybe this image could be a nice example to manual about photons
All comments are welcomed
Download 'a4_v060.jpg' (111 KB)
Preview of image 'a4_v060.jpg'
Subject: Re: magnifying glass - 1 attachment
Date: 22 Jul 2002 01:12:41
Message: <Xns925348BB6CDFDraf256com@204.213.191.226>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in
news:Xns### [at] 204213191226
btw - where from this long rainbow line going accros bottom part of picture
came from :) ? It could be either glass refraction, or metal ring around it
reflection... or maybe both
Subject: Re: magnifying glass - 1 attachment - 1 attachment
Date: 22 Jul 2002 08:01:40
Message: <Xns92538E1E6BC70raf256com@204.213.191.226>
I added radiosity and "light sphere" - sphere made from about
30 light_soures.
But now my dispersion don't affect photons - ther is no rainbow, only white
photons - why ? All lights in "light sphere" doesn't effect photons - so I
quest it must be radiosity "fault" ? how can I still have dispersion
photons and use radiosity ?
Rays:          19747704   Saved:           2656851   Max Level: 47/100
47 ? wow I woundering why... I guest that some photons must go trought
ring->glass->ring->glass->ring etc
Surface of Revolution         29359998         1861789      6.34
Surface of Rev. Bound         29359998         3333150     11.35
does it means I should i.e. make another boundeing boxfor my SOR (glass
hand)
Peak memory used:          3431388 bytes
only 3 MB ? at spacing 2 times smaller it was IMO about 100 mb ;)
Time For Photon:   0 hours  0 minutes   9.0 seconds (9 seconds)
Time For Trace:    2 hours 10 minutes  32.0 seconds (7832 seconds)
    Total Time:    2 hours 10 minutes  41.0 seconds (7841 seconds)
Download 'a4_v061.jpg' (30 KB)
Preview of image 'a4_v061.jpg'
Date: 22 Jul 2002 11:09:32
Message: <3d3c202c@news.povray.org>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in message
Nice pic, but I would like to see something through the lens?
Maybe
Someone posted a similar problem a little while ago, and it was
suggested the light source was too close. Moved further away and
problem solved.
Alf
Date: 22 Jul 2002 11:32:01
Message: <Xns9253B1C93F745raf256com@204.213.191.226>
"Alf Peake" <alf### [at] peake42freeservecouk> wrote in
news:3d3c202c@news.povray.org
yes - it's my problem with it - can it be a bug ?
pigment is color rgbf <.93,.95,.99,.98>
and if ther is nodispersion - it looks like glass
after adding dispersion - glass is very 'dark' and non-transparent. After
adding dispersion I had to add ambinet 2.5 (!) to have sam brightness as
with no dispersion and ambient 0.0
>> Maybe just adding jitter instead of increasing spacing will help ?
> problem solved.
not in this case - light is in <-20,45,-30>*100
while scene (magnifying glass) is about 40x40x40
Date: 22 Jul 2002 14:35:47
Message: <Xns9253D0EECC8E6raf256com@204.213.191.226>
Yeep, I'm alsow tired with this magnifying glass :/ but I will not give up
until I get nice image :) even if each render time is 5-10 h ;(
This image shows possible bug - texture looks very diffrent on mosaic
preview 2x2, and on final 1x1 image.
The 2x2 glass is more 'clear' and 'sharp' and 1x1 is very blured/non-
transparent, while the effect, if any, should be reversed.
Download 'a4_pre.jpg' (33 KB)
Preview of image 'a4_pre.jpg'
Date: 22 Jul 2002 15:25:25
Message: <3d3c5c25@news.povray.org>
Perhaps you have to play around with "collect off" for the
glass, double_illuminate and transmittance instead of filtering...
Just a guess though...
Tim
