POV-Ray : Newsgroups : povray.binaries.images : Dream Tank, part 2 (78k BU) Server Time
27 Mar 2026 15:09:01 EDT (-0400)
  Dream Tank, part 2 (78k BU) (Message 1 to 10 of 10)
Subject: Dream Tank, part 2 (78k BU)
Date: 6 Feb 2002 21:58:10
Message: <Xns91ADCB100321Aspammindspringcom@204.213.191.226>
Well, I've tried several times over the last week to combine radiosity
and photons, but I'm not getting any love.  I'm using 2x2 area lights in
each of the pendants, and photons{ collect off } on all objects exept the
water.  Any hints?  My settings are as follows:
global_settings {
  assumed_gamma 1.6
  max_trace_level 10
  photons {
    count 50000
    autostop 0
    jitter .3
  radiosity {
    pretrace_start 0.01
    pretrace_end   0.01
    count 500
    error_bound 0.1
    recursion_limit 1
    always_sample off
Rich Allen
(Remove SPAM from my address to reply by e-mail)
Download 'DreamTank.jpg' (78 KB)
Preview of image 'DreamTank.jpg'
Subject: Re: Dream Tank, part 2 (78k BU)
Date: 6 Feb 2002 23:26:53
Message: <3c62020d$1@news.povray.org>
"Rich" <SrP### [at] ricoswebcom> wrote ...
>   photons {
>     count 50000
You're gonna need a lot more photons than that.  :-)  I'd go for at least a
few million, maybe even in the tens of millions for the resolution you're
looking at here.
-Nathan
Date: 7 Feb 2002 06:02:03
Message: <3C625EAB.D904BCC0@gmx.de>
'photons{ collect off }' should only be used if you don't want photons to
be visible on that object.  Like Nathan mentioned count should be much
higher.
Concerning the radiosity settings, with error_bound 0.1 you probably need
a lower pretrace_end or turn samples during final trace on.
Last updated 06 Feb. 2002 _____./\/^>_*_<^\/\.______
Date: 7 Feb 2002 10:16:22
Message: <3c629a46@news.povray.org>
"Rich" <SrP### [at] ricoswebcom> wrote in message
Umm, I think water is the only thing you want "collect off" for (as the docs
say, most things that are photon targets don't show photons, they just refract
or reflect 'em).
I think the stuff that looks like it might be photon-related on the tank bottom
and room walls is actually radiosity artifacts.
Date: 7 Feb 2002 12:38:36
Message: <3c62bb9c@news.povray.org>
How many gallons? What type of fish?
Rich <SrP### [at] ricoswebcom> wrote in message
Date: 7 Feb 2002 23:54:35
Message: <Xns91AEDEDD145FEspammindspringcom@204.213.191.226>
"Nathan Kopp" <nat### [at] koppcom> wrote in news:3c62020d$1@news.povray.org:
> least a few million, maybe even in the tens of millions for the
> resolution you're looking at here.
> -Nathan
Yikes!  OK, I'll give it a try tonight.
Rich Allen
Date: 7 Feb 2002 23:56:26
Message: <Xns91AEDF2DE5C53spammindspringcom@204.213.191.226>
"Tom Melly" <tom### [at] tomandlucouk> wrote in news:3c629a46@news.povray.org:
> docs say, most things that are photon targets don't show photons, they
> just refract or reflect 'em).
Hmm, wouldn't that defeat the purpose of using photons in this scene?  I'd
think putting collect off on the water would prevent it from producing
caustics, etc.
Rich Allen
Date: 7 Feb 2002 23:59:37
Message: <Xns91AEDFB7E4D55spammindspringcom@204.213.191.226>
"Shay" <sah### [at] simcopartscom> wrote in news:3c62bb9c@news.povray.org:
This would be an approximately 100 gallon tank, if I could get someone to
build it for me for less than a house payment!  Custom tanks are expensive!
If I had it, it would be a reef tank with some clowns, a tang, and lots of
inverts.
Rich Allen
Date: 10 Feb 2002 00:54:28
Message: <3c660b14$1@news.povray.org>
"Rich" <SrP### [at] ricoswebcom> wrote...
> caustics, etc.
Actually, you DO want to use "collect off" for the water.  This means that,
although photons won't show up ON the water, they will still be produced
THROUGH the water.
The reason we don't collect photons on clear surfaces is twofold:
1) It is a waste of time. Because clear surfaces have such a small diffuse
component, it doesn't make a difference if we show them or not.
2) On thin clear surfaces, we save photons on both surfaces of the object.
However, when we go to collect the photons, we will get a little "bleed"
from one surface when we're trying to gather from the other.  This is also a
problem when we have a clear object sitting directly on top of an opaque
object.  We _really_ want to turn collect OFF for the clear object, because
otherwise, when we try to collect photons on the opaque object, we will end
up gathering twice as many photons, since we'll be gathering the photons
from both the clear layer and the opaque layer.
-Nathan
Date: 11 Feb 2002 04:47:51
Message: <Xns91B21C7418485spammindspringcom@204.213.191.226>
"Nathan Kopp" <nat### [at] koppcom> wrote in news:3c660b14$1@news.povray.org:
> that, although photons won't show up ON the water, they will still be
> produced THROUGH the water.
Ah!  OK, I've gone through the photon docs yet again, and I see where I
missed the mark.  I had the idea in my head that turning off photon
collecting meant that photons ignored that object completely.  Thanks for
the explanation, it cleared up some of the points that weren't very clear
to me in the docs.
I've got another render going now with 2 million photons, corrected
collection, and no radiosity (I've yet to find good radiosity settings that
work with photons in this scene).
Rich Allen
