POV-Ray : Newsgroups : povray.binaries.images : Mezquita revisited - A14329aR3.jpg [1/1] Server Time
14 Jan 2026 18:31:13 EST (-0500)
  Mezquita revisited - A14329aR3.jpg [1/1] (Message 1 to 10 of 10)
Subject: Mezquita revisited - A14329aR3.jpg [1/1]
Date: 29 Mar 2001 15:03:12
Message: <MPG.152db36712a16bc898971a@NEWS.POVRAY.ORG>
Hi all,
Still busy with my 5-year project! A different view of the interior of
brighten the finished image a little as it came out too dark, but it
looks much better than without R. It is a view that appears on a picture
postcard I bought over there... At least, I try to let it look like
that.
The lights trouble me the most; lots of the texture is still too even; I
know, I know.
What do you think?
Regards,  Sander
Download 'A14329aR3.jpg' (82 KB)
Preview of image 'A14329aR3.jpg'
Subject: Re: Mezquita revisited - A14329aR3.jpg [1/1]
Date: 29 Mar 2001 17:48:36
Message: <3AC3BB0E.65481C7@faricy.net>
Not bad!  It appears kinda uniform at first, but it doesn't seem to
detract.  I notice a lot of subtelties in the light and shadow that aren't
readily apparent, I think they help.
Date: 29 Mar 2001 18:31:31
Message: <3ac3c5d3@news.povray.org>
That's a beautiful render, Sander...
Date: 30 Mar 2001 03:03:29
Message: <3ac43dd1@news.povray.org>
Wonderful - wish I had the patience to do all the CSG needed for interiors.
Mick
Date: 30 Mar 2001 03:24:31
Message: <3AC442BF.28F75BD9@gmx.de>
Sander wrote:
> Hi all,
> that.
> know, I know.
> What do you think?
Nice, there seems to be a lot of light coming from above in the
background, is that wanted?
If the render is too dark, just increase the ambient of the light emitting
objects.
Date: 30 Mar 2001 06:09:44
Message: <3ac46978@news.povray.org>
Sander,
Never one to criticize your work,
especially looking at it in 16 colors.
Still, I wonder...
what is at the end of the tunnel?
Only the best,
Peter
war### [at] hotmailcom
Sander wrote in message ...
Date: 30 Mar 2001 06:16:46
Message: <raq8cto4hgqa5na86i14uskvinljuclqrt@4ax.com>
On Thu, 29 Mar 2001 22:03:05 +0200, Sander <san### [at] stolscom> wrote:
<image>
<snip>
>What do you think?
The lighting seems very realistic to me Sander.
I like the timescale!  A little too much polish on the floor though :-)
It needs some sort of focus point to give more interest and scale to the scene.  I
take it
that this is how it really looks, so you can't add a sculpture - perhaps you could add
a
dreaded poser figure or two ?
David
dav### [at] hamiltonitecom
http://hamiltonite.com/
Subject: Re: Mezquita revisited - A14329aR3.jpg [1/1] - M_R_R.jpg [1/1]
Date: 2 Apr 2001 06:01:05
Message: <MPG.15326c3be2af9ff0989728@NEWS.POVRAY.ORG>
Thank you all for the encouraging words!
There is some help I would like to have with radiosity: I post the same
scene with and without R. What causes the change in colour and why does
the +R image look so flat?
Settings:
<code begin>
global_settings
  assumed_gamma 2.2
  ambient_light color rgb .25
      ini_option "+QR"
      radiosity {
        pretrace_start  1/16
        pretrace_end    1/128
        count          35
        nearest_count   5
        error_bound     1.8
        recursion_limit 3
        low_error_factor .5
        gray_threshold  0.0
        minimum_reuse   0.015
        brightness      1
        adc_bailout     0.01/2
        normal on
<code end>
Just a low-quality R to start with.
Is it the assumed_gamma? or the ambient_light?
Regards,  Sander
Download 'M_R_R.jpg' (52 KB)
Preview of image 'M_R_R.jpg'
Date: 2 Apr 2001 14:36:03
Message: <Xns9077D1DA785F7seed7@povray.org>
>Settings:
 <snip code>
 The use of ambient_light makes the scene look flat as it brightens it.
You can probably delete it when using radiosity.
 Also have a look at the diffuse values in the finish of your textures,
it determines the basic brightnes of a texture when using radiosity.
 You use an assumed_gamma of 2.2, together with the preset
display_gamma of 2.2 this results in an image with a gamma of 1. A
gamma 1 picture will look somewhat dark on a gamma 2.2 monitor.  It may
be that you compensated this by using stronger lights (value bigger
than 1) and the ambient_light.
 When you set the assumed_gamma to 1, the image will have a gamma of
2.2. This will look more natural on your monitor. You may have to
reduce light intensities.
Ingo
Date: 2 Apr 2001 21:43:29
Message: <slrn9ci9dp.35j.steve@zero-pps.localdomain>
On Thu, 29 Mar 2001 22:03:05 +0200, Sander wrote:
>What do you think?
I think awesome!
  1:17am  up 60 days,  2:01,  2 users,  load average: 1.06, 1.02, 1.04
