Peter Popov wrote:
> Here's an in-progress render of a scene I'm working on. There's still
> a lot to be done but I felt like sharing it anyway. Please let me know
> what you think.
He's cute! I like the walls, but the table looks rather simple next to
them.
Mel
Subject: Re: My first in a long time - Sloncho-wip-1.jpg
Date: 25 Feb 2000 15:21:52
Message: <38b6e460@news.povray.org>
> what you think.
> The elephant was modelled in the Rhino eval. The flame is a highly
> modified Howard Day one. The walls have a weird normal and that's
> about all there's to this image.
Sometimes its hard to put life in a pov image; you've done a terrific job of
accomplishing just that (even if it is a model of an inanimate object).
> Right now the walls are a rounded box with a normal. I'd greatly
> appreciate it if someone could help me make an isosurface version of
> that.
Here's a 30x30x30 (I think) rounded box, made out of clay with a nice color
map, the camera is currently inside the box looking towards a corner. If
you need help changing the way it looks don't hesitate to ask:
#version unofficial MegaPov 0.4;
isosurface {
function { x^20+y^20+z^20-1-noise3d(x*15,y*15,z*15)/10
-noise3d(x*60,y*60,z*60)/20 }
contained_by { box { -1.1,1.1 } }
threshold 0
accuracy .01
sign -1
pigment { bozo color_map { [0 rgb <.9,.8,.7>]
[0.5 rgb <1, .9, .8>] } scale <.1,.5,.1> }
scale 15
location <0,0,0>
look_at <-3,-3,7>
light_source {
0
color rgb 1
translate <0,0,0>
>Render time was 3 hr 5 min in the background on a K6III/400. Memory
>consumed was 23 MB (yes it's a big mesh :) ). Radiosity was used but
>only because I forgot to turn it off.
You mean you do test renders with radiosity turned on :-)
Beautiful image, it's great just as it is. The wall
looks particularly good. I'd be interested to know what
normal you used on the wall.
Steve email mailto:sjl### [at] ndirect co uk
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
11:23pm up 19:14, 7 users, load average: 2.16, 2.29, 2.26
Thanks to everyone for the kind comments. Here 's version two. This is
the last one before the final render. I want to apologize in advance
for the total of three version (this is No. 2) of the same image that
I'll post, but this project is really important for me and I want it
to be as perfect as I can make it.
Now for the image. I don't know the origin of the horribly looking
crackles in the smoke, if someone has an idea please let me know.
Someone pointed that the elephant is not casting a shadow. Should it
cast one, it being transparent and with such soft illumination as in
this scene? Does anyone recognize what is burning?
Thanks in advance for any comments. I really appreciate your help.
Peter Popov
pet### [at] usa net
ICQ: 15002700
Download 'sloncho-wip-2.jpg' (83 KB)
Preview of image 'sloncho-wip-2.jpg'
It's a P!
I really like that wall...
Lance.
The Zone - http://come.to/the.zone
Ain't I nuts? :)
I no longer keep that source but it was something along the lines of:
normal
{ average
normal_map
{ [1 granite -2 scale 2]
[0.5 granite]
[0.25 granite 0.5]
Just a simple 1/f type of thing, nothing special.
Peter Popov
pet### [at] usa net
ICQ: 15002700
I would like to comment if I may...
I was just comparing this version with the first you posted and to be
honest I really like the lighting you had in the original version. This
one seems to be a little over saturated with light. I liked the previous
version because it seemed self illuminating.
As far as shadows go a soft shadow would not be unrealistic but perhaps
it is not really needed. I was just playing around with a clear plastic
bottle with about 1/8 of it's volume filled with water. Under incandecent
light the shadow was very pronounced even with the caustics. Under a
flouecent light with a modest white reflecter behind it the shadow was
washed out but still present. The caustics were not as pronounced. The
distance to the single bulb flourecent lamp was around 2 meters.
It's your call but I really did like the lighting contrast better in
your first posted image.
Ken Tyler - 1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
P.S. Comparing the two images again another thing that stands out is the
depth of the normal used on the walls and floor. Again I favour the first
over the second perhaps because the first does not call attention to
itself as much as the first. It has become a distracting element. Perhaps
it is a result of the two different lighting models or perhaps you actually
changed the normal but whatever the reason I prefer the first over the last.
If Lance hadn't said it was a "P" I was going to say "D".
I too think a hazy shadow should exist for the elephant. Maybe the gnarled
lines are intersections with the wall? Maybe not.
Weren't you using a rounded box for the room before? I think that would be much
more suitable for this chipped and chiseled type of texture.
I really have to say though that the burning object, if indeed a letter P, is
going to need better distinction.
"Peter Popov" <pet### [at] usa net> wrote in message
news:A924ONPN86v60lcyPEFtprlybybW@4ax.com...
| Peter Popov
| pet### [at] usa net
| ICQ: 15002700
The lighting is a bit too intense in this image compared
to the first one. That looks like it is 3DS that's
been set alight.
I see what you mean about the smoke, only thing I could
suggest is that if you've got any ambient or diffuse in
that wall texture try turning it off or turning it down,
as it seems to be the wall shining through the smoke,
but I could be completely wrong here.
2:50pm up 1 day, 10:41, 7 users, load average: 2.10, 2.12, 2.09
