POV-Ray : Newsgroups : povray.binaries.images : --- Server Time
17 Feb 2026 04:38:30 EST (-0500)
  --- (Message 1 to 9 of 9)
Subject: Re: Harmonograph simulation
Date: 20 Sep 2016 16:06:00
Message: <9j53ublkn6273do4dm0rhcq940prr4aqe3@4ax.com>
On Tue, 20 Sep 2016 21:04:32 +0100, AQ <AQ### [at] worldcom> wrote:
>After some help from Clipka with some code I thought I would post one
>of the images from a 2 pendulum  Harmonograph simulator.
>It is from some code I was playing with in 2005 !!
>If anyone is interested I will post the source code
>AQ
Whoops. Sorry !!   I obviously need to learn how to post an image when
using Forte Agent
AQ
Date: 20 Sep 2016 16:30:01
Message: <web.57e19b653023a69a9934c0510@news.povray.org>
> >AQ
> using Forte Agent
> AQ
Let me try again
Download 'harmonograph 12 small.jpg' (296 KB)
Preview of image 'harmonograph 12 small.jpg'
Date: 21 Sep 2016 13:02:48
Message: <57e2bd38$1@news.povray.org>
>>> AQ
>> using Forte Agent
>> AQ
> Let me try again
Neat! I'd like to see the source code.
Bill P.
Date: 23 Sep 2016 12:17:52
Message: <dclaub5mogeqv89d6ecm2m1aa4mrf9epq5@4ax.com>
On Wed, 21 Sep 2016 13:02:48 -0400, William F Pokorny <ano### [at] anonymousorg> wrote:
>>>> AQ
>>> using Forte Agent
>>> AQ
>> Let me try again
>Bill P.
See P.B.S-F
I hope that is the correct folder
Date: 23 Sep 2016 12:35:29
Message: <57e559d1$1@news.povray.org>
>> Bill P.
> See P.B.S-F
Thanks much John.
The usual place for text scene files is P.T.S-F, but where it is works
for me. :-)
Bill P.
Date: 27 Sep 2016 12:20:00
Message: <web.57ea9b8e3023a69ab488d9aa0@news.povray.org>
> Bill P.
I was interested too, and just grabbed some info from Wikipedia and worked out
something functional.
My head was not in "function-space" at the time, so I just embedded the formulas
in the loop.
I think initially I was going to try to make it an isosurface...
The HSV to RGB macros are copied into the SDL to keep the parse time down, as I
haven't had the roundtuits to install 3.71-etc
I was surprised and delighted to see how closely related these are to Lissajous
figures, which I was just recently fiddling with.  I guess if there's no
damping, then they are identical things.
I haven't implemented the moving paper portion of the code yet.
Now we just need an animated inverse kinematic harmonograph machine to go with
the output...   :D
I haven't gotten anything near as beautiful as Anthraquinone did - I guess it's
all in the skill of acquiring a good feel for the oscillation parameters, and
writing up a nice texture for the trace.
#version 3.7;
global_settings {assumed_gamma 1.0}
#include "consts.inc"
#include "textures.inc"
#declare Size = 20;
 location <0, 0, -Size*2> // Front
 //location <0, Size*3, 10> // Top
 look_at  <0, 0, 10>
 up y
light_source {<10, 10, -100> White shadowless}
#macro _CH2RGB (HH)
   #local H = mod(HH, 360);
   #local H = (H < 0 ? H+360 : H);
   #switch (H)
      #range (0, 120)
         #local R = (120-  H) / 60;
         #local G = (  H-  0) / 60;
         #local B = 0;
      #break
      #range (120, 240)
         #local R = 0;
         #local G = (240-  H) / 60;
         #local B = (  H-120) / 60;
      #break
      #range (240, 360)
         #local R = (  H-240) / 60;
         #local G = 0;
         #local B = (360-  H) / 60;
      #break
   <min(R,1), min(G,1), min(B,1)>
#macro _CHSV2RGB(Color)
   #local HSVFT = color Color;
   #local H = (HSVFT.red);
   #local S = (HSVFT.green);
   #local V = (HSVFT.blue);
   #local SatRGB = _CH2RGB(H);
   #local RGB = ( ((1-S)*<1,1,1> + S*SatRGB) * V );
   <RGB.red,RGB.green,RGB.blue,(HSVFT.filter),(HSVFT.transmit)>
#declare Line = 0.1;
#declare Amp = 4;
#declare Amp1 = 10;  // X
#declare Amp2 = 5;  // X
#declare Amp3 = 10;  // Y
#declare Amp4 = 5;  // Y
#declare Freq = 1;
#declare Freq1 = 10; // X
#declare Freq2 = 10; // X
#declare Freq3 = 10; // Y
#declare Freq4 = 160; // Y
#declare Phase = 0;
#declare Phase1 = pi/2; // X
#declare Phase2 = pi/3; // X
#declare Phase3 = 0; // Y
#declare Phase4 = pi/6; // Y
#declare Damp = 0.1;
#declare Damp1 = 0.1; // X
#declare Damp2 = 0.1; // X
#declare Damp3 = 0.1; // Y
#declare Damp4 = 0.1; // Y
// From:  https://en.wikipedia.org/wiki/Harmonograph
// movement of a damped pendulum:
// #declare X = function (T) { Amp*sin(T*Freq+Phase)*pow(e, (-Damp*T)) };
//the motion of a rod connected to the bottom of the pendulum along one axes
will be described by the equation
// #declare X = function (T) { Amp1*sin(T*Freq1+Phase1)*pow(e, (-Damp1*T)) +
Amp2*sin(T*Freq2+Phase2)*pow(e, (-Damp2*T)) };
// A typical harmonograph has two pendulums that move in such a fashion, and a
pen that is moved by two perpendicular rods connected to these pendulums.
// Therefore the path of the harmonograph figure is described by the parametric
equations
//#declare X = function (T) { Amp1*sin(T*Freq1+Phase1)*pow(e, (-Damp1*T)) +
//#declare Y = function (T) { Amp3*sin(T*Freq3+Phase3)*pow(e, (-Damp3*T)) +
Amp4*sin(T*Freq4+Phase4)*pow(e, (-Damp4*T)) };
#declare Iterations = 20;
#declare Step = 0.0001;
#for (i, 0, Iterations*2*pi, Step)
 #local T = i;
 #local X = Amp1*sin(T*Freq1+Phase1)*pow(e, (-Damp1*T)) +
Amp2*sin(T*Freq2+Phase2)*pow(e, (-Damp2*T));
 #local Y = Amp3*sin(T*Freq3+Phase3)*pow(e, (-Damp3*T)) +
Amp4*sin(T*Freq4+Phase4)*pow(e, (-Damp4*T));
 #local H = (360/Iterations)*i;
 #local Color = _CHSV2RGB(<H, 1, 1, 0, 0>);
   sphere {
    <X, Y, i>, Line
    texture {pigment {rgbft Color} finish {specular 0.6} }
#end // end for i
Date: 9 Oct 2016 11:41:27
Message: <k96kvb1na0575fh43ehiagoa1gth70f3fr@4ax.com>
On Tue, 27 Sep 2016 12:17:18 EDT, "Bald Eagle" <cre### [at] netscapenet> wrote:
>> Bill P.
>in the loop.
>the output...   :D
You have a lot of parameters to play with there.
I simplified the code a bit so I could try to understand it and changed the colouring
again for simplicity. It needs to be simple for me to understand
it.  I had not seen those macros before.  I will have to have a look at them later.
AQ
Date: 10 Oct 2016 10:20:00
Message: <web.57fba2633023a69ab488d9aa0@news.povray.org>
colouring again for simplicity. It needs
> it.
It does seem like a lot of parameters at first, but it's not really a lot to
understand.
2 pendulums, each has amplitude, frequency, phase, and dampening.
each one has a second "wiggle" to it - thus there are four sets of 4 parameters.
I didn't even apply the first equation again to simulate the moving paper as
suggested in the Wikipedia article!  :)  :O
I discovered them after trying to follow some of the discussions about different
color spaces, and finally tracked down a thread where their location was
disclosed.
Now that I know that they're there, I find I play with them quite a bit for
scenes requiring lots of color changes.
Thanks for you initial image post - it's still quite inspiring!
> AQ
Date: 18 Nov 2016 12:35:01
Message: <web.582f3b133023a69ac437ac910@news.povray.org>
Just found this recently:
http://wheelof.com/sketch/
There's a link to source code on GitHub
