POV-Ray : Newsgroups : povray.binaries.images : Racing to the White [41KBbu] - bship1_os.jpg Server Time
15 Jul 2026 15:40:00 EDT (-0400)
  Racing to the White [41KBbu] - bship1_os.jpg (Message 1 to 10 of 11)
Subject: Racing to the White [41KBbu] - bship1_os.jpg
Date: 4 Jun 2001 17:06:29
Message: <7otnhtclocherlm3tm1f91g26a5rvmtmif@4ax.com>
Still not having much time for POVing, plus I've got a move next month
to look forward to :-)
Quick picture so that you don't forget me. (When I get the time, I may
add some land to the picture.)
Bye
Justin Whitton
_  __                                           __  _
 \/  \ mail: jus### [at] rayjayclaracouk /  \/
_/\__/ web: http://www.rayjay.clara.co.uk/     \__/\_
 \/  \ MSN Messenger ID:msn### [at] rayjayclaracouk /  \/
_/\__/ ICQ Messenger ID:100218081              \__/\_
Download 'bship1_os.jpg' (41 KB)
Preview of image 'bship1_os.jpg'
Subject: Re: Racing to the White [41KBbu] - bship1_os.jpg
Date: 4 Jun 2001 17:28:50
Message: <MPG.15861bf1d9b849ce9897bc@NEWS.POVRAY.ORG>
In article <7otnhtclocherlm3tm1f91g26a5rvmtmif@4ax.com>, Justin Whitton
says...
> Bye
> Justin Whitton
I'll certainly not forget this, anyway! Impressive, dynamic, beautiful!!
Regards,  Sander
Date: 4 Jun 2001 21:13:08
Message: <slrn9ho4nt.k55.steve@zero-pps.localdomain>
It's nothing to look forward too.  I moved in January, for the last time
in my life ever:-(  I lost my song book in the process, this was a file
of songs with chords built up over about 16 years, and now it's gone.
Big change to your usual stuff, it looks almost Bryce.  Nice image though.
 11:49pm  up 123 days, 38 min,  2 users,  load average: 1.20, 1.06, 1.02
Date: 5 Jun 2001 02:30:11
Message: <3b1c7c73@news.povray.org>
Nice.
How did you do the rocket fire? I know it's probably simple, but I've been
trying to get a similar effect with media and I just can't get it right. Could
you post the code for the flames?
Thanks,
Nekar
"Justin Whitton" <jus### [at] rayjayclaracouk> wrote in message
news:7otnhtclocherlm3tm1f91g26a5rvmtmif@4ax.com...
> Bye
> Justin Whitton
> _  __                                           __  _
Date: 5 Jun 2001 02:39:27
Message: <ifvohtc805p4ld79qihta7dp56a1oqo24r@4ax.com>
On Tue, 5 Jun 2001 08:34:03 +0200, "Nekar Xenos"
<j-p### [at] citywalkcoza> wrote:
>Nice.
>Thanks,
>Nekar
Nekar,
it requires MegaPOV by Nathan Kopp, and uses the changed version of
emission media.
		hollow
		pigment { rgbt <1,1,1,1> }
		finish { ambient 0 diffuse 0 }
		interior {
			media {
				emission { 2, 1 }
				method 3
				intervals 5
				samples 10,10
				density {
					spherical
					colour_map {
						[0 rgb 0]
						[0.5 rgb <0.1,0,0>]
						[0.9 rgb <0.9,0.9,0>]
						[1 rgb 1]
Justin Whitton
_  __                                           __  _
Date: 5 Jun 2001 02:41:40
Message: <3b1c7f24@news.povray.org>
/* Nekar Xenos */#local N=<-20,40,100>;#local K=<20,-40,100>;#local R=seed(0);
blob{#while((K-N).x>0)#local X=N;#local N=N+<rand(R),rand(R),1>/3;#local N=(
vlength(N-K)<vlength(X-K)?N:2*X-N);sphere{<N.y,-N.x,N.z>,1,1 scale .02}sphere{N
,1,1 scale.02}sphere{<-N.x-40,N.y,N.z>1,1 scale.01}sphere{<N.x+40,-N.y,N.z>1,1
scale.01 }#end pigment{rgbt 1}interior{media{emission <2,4,5>*5}}hollow}
news:ifvohtc805p4ld79qihta7dp56a1oqo24r@4ax.com...
> >Nice.
Could
> >Thanks,
> >Nekar
> Nekar,
> emission media.
> hollow
> interior {
> media {
> emission { 2, 1 }
> method 3
> intervals 5
> samples 10,10
> density {
> spherical
> colour_map {
> [0 rgb 0]
> [0.5 rgb <0.1,0,0>]
> [1 rgb 1]
> Regards,
> Justin Whitton
> _  __                                           __  _
Date: 5 Jun 2001 12:16:28
Message: <chrishuff-D0B268.11130005062001@povray.org>
In article <ifvohtc805p4ld79qihta7dp56a1oqo24r@4ax.com>,
> emission media.
You could get a very similar effect using absorption in combination with
emission instead of that special emission, but MegaPOV is still very
helpful for media (mainly because of sampling method 3).
Christopher James Huff - chr### [at] maccom, http://homepage.mac.com/chrishuff/
Date: 5 Jun 2001 12:29:49
Message: <3b1d08fd$1@news.povray.org>
Nice water... i really like it.
> Bye
> Justin Whitton
Date: 5 Jun 2001 16:37:06
Message: <e8gqhtkkvk2uk6p1r9pmonn4t2tc4vne7p@4ax.com>
On Tue, 05 Jun 2001 11:13:00 -0400, Chris Huff <chr### [at] maccom>
>> emission media.
I should have clarified, to use the source snippet posted you need
MegaPOV.
As Chris rightly says you can get the same effect using emission and
absorption (I've done it that way in the past), but using the new
emission type in MegaPOV reduces the requirements of brain CPU cycles
[And I'm trying desperately not to upset Chris because his
implementation of Glows in MegaPOV is one of my favourite features,
thanks Chris.]
Justin Whitton
_  __                                           __  _
Date: 5 Jun 2001 16:44:32
Message: <sngqhtk5mmij0bus9onqup5fpg78sr0ed6@4ax.com>
On Tue, 5 Jun 2001 12:33:25 -0400, "Ross Litscher"
No don't like it, it's a cheat.
a) It's not transmissive, it's only variable reflection on a plane
with a normal. (Single colour plane.)
plane { y, 0
	interior {
		ior 1.5
		pigment { rgb <0,0.3,0.2> }
		normal { granite 0.02 scale <10,20,5> rotate y*36 }
		finish {
			ambient 0
			diffuse 1
			reflection_type 1
			conserve_energy
b) the stars have been set to "vampire" mode with no_reflection
because they looked "odd" when reflected on this water.
There once was a time when I tried to make my scenes internally
coherent, i.e. if you placed the camera anywhere in the scene you
would get a picture of the scene, not the back of a cardboard cut-out.
Now it's more of a case of please don't go out of the bounds of the
designated viewing area :-(
Regards
Justin Whitton
_  __                                           __  _
