POV-Ray : Newsgroups : povray.binaries.images : some of my little raytracer results Server Time
12 Jun 2026 20:22:27 EDT (-0400)
  some of my little raytracer results (Message 1 to 4 of 4)
Subject: some of my little raytracer results
Date: 21 May 2026 04:19:58
Message: <6a0ec02e@news.povray.org>
In
https://news.povray.org/povray.general/thread/%3C69f841da%40news.povray.org%3E/
I wrote a bit about a little ray tracer I'm writing. Besides the image,
it now writes a lot of data to a SQLite database. Amongst that is the
ray graph
for each pixel. This, with some other data can then be queried:
  NimRay Query tool
  renders analytical images from a NimRay database.
  Usage:
    nrq <database.db> <query> [options] [output.ppm]
  If output.ppm is omitted, writes P6 binary PPM to stdout.
  Queries:
    pixels              Final composited image
    reconstruct         Reconstruct image from raygraph + lightContribs
    primary             Primary hits only, no reflections (TODO)
    normals             Surface normal map (XYZ → RGB)
    depth [near] [far]  Depth map (default near=0.1 far=20.0)
    raygraphlength      Ray graph length per pixel
    bouncedepth         Deepest reflection bounce per pixel
    albedo              Material base colour, no lighting
    shadow              Shadow occlusion fraction per pixel
    ao                  Ambient occlusion approximation
    shapemask           Shape/background mask (white=hit, black=miss)
    light <n>           Contribution of light N
    reflectiondepth <n> Reflection rays at exactly depth N
    crossshape <y> <x>  Pixels where primary hit shape Y, reflection hit
shape X
Most of it works fine. The one that doesn't yet is a complete image
reconstruction from the ray-graph. Can't get the query going properly.
It works for a single ray, but running that for each pixel also takes
ages.
So far a lot of analytical data can be extracted, see images. An
interesting one
is the ray-graph length. It could be used to analyze and subdivide the
multithreaded work load over different sized areas.
My toy renderer is single threaded. It's 840 KB large and has SQLite
build in.
Without using the database it renders the image in ~0.3 s. with database
it takes ~2 seconds more. The resulting database is a whopping 220292KB.
For archiving it can be compressed ~5.5x by 7zip.
Each of the analytical images are created in less than a second, didn't
time them.
ingo
Download '_pixels.png' (44 KB) Download 'albedo.png' (3 KB) Download 'ao.png' (6 KB) Download 'bouncedepth.png' (4 KB) Download 'crossshape0_1.png' (2 KB) Download 'crossshape0_4.png' (2 KB) Download 'crossshape4_0.png' (2 KB) Download 'depth.png' (12 KB) Download 'light0.png' (22 KB) Download 'light1.png' (36 KB) Download 'normals.png' (30 KB) Download 'raygraphlength.png' (7 KB) Download 'reflectiondepth2.png' (11 KB) Download 'reflectiondepth4.png' (4 KB) Download 'shadow.png' (6 KB) Download 'shapemask.png' (2 KB)
Preview of image '_pixels.png'
Preview of image 'albedo.png'
Preview of image 'ao.png'
Preview of image 'bouncedepth.png'
Preview of image 'crossshape0_1.png'
Preview of image 'crossshape0_4.png'
Preview of image 'crossshape4_0.png'
Preview of image 'depth.png'
Preview of image 'light0.png'
Preview of image 'light1.png'
Preview of image 'normals.png'
Preview of image 'raygraphlength.png'
Preview of image 'reflectiondepth2.png'
Preview of image 'reflectiondepth4.png'
Preview of image 'shadow.png'
Preview of image 'shapemask.png'
Subject: Re: some of my little raytracer results
Date: 22 May 2026 02:42:18
Message: <6a0ffaca$1@news.povray.org>
recreating the image from the ray-graph now works, takes half a second
single threaded. That makes it possible to change the colour of a light
in post production.
ingo
Download 'changelight.png' (41 KB)
Preview of image 'changelight.png'
Date: 24 May 2026 05:35:00
Message: <web.6a12c549c5380a4f22ad5b506cde94f1@news.povray.org>
hi,
ingo <ing### [at] nomailcom> wrote:
> In
> ray graph
> build in.
v interesting stuff, I wish I had "head space" for.
what happens if, say, you re-render the same scene but with the camera moved a
little, does the whole database need rewriting/rebuilding ?
thanks.
regards, jr.
Date: 24 May 2026 19:05:00
Message: <web.6a1383f4c5380a4f17bac71e8ffb8ce3@news.povray.org>
Too some extent, yes. Too some extent, no.
The obvious answer that "doe not make any chocolate".
In the current way the renderer works I could define multiple cameras per trace.
Then what y're looking for would work. Else, sorry, no, re-render.
ingo
