After Clarence1898 said he would have to try metallic reflection with
values greater than 1--forbidden fruit effect, except no one gets
punished--I figured I would try it myself. As I figured would happen,
the mutual reflections saturated the red to the extent that it's
brighter than the original color; but otherwise, it's not too bad.
Some reddening of mutual orange reflections is inevitable with 3-channel
RGB rendering, but having the red channel greater than 1 really steps up
the effect. The spectrally rendered image (36 channels) shows very
little hue drift in the reflections.
But I still remembered an overly bright render with runaway reflections
and a necessity to limit max_trace_level to 5, so I tried transparent
textures to see if that was what I remembered. The left sphere in each
image uses filtered transparency, and the right sphere uses interior
fading. Still not bad.
Turns out what I remembered was M_Glass2 from textures.inc. Don't use
M_Glass2. M_Glass2 is horrible. In fact, don't use any of the glass
materials in textures.inc; roll your own using Fresnel reflection.
Other notes:
- The assumed_gamma is 1.0.
- For consistency with spectral rendering, the finish diffuse is set
to 1.0. To compensate, all the object colors are multiplied by
Clarence's diffuse, 0.6. Thus, 2.0 becomes 1.2.
- You may notice that the RGB glass renders have a higher green channel
than the spectral render; this is to mitigate the primary color bias
(in this case, red) that always occurs with 3-channel rendering of
colored transparency. This bias is also seen in the metallic mutual
reflections, and to a lesser extent in the radiosity of the non-
metallic object, but the bias there cannot be corrected without
changing the color of the unreflected surface.
- For the record, using my SPD generator (see MakeSpectrum in p.object-
collection), I can get up to rgb <2.2557, 0.5639, 0> at diffuse 0.6
before the color IRL starts reflecting more red than it receives.
Download 'hyper_orange-096.jpg' (43 KB)
Download 'hyper_orange-120.jpg' (45 KB)
Download 'hyper_orange-120sr.jpg' (44 KB)
Download 'hyper_orange-glass-096.jpg' (34 KB)
Download 'hyper_orange-glass-120.jpg' (36 KB)
Download 'hyper_orange-glass-120sr.jpg' (34 KB)
Preview of image 'hyper_orange-096.jpg'
Preview of image 'hyper_orange-120.jpg'
Preview of image 'hyper_orange-120sr.jpg'
Preview of image 'hyper_orange-glass-096.jpg'
Preview of image 'hyper_orange-glass-120.jpg'
Preview of image 'hyper_orange-glass-120sr.jpg'
