POV-Ray : Newsgroups : povray.binaries.images : Other things the text object can do. Server Time
5 Aug 2025 09:48:14 EDT (-0400)
  Other things the text object can do. (Message 21 to 30 of 37)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Other things the text object can do.
Date: 6 Mar 2025 14:55:00
Message: <web.67c9fcb19216b80b33dbb0635cc1b6e@news.povray.org>
"Leroy" <whe### [at] gmailcom> wrote:
> "Chris R" <car### [at] comcastnet> wrote:
> > William F Pokorny <ano### [at] anonymousorg> wrote:
> > > Only tricky part is figuring out the base character size and spacing.
> > > I've not found an easy and reliable way to do that as yet. I got to the
> > > above values by trial and error.
> > > Used box characters for the rectangular frame using the strings:
"└───&#9
47
> 2;
> > ─────┘" and
"│││││││││&#9
47
> 4;
> > > Bill P.
> > If you are using a mono-type font, this worked for me:
> > #local _t1 = text { ttf "fontname.ttf" "A" 1.0, 0 }
> > #local _t2 = text { ttf "fontname.ttf" "AA" 1.0, 0 }
> > #local _t1sz = max_extent(_t1) - min_extent(_t1);
> > #local _t2sz = max_extent(_t2) - min_extent(_t2);
> > #local _unit_width = (_t2sz - _t1sz).x;
> > text { ttf "fontname.ttf" "What the heck?" 1.0, -2*unit_width*x }
> > text { ttf "fontname.ttf" "What the heck?" 1.0, <-unit_width, -1, 0> translate
> > <0, 14, 0> }
> > -- Chris R
> I remember this little trick. But I didn't want to be limited to  mono-type
> fonts so I wrote a macro that cut a string into pieces and place each letter
> separately. And promptly forgot about it.
Aah!  In the meantime, I went down a rabbit hole and essentially did the same
thing...
See: https://github.com/carath63/povlibrary
library/libtext.inc
Examples/text_test.pov
Here is an example of using that technique to lay out text around a cylinder, up
a helix, and following a spline.  The spline relies on how close your the
distance between letters lines up with the distance between spline points.  As
you can see, it didn't work very well once the letters moved around the front
curve of the spline.  Still trying to figure out how to fix that.
-- Chris R
Download 'text_test.png' (98 KB)
Preview of image 'text_test.png'
Date: 6 Mar 2025 15:35:00
Message: <web.67ca06699216b80b33dbb0635cc1b6e@news.povray.org>
#9
> 47
> > 2;
> > > ─────┘" and
#9
> 47
> > 4;
> > > > Bill P.
> > > <0, 14, 0> }
> > > -- Chris R
> thing...
> library/libtext.inc
> -- Chris R
To prove my spline layout code is correct, I created some tools for converting a
spline whose values have an arbitrary range into a spline whose values go from
0.0 to the computed length of the spline over the given range of values.  Using
a spline that has been tuned this way gave a much better result in laying out
the text.
-- Chris R
Download 'text_test.png' (85 KB)
Date: 6 Mar 2025 16:00:00
Message: <web.67ca0bc19216b80bd97b426e25979125@news.povray.org>
> the text.
are you aware that there are spline macros to do this sort of thing?
IIRC, they are in transforms.inc
- BW
Date: 7 Mar 2025 11:10:00
Message: <web.67cb194b9216b80b53fb81ab5cc1b6e@news.povray.org>
> > the text.
> - BW
I knew in the back of my head that I had used the Spline_Trans macro before, but
couldn't remember what it was called or where it was.  Thanks!
I'll probably create a new version of my Text Spline alignment macro and replace
my code for computing the rotations with this, which allow for banking the text
as well, which would be cool.
The macro still has to do the work of computing the offset based on the letter
spacing, and then using this macro to do the placement and orientation.  And I
haven't seen anything equivalent to the code I wrote to convert a Spline using
arbitrary values with a Spline that uses distances along the spline curve for
values, so I think that's still useful.
-- Chris R
Date: 7 Mar 2025 11:55:00
Message: <web.67cb24049216b80ba5a6be6925979125@news.povray.org>
I didn't have a lot of time when I was trying to find what I was looking for.
I think if you're able to locate (or someone can post a link to) Chris Colefax's
spline macros - my understanding is that there was all of that kind of stuff in
there as well.
I've never used any of these macros, and my memory tells me that the good macros
had something to do with a rollercoaster animation....
It's possible I might have some of these Colefax macros squirreled away
somewhere.
Won't have the opportunity to dig around for them and post until maybe Sunday.
We also really ought to have a thread where ALL of the Colefax macros are listed
and posted as attachments, and then they can be collected into a single zip so
that they aren't lost.
- BW
Date: 7 Mar 2025 13:40:00
Message: <web.67cb3ca29216b80b53fb81ab5cc1b6e@news.povray.org>
> > > the text.
> > - BW
> -- Chris R
Time to move on, but here's the previous image using the new macro using
Spline_Trans with a Banking value of 1.0.  I used a more interesting font as
well.  The banking is subtle, but you can see it on the downward curve around
the "good people" section.
-- Chris R
Download 'text_test.png' (95 KB)
Date: 7 Mar 2025 15:25:00
Message: <web.67cb55859216b80ba5a6be6925979125@news.povray.org>
Also, of course, Friedrich Lohmueller's site.
https://www.f-lohmueller.de/pov_tut/animate/pov_anie.htm
(near bottom)
Date: 10 Mar 2025 09:30:00
Message: <web.67cee8709216b80bcaf2d0115cc1b6e@news.povray.org>
> (near bottom)
How could I forget that!  I used to take my morning coffee and pick a random
link from his site to explore things you can do in POV-Ray and how to do them.
If I had gone back to this, I would have seen the "Orient your object in the +Z
axis" comment, instead of my trial and error that found I had to rotate the text
objects 90 degrees!
-- Chris R
Date: 10 Mar 2025 09:50:00
Message: <web.67ceed8d9216b80b3bc22bca25979125@news.povray.org>
> > (near bottom)
Because there is SO MUCH to take in, that eventually some information starts to
fall of the stack.
https://en.wikipedia.org/wiki/Dunbar%27s_number
And I'm sure that you've written enough code to have forgotten how the code you
wrote 3 days ago works, because it was _obvious_ at the time.  ;)
Glad you're having fun with POV-Ray and coding animations.  Sometimes we learn
new things in the process of revisiting and relearning old things.
And then we add those NEW lessons onto the stack!  :D
- BW
Date: 19 Mar 2025 02:25:16
Message: <67da634c$1@news.povray.org>
On 3/4/25 10:35, William F Pokorny wrote:
> I started looking at a yuqk version of documentation for the text{} object.
Playing with the thickness parameter.
I've always specified values >0, but it works with values at 0 and with
negative values. With the latter though, by intent or mistake, only
renders the front and back surfaces - and the interior exterior
treatments are interesting / different(*).
Iideally we'd have an 'open' capability with text{}, but the way the
negative thickness values are working allows us to somewhat easily add
front and back surface textures which are different than the text{} sides.
The images use an 'interior_texture{}' that is green for the "What the
heck" string. Only matters with the negative thickness on the third and
fourth sub images. The fourth also using 'inverse'.
Bill P.
(*) Jerome contributed fixes to v3.8 which stabilized the interior /
exterior surface treatments for text{} objects with +z thicknesses. This
means prior versions will behave differently.
Download 'textthicknessstory.png' (85 KB)
Preview of image 'textthicknessstory.png'
