POV-Ray : Newsgroups : povray.binaries.images : Other things the text object can do. Server Time
17 Jun 2025 16:06:39 EDT (-0400)
  Other things the text object can do. (Message 18 to 27 of 37)
Subject: Re: Other things the text object can do.
Date: 6 Mar 2025 10:30:00
Message: <web.67c9bf169216b80bd97b426e25979125@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> > Useless is being generous.  Search engines today are worse than useless.
> sort of agree, but perhaps your combined activity has caused Google "to wake up"
> :-), typing "ron parker font" in the above 'Search' shows the relevant result,
> top of list.
I just did exactly that, and that thread isn't on my list at all.
3 pages of results, and not one of them is the proper thread.
It has to do with cookies and all of this "tailored search results" BS
Wish I could use Yandex or some of the other ones from this computer.
We need a private search engine for the newsgroups!
- BW
Date: 6 Mar 2025 12:00:00
Message: <web.67c9d3769216b80bd97b426e25979125@news.povray.org>
I did find these though, which may be of related interest.
https://news.povray.org/povray.text.scene-files/thread/%3C4004808c%241%40news.povray.org%3E/?ttop=441451&toff=350
https://news.povray.org/povray.beta-test/thread/%3C3bd48bf6%40news.povray.org%3E/?ttop=441402&toff=1900
https://news.povray.org/povray.programming/thread/%3C38B18153.72BE%40aol.com%3E/?ttop=445029&toff=800&mtop=84879&moff=2
0
Date: 6 Mar 2025 13:50:00
Message: <web.67c9ed999216b80b17bac71e8ffb8ce3@news.povray.org>
The explanation in the last post of this thread is the interesting bit. Last
post:
https://news.povray.org/povray.beta-test/message/%3Cslrn9tdjuv.32q.ron.parker%40fwi.com%3E/#%3Cslrn9tdjuv.32q.ron.parke
r%40fwi.com%3E
ingo
Date: 6 Mar 2025 14:55:00
Message: <web.67c9fcb19216b80b33dbb0635cc1b6e@news.povray.org>
"Leroy" <whe### [at] gmailcom> wrote:
> "Chris R" <car### [at] comcastnet> wrote:
> > William F Pokorny <ano### [at] anonymousorg> wrote:
> > > Only tricky part is figuring out the base character size and spacing.
> > > I've not found an easy and reliable way to do that as yet. I got to the
> > > above values by trial and error.
> > > Used box characters for the rectangular frame using the strings:
"└───&#9
47
> 2;
> > ─────┘" and
"│││││││││&#9
47
> 4;
> > > Bill P.
> > If you are using a mono-type font, this worked for me:
> > #local _t1 = text { ttf "fontname.ttf" "A" 1.0, 0 }
> > #local _t2 = text { ttf "fontname.ttf" "AA" 1.0, 0 }
> > #local _t1sz = max_extent(_t1) - min_extent(_t1);
> > #local _t2sz = max_extent(_t2) - min_extent(_t2);
> > #local _unit_width = (_t2sz - _t1sz).x;
> > text { ttf "fontname.ttf" "What the heck?" 1.0, -2*unit_width*x }
> > text { ttf "fontname.ttf" "What the heck?" 1.0, <-unit_width, -1, 0> translate
> > <0, 14, 0> }
> > -- Chris R
> I remember this little trick. But I didn't want to be limited to  mono-type
> fonts so I wrote a macro that cut a string into pieces and place each letter
> separately. And promptly forgot about it.
Aah!  In the meantime, I went down a rabbit hole and essentially did the same
thing...
See: https://github.com/carath63/povlibrary
library/libtext.inc
Examples/text_test.pov
Here is an example of using that technique to lay out text around a cylinder, up
a helix, and following a spline.  The spline relies on how close your the
distance between letters lines up with the distance between spline points.  As
you can see, it didn't work very well once the letters moved around the front
curve of the spline.  Still trying to figure out how to fix that.
-- Chris R
Download 'text_test.png' (98 KB)
Preview of image 'text_test.png'
Date: 6 Mar 2025 15:35:00
Message: <web.67ca06699216b80b33dbb0635cc1b6e@news.povray.org>
#9
> 47
> > 2;
> > > ─────┘" and
#9
> 47
> > 4;
> > > > Bill P.
> > > <0, 14, 0> }
> > > -- Chris R
> thing...
> library/libtext.inc
> -- Chris R
To prove my spline layout code is correct, I created some tools for converting a
spline whose values have an arbitrary range into a spline whose values go from
0.0 to the computed length of the spline over the given range of values.  Using
a spline that has been tuned this way gave a much better result in laying out
the text.
-- Chris R
Download 'text_test.png' (85 KB)
Date: 6 Mar 2025 16:00:00
Message: <web.67ca0bc19216b80bd97b426e25979125@news.povray.org>
> the text.
are you aware that there are spline macros to do this sort of thing?
IIRC, they are in transforms.inc
- BW
Date: 7 Mar 2025 11:10:00
Message: <web.67cb194b9216b80b53fb81ab5cc1b6e@news.povray.org>
> > the text.
> - BW
I knew in the back of my head that I had used the Spline_Trans macro before, but
couldn't remember what it was called or where it was.  Thanks!
I'll probably create a new version of my Text Spline alignment macro and replace
my code for computing the rotations with this, which allow for banking the text
as well, which would be cool.
The macro still has to do the work of computing the offset based on the letter
spacing, and then using this macro to do the placement and orientation.  And I
haven't seen anything equivalent to the code I wrote to convert a Spline using
arbitrary values with a Spline that uses distances along the spline curve for
values, so I think that's still useful.
-- Chris R
Date: 7 Mar 2025 11:55:00
Message: <web.67cb24049216b80ba5a6be6925979125@news.povray.org>
I didn't have a lot of time when I was trying to find what I was looking for.
I think if you're able to locate (or someone can post a link to) Chris Colefax's
spline macros - my understanding is that there was all of that kind of stuff in
there as well.
I've never used any of these macros, and my memory tells me that the good macros
had something to do with a rollercoaster animation....
It's possible I might have some of these Colefax macros squirreled away
somewhere.
Won't have the opportunity to dig around for them and post until maybe Sunday.
We also really ought to have a thread where ALL of the Colefax macros are listed
and posted as attachments, and then they can be collected into a single zip so
that they aren't lost.
- BW
Date: 7 Mar 2025 13:40:00
Message: <web.67cb3ca29216b80b53fb81ab5cc1b6e@news.povray.org>
> > > the text.
> > - BW
> -- Chris R
Time to move on, but here's the previous image using the new macro using
Spline_Trans with a Banking value of 1.0.  I used a more interesting font as
well.  The banking is subtle, but you can see it on the downward curve around
the "good people" section.
-- Chris R
Download 'text_test.png' (95 KB)
Date: 7 Mar 2025 15:25:00
Message: <web.67cb55859216b80ba5a6be6925979125@news.povray.org>
Also, of course, Friedrich Lohmueller's site.
https://www.f-lohmueller.de/pov_tut/animate/pov_anie.htm
(near bottom)
