POV-Ray : Newsgroups : povray.binaries.images : Vase - Isosurface - MathMod Server Time
16 Apr 2026 15:30:43 EDT (-0400)
  Vase - Isosurface - MathMod (Message 1 to 6 of 6)
Subject: Vase - Isosurface - MathMod
Date: 9 Dec 2024 10:55:03
Message: <675712d7@news.povray.org>
Here, the result of the transcoding from MathMod to POVRay.
(see discussion in p.a-u).
kurtz le pirate
compagnie de la banquise
Download 'vase_iso.jpg' (219 KB)
Preview of image 'vase_iso.jpg'
Subject: Re: Vase - Isosurface - MathMod
Date: 9 Dec 2024 11:50:00
Message: <web.67571eb41965dde4a2cb7a7025979125@news.povray.org>
That came out great - and the stone texture is beautiful  :)
(At some point, if you aren't using your computer for anything for a while, an
HDR environment and SSLT in the stone texture would probably be fantastic.)
I think that I'd like to see the functions you used.
Normally when I translate between other forms and SDL, I write my SDL on the
top, and leave the original code as a long comment on the bottom.  Sometimes
I'll even just interleave the SDL with the original commented-out code so that I
can see what I'm doing line-pair by line-pair.
Great work, and I'm glad it all got straightened out.  :)
Thanks Tor, as always!
- BW
Date: 10 Dec 2024 05:32:45
Message: <675818cd$1@news.povray.org>
It's just the 'T_Stone20'
hum... SSLT is beyond my knowledge. I've never played with this option.
Text file attached here. Only the interesting part with functions.
No prettyprint, sorry.
Yes, Tor always adds his little grain of salt which helps a lot.
kurtz le pirate
Download 'mathmod_vase.txt' (5 KB)
Date: 11 Dec 2024 00:14:19
Message: <67591fab$1@news.povray.org>
Cool! :-)
Bill P.
Date: 20 Dec 2024 13:20:00
Message: <web.6765b5241965dde4e83955656e066e29@news.povray.org>
Wow, that is a beauty. And a really interesting use of isosurface functions.
I tried to follow your recent post about the function re-writing from MathMod,
but got hopelessly lost :-(  Very sophisticated! I need to re-read it...over and
over again, until it sinks into my poor brain...
Date: 21 Dec 2024 05:43:07
Message: <67669bbb$1@news.povray.org>
But no, it's not that difficult.
You just need to know a few tricks and have lot of patience...
* Replace the rise to power '^' by pow(a,b) or write explicitly a*a*a...
* A function is defined by its name and parameters.
   The current parameters (x,y,z) may not be written.
   #declare foo = function {...} is the same thing that
   #declare foo = function(x,y,z) {...}
* Check the number of parameters required by the function.
   N required -> N passed and N passed ->  N required.
* Mathmod often uses the 't' parameter. In the vast majority of cases,
   this parameter can be omitted. 't' is used for animation and/or
   morphing.
* Matmod lets you use 'if' in functions. POVRay doesn't.
   You have to replace it with a 'select()'. See TOK's more detailed
   explanations.
* Remember also that POV compares to zero in the 'select()'.
   In Matmod this is not always the case.
* In Matmod, declaration is sequential and a function can be redefined.
   In fact, the same 'function name' can be used several times.
   In POV, this is forbidden (and so much the better!).
* Don't forget the constants and the domains
Sample :
"Animated Bone Cage model by Abderrahman Taha 12/11/2020"
"P_Skeletal0=-y-z+(51/100)*(-x*y+y*z+z*x)+12/10"
-> Add '#declare' at the beginning, remove the quotation marks, add
    'function {' after the equal sign and at the end of the line.
    #declare P_Skeletal0 = function{ -y-z+(51/100)*(-x*y+y*z+z*x)+12/10 }
Then
"isoTransform=if((x-pi)*(x-pi)<(13),P_Skeletal(x,y-4*t,z-20*t,t),(1))+exp((x-pi)*(x-pi)-9)"
Which can be rewritten as :
"isoTransform = if (
   (x-pi)*(x-pi)<(13),
   (1)
We replace the 'if()' with a 'select()', paying attention to the
condition, which in this case is not relative to (zero) but to (13).
Resulting in :
#declare isoTransform = function {
   select (
     (x-pi)*(x-pi)-13, // A : condition with respect to 0
     P_Skeletal(x,y,z) // If A < 0
     1                 // Else (A >=0)
Note the deletion of the 't' parameter.
The hardest part is still adjusting the isosurface parameters:
contained_by, threshold, accuracy, max_gradient, ...
All this also works for the parametric part and the
parametric { } POV's object.
Have fun !!
kurtz le pirate
