POV-Ray : Newsgroups : povray.binaries.images : Playing with slope_map and normal accuracy Server Time
28 Jul 2026 00:47:18 EDT (-0400)
  Playing with slope_map and normal accuracy (Message 1 to 1 of 1)
Subject: Playing with slope_map and normal accuracy
Date: 27 Nov 2024 05:41:00
Message: <6746f73c$1@news.povray.org>
More playing around as I work on documentation. In the attached image
looking at slope_map{} in the yuqk fork. I believe all of the results
can be done accomplished in POV-Ray v3.8. too.
Using a scaled onion pattern with an ip_form of <1,0,1> and a
triangle_wave modifier - POV-Ray's wood without the need to rotate.
In the upper left duplicating a scene from the POV-Ray v3.8 documentation.
In the lower left trying the yuqk way to use the general value modifiers
within the normal block while also immediately chaining poly_wave.
      #declare Fn = function {
         pattern {  // This {} enables value modifiers
             onion
             ip_form <1,0,1>
             triangle_wave
             poly_wave 3
     cylinder {
         0, y, 4
         pigment { srgb <1, .9, .2> }
         finish { specular 1 }
         normal {
     #if (1)
             pigment_pattern { // This {} enables value modifiers
                 onion
                 ip_form <1,0,1>
                 triangle_wave
                 poly_wave 3
     #else
             function { Fn(x,y,z) }
             slope_map { SlopeMap00 }
           //slope_map { SlopeMap01 }
             bump_size 1.0
             accuracy 0.505 // Larger values are interesting...
In the right column changing to larger accuracy values from that in the
left column produces interesting results. A result of the pyramid of
four locations, value field, sampling method. Looks cool. :-)
Bill P.
Download 'slope_mapplay.jpg' (136 KB)
Preview of image 'slope_mapplay.jpg'
