POV-Ray : Newsgroups : povray.binaries.images : The third Poe-generated RSOCP script, still using the original prompt... Server Time
12 Sep 2025 20:23:32 EDT (-0400)
  The third Poe-generated RSOCP script, still using the original prompt... (Message 1 to 1 of 1)
Subject: The third Poe-generated RSOCP script, still using the original prompt...
Date: 26 Jul 2024 11:27:30
Message: <66a3c062@news.povray.org>
Hi(gh)!
...turned out to be faulty!
Now I in fact continued the original "chat" (and deleted the
accidentally started second one)... according to the (German writing!)
"Assistant" chat bot, Poe started to "improve" the scene, which means
elaborating it... but it got the pigment syntax for the plane wrong (at
least for POV-Ray 3.7 - I don't know whether it might work with 3.8) -
there can't be two pigment pattern types within the same pair of brackets!
// Camera
     location <0, 5, -10>
     look_at <0, 1, 0>
     angle 45
// Lighting
light_source { <-10, 20, -10> color rgb <1, 1, 1> }
sky_sphere {
     pigment { gradient <0, 1, 0>
               color_map {
                   [0.0 color rgb <0.5, 0.7, 1>]
                   [0.7 color rgb <0.2, 0.4, 0.8>]
// Plane
plane {
     y, 0
         bumps
         granite
         color_map {
             [0.0 color rgb <0.8, 0.8, 0.8>]
             [0.5 color rgb <0.6, 0.6, 0.6>]
             [1.0 color rgb <0.4, 0.4, 0.4>]
         scale 2
     normal {
         bumps
         frequency 5
         scale 0.1
// Sphere
sphere {
     <0, 1, 0>, 1
     finish {
         ambient 0.2
         diffuse 0.4
         specular 0.6
         roughness 0.05
         reflection {
             0.7
             fresnel true
         normal {
             granite
             scale 0.1
         pigment { color rgb <1, 1, 1> }
         finish { reflection 0.5 }
Also, the system doesn't seem to know that in POV-Ray (at least in 3.7 -
I still haven't tried out 3.8) normal is not a property within finish,
but on the same level as finish within texture...
By fixing this (removing "bump" and taking normal out of the finish
brackets) and then rendering, I got the scene attached here.
Strangely enough, having finish and normal outside the texture
statement, it still works!
Now this looks nice - but it starts to depart significantly from my
original prompt! Most likely, I from now on would generate two lines of
Poe-powered RSOCPs scenes: one following the continous "chat" with
constant "improvements" by the AI engine (however, without changing my
prompt!), the other one just using single-partite "chats" with the same
prompt over and over.
See you in Khyberspace!
Yadgar
VBI BENE, IBI BACTRIA!
Download 'poeray_rsocp_003.png' (540 KB)
Preview of image 'poeray_rsocp_003.png'
