POV-Ray : Newsgroups : povray.binaries.images : Heightfields of sediment layers Server Time
28 Jul 2026 09:18:23 EDT (-0400)
  Heightfields of sediment layers (Message 21 to 28 of 28)
Subject: Re: Heightfields of sediment layers - wip 1
Date: 9 Oct 2023 02:37:59
Message: <65239fc7@news.povray.org>
Op 08/10/2023 om 22:36 schreef Samuel B.:
> In the images you posted, I can't see individual height_field 'pixels,' but what
> I do see is diffuse light being reflected only at certain angles, similar to a
> 'toon shader. It's a general lack of smoothness that the smooth keyword can't
> touch... It's the same thing I've seen with free height maps found online.
I wonder if you do no interpret here the granite normals from the used
(complex) rock texture...? See below.
>>> I don't know exactly what your goals are, but can some things be done using
>>> pigment maps and/or functions?
>> Basically, I use the image_map within a height_field function, more or
>> less warped, and then sheared using a matrix.
> Ah, ok. There are ways of ditching the matrix shears and doing everything
> entirely with functions, but it would require somewhat extensive changes to the
> code. And the result would not be the same :/
Hmmm... I am not /that/ proficient with functions I am afraid, but it is
a way I certainly want to explore more in detail.
> I downloaded and rendered the scene. The result looks a lot smoother than the
> images you posted... Did you use a dilate operation on the height_map? It seems
> to have worked pretty well!
See above. As I did not change anything to the image_map, your comment
seems to partly confirm the 'normals' hypothesis... ;-)
[ex cathedra]
My playing with the warp {turbulence ...} had the interesting effect of
nicely simulating what is known as 'loading' in sedimentology:
alternating layers of unconsolidated, water-saturated, sediments
(sand/clay), for example in tidal basins with a high sediment input.
Differential compaction of those sediments may generate 'loading'
deformation of the coarser sediments into the finer ones. Earthquakes
can generate those same features by 'liquefying' soft sediments.
[/ex cathedra]
> Btw, 'CamZoom' doesn't seem to do anything. Changing the camera's angle to this
> makes it work: CamAng/CamZoom
I know. CamZoom is just there in case it is needed. It is in fact a
relict from another scene I didn't bother to ditch. :-)
Date: 11 Oct 2023 07:50:07
Message: <65268bef$1@news.povray.org>
Op 9-10-2023 om 08:37 schreef Thomas de Groot:
>> angle to this
Just for completeness sake, I checked; it originally came from the
original iso2pov scene codes by Jaime. I do not remember having checked
its correct working...
Date: 11 Oct 2023 18:45:00
Message: <web.652724548839199f16bed5696e741498@news.povray.org>
> > [...] It's a general lack of smoothness [...]
Yeah, it's quite possible. Also, other differences in shading, colors and aa
could have something to do with my perception of things.
> [ex cathedra]
> [/ex cathedra]
It's very fascinating. I'm sure the layers could tell you a lot about the makeup
and history of the surrounding landscape... And I bet one could find heavier
minerals at the bottoms of various basins, given enough disturbance of the
sediments during and after deposition. Gold, if present, will of course settle
toward the bottoms of things, but other stuff is sure to settle in as well. Many
precious & semi-precious gems (ruby, garnet, etc.) are denser than other
minerals. In fact, there's a local creek where small red garnets can be found
alongside gold, provided the panning step isn't done too aggressively.
> [>] Just for completeness sake, I checked; it originally came from the
Its funny how various bits of code tend to collect and deposit themselves in our
scenes over time :D
Sam
Date: 12 Oct 2023 02:43:31
Message: <65279593$1@news.povray.org>
Op 12/10/2023 om 00:40 schreef Samuel B.:
...which still does not preclude your initial comment obviously. It is
something I have not been consciously aware of enough.
As a side track to the subject, I am playing also with height field maps
generated by GeoControl (*.tga). It also provides normal maps (the
well-known bluish maps) and greyscale maps, both as *.bpm. I want to
explore if I can usefully add the normal maps to my height fields. It
looks like it does.
>> [ex cathedra]
>> [/ex cathedra]
Indeed. However, it all depends on the availability (far of or nearby)
of source rocks containing or having contained such minerals, as the
concentrations of gold or heavy minerals (placers!) are the results of
erosion and then winnowing by streams and other such processes. Even the
wind can play that role in desert environments. So yes, knowing
something about the local geology can be very useful.
> scenes over time :D
There it is! Erosion and sedimentation in action! :-)
Date: 14 Oct 2023 18:00:00
Message: <web.652b0ea38839199f16bed5696e741498@news.povray.org>
> looks like it does.
What would the normal maps be useful for, I wonder? We can only change surface
normals via the normal{} block, so any other things for which we would use
normal maps can already be done with slope maps... There's functions I guess,
since I don't think we can use regular slope maps in those... so having a normal
map from another program might be useful there.
> >> [ex cathedra]
> >> nicely simulating what is known as 'loading' in sedimentology [...]
> > and history of the surrounding landscape [...]
Yeah, I think you could find out things about an area that are not otherwise
easily deduced by just studying the nearby bedrock. For instance (and I might've
mentioned this before), but around here there can be found a mineral called
sillimanite. Not only does it impart quartz with a neat opalaescent appearance,
but it can also be use as a gauge, indicating the specific range of temperatures
local minerals formed under at some point in the past. (And that's the extent of
my knowledge regarding the subject ;P)
Sam
Date: 15 Oct 2023 07:41:39
Message: <652bcff3$1@news.povray.org>
Op 14-10-2023 om 23:56 schreef Samuel B.:
>> looks like it does.
I explored its use out of curiosity. I agree with you about their
usefulness: it is limited.
>>>> [ex cathedra]
Sillimanite... reminds me of mineral microscopy in my student's years,
especially because it was so easy to recognise at first sight! :-)
Date: 16 Oct 2023 18:28:55
Message: <652db927$1@news.povray.org>
On 06/10/2023 14:46, Thomas de Groot wrote:
> I may be dim... can you explain?
The scene reminds me of those in western movies or comics where bandits
are planning a big train robbery.
The grazing light places a lot of emphasis on the sedimentary rock, and
it seems as if the cowboy is telling others to climb it to observe from
above.
Paolo
Date: 17 Oct 2023 02:07:27
Message: <652e249f$1@news.povray.org>
Op 17/10/2023 om 00:28 schreef Paolo Gibellini:
> above.
Lol! You are perfectly right indeed! I was too much focussed on the
doggy being trained to climb rocks. :-)
