POV-Ray : Newsgroups : povray.binaries.images : What about repeat and offset with image / bump maps? Server Time
27 Sep 2024 07:25:02 EDT (-0400)
  What about repeat and offset with image / bump maps? (Message 1 to 9 of 9)
Subject: What about repeat and offset with image / bump maps?
Date: 2 Mar 2023 18:19:37
Message: <64012f09@news.povray.org>
As we were playing around with image_maps and height_fields, I was
reminded there is support for the keywords 'repeat' and 'offset' in the
image_map and bump_map code.
These look useful to me in that they can accomplish what we usually do
with scale and translate, without an actual transform. Anyone know why
they are, since v3.7 at least, hidden from users? Or have I again missed
some documentation?
Attached an image with traditional 'once' map on the left. In the middle
using repeat <2,2> (how many/much in 1x1) and offset <0.5,0.5>
(accounting for 2x repeats in 1x1).
On the right we go with repeat <3,3> only and add in the two repeat/flip
tiling warps. I don't believe we can as easily accomplish this kind of
tiling effect another way.
Aside: Those image_map repeat values can be any non integral positive
(>0) float too.
Bill P.
#declare Pigment00 = pigment {
     image_map { "p189crop.jpg"
         repeat <2,2>
         offset <0.5,0.5>
         map_type 0
         once
         interpolate 2
   //warp { repeat x flip x }
   //warp { repeat y flip y }
Download 'imap_repeat_offset.png' (457 KB)
Preview of image 'imap_repeat_offset.png'
Subject: Re: What about repeat and offset with image / bump maps?
Date: 3 Mar 2023 02:05:00
Message: <web.64019b999e80f4689b4924336e066e29@news.povray.org>
They're still there in v3.8, in the docs at "3.6.2.5.5 Warp"
I remembered 'repeat' and 'offset', but not 'flip'.
The  middle image shows only one smaller image_map; should there be two instead?
I just tried this warp {repeat...} stuff on the function height_fields that
we've been discussing recently-- to try another way to eliminate the 'mirror
flipping in z' of the HF result. It WORKS! (with a certain configuration of the
warp items that's not yet understandable to me)-- and successfully takes the
place of the (1-y) fix that's required when the function is used later. The same
warp construction works for BOTH an image_map-to-function-to-HF, as well as
typical patterns like 'onion' and granite' (the only patterns I've tested so
far). Thanks for suggesting this; now we have *multiple* ways to fix the HF
mirroring flaw.
Example 1:
#declare somb =
function{
     pigment{
         image_map{png "...MY_IMAGE..." once}
         warp{repeat -y offset -y flip -y} // OR warp{repeat -x flip y}
Example 2:
#declare somb =
function{
     pigment{
         granite scale 2
Date: 3 Mar 2023 05:47:23
Message: <6401d03b$1@news.povray.org>
The warp's repeat, offset and flip are handy, but the repeat and offset
keywords and code in the image_map and bump_map are not related except,
more than a bit, conceptually.
I'll have to play though with negative values with those three in warps
- never tried it. (What does THIS button do!) :-)
Bill P.
Date: 4 Mar 2023 07:49:10
Message: <64033e46$1@news.povray.org>
Op 3-3-2023 om 00:19 schreef William F Pokorny:
>          repeat <2,2>
>          offset <0.5,0.5>
>          map_type 0
>          once
>          interpolate 2
Interesting stuff I need to look into. As a reminder maybe: adding gamma
1 to the image_map is still essential and makes a difference whether you
use it or not
   image_map { "p189crop.jpg" gamma 1
Date: 4 Mar 2023 22:50:14
Message: <64041176$1@news.povray.org>
On 3/4/23 07:49, Thomas de Groot wrote:
> adding gamma 1 to the image_map is still essential and makes a
> difference whether you use it or not
The latter part about it making a difference can certainly be true.
It only needs to be 'gamma 1', if the file was created in a linear color
space(a). The default output and input is 'gamma srgb' in v3.8/v4.0 -
excepting hdri file formats at 'gamma 1' and netpbm formats which use
'gamma bt709' by default(b).
The above a lie, if you want to use odd file gammas for effect. You can,
for example, specify a 'gamma <value>' and stick whatever you want in
there for a positive value.
That said. Practically, it's true the majority of the image files coming
from models we pick up somewhere out and about are written in the linear
color space. For those you do need to always use 'gamma 1' because they
were written with the expectation they'd be read as 'gamma 1' files.
Bill P.
--- More detail...
(a) - There was/is a bug in the v3.8/v4.0 branches were png files were
being written without the srgb block unless the render was invoked with
file_gamma=srgb. It's fixed in povr, I do not know the current status in
v3.8 beta 2 or v4.0 master. The block is something you can see - or not
- by editing a png file. Amongst the gibberish, look for the text 'sRGB'
almost immediately following 'gAMA' near the top. If you see it, you
have the sRGB block.
If you don't see and are using v3.8/v4.0 defaults you should code 'gamma
srgb' while reading / using such POV-Ray created pngs. And/or be sure to
use file_gamma=srgb on writing pngs.
(b) - Yes, there was another bug POV-ray v3.8/v4.0 which is patched in
povr for netpbm file formats of .ppm and .pgm. The gamma wasn't
defaulting properly on write or read - I cannot remember which at the
moment.
Aside: With both (a) & (b) bugs, the reality is you might see the
differences or not depending on stuff. Ignorance is bliss until the
truck runs you over. A lot of truth too in, "if it looks good, it is
good."
A test I sometimes run is to write file formats from povr, then
immediately read that file back in sort of a SDL povr/POV-Ray image
display tool where I again write the image file using a different name
from the first written. I now have two files I can compare image to
image which should be very near identical. Once in a while they're not.
Date: 5 Mar 2023 02:36:59
Message: <6404469b$1@news.povray.org>
Ah! Thanks for the reminder of these details indeed. I seem to recall
that Christoph mentioned these long ago... I use v3.8 beta 2 as a rule
and I think it is not different on these matters. Poseray conversions
from Poser files standard adds gamma srgb to the image_maps and gamma 1
to the bump_maps.
Date: 5 Mar 2023 15:45:00
Message: <web.6404fe719e80f4689b4924336e066e29@news.povray.org>
> space(a).
I'm wondering if you meant 'non-linear' there? I certainly don't want to get
into THAT 'can of worms' again re: linear-vs-non-linear (painful memories of
Ive's reaction in the distant past, ha.) It's just that, in my own way of
thinking, an image from the internet that is typically encoded(??) with a gamma
of 2.2 or sRGB is what I call non-linear (rightly or wrongly.) And when used for
a height_field in POV-ray, it needs 'gamma 1' added, to reconstruct the intended
linear nature of the image's brightness values-- so that we get a nice linear HF
slope from the black-to-white brightness values.
Maybe this is just my own screwy way of describing the situation, in a way that
makes sense only to me.
Yes! Some interesting effects can be achieved that way, with height_fields at
least. There is actually no imposed limit to the value.
> color space.
non-linear? :-D (see pedantic explanation above)
Date: 5 Mar 2023 17:36:22
Message: <64051966$1@news.povray.org>
On 3/5/23 15:41, Kenneth wrote:
Linear(c).
For the typical jpeg and png formats on the web, yes.
> And when used for
Maybe, kinda.
Unless mangling the image file for effect(b), you want to read the image
file with the same gamma correction(a) used when it was created to get
again the same, internal, linear rgb values that existed prior to the
image being written.
There is no 're-construction' when using a gamma correction of 1.0. At
'gamma 1.0' you are reading (or writing) the image doing no gamma
correction(a) at all. The values internal to the image file are directly
transferred to POV-Ray's internal, linear rgb space - whether they were
written to the image file with gamma correction or not.
Again. The up front rule is to read image files using the same gamma as
was used when they were written/created(b).
Bill P.
(a) - Where the gammas involved are other than 1, on image read/input we
are actually applying the inverse gamma correction to that used during
write to get back to the linear, rgb space internal to POV-Ray.
(b) - Other than mangling for effect, there is one other time you might
want to apply the 'preview display gamma' correction on an image read...
Suppose you've written an image file from POV-Ray with file_gamma=1.0.
When you view this file with whatever viewing tool outside of POV-Ray it
will appear darker than it appeared in POV-Ray's preview window. POV-Ray
gamma corrects with the display gamma setting prior to preview as it
would correct prior to writing to a file using the file_gamma value.
If you want to see this image in POV-Ray's preview window in the same
way other image viewers will display it, you need to apply the display
window's gamma correction (the default is srgb) during the image
read/input. What we are really doing is applying the inverse gamma srgb
to an as written linear gamma file - so the forward, srgb, preview
window gamma correction ends up back in the linear color space as you
preview it in POV-Ray... :-)
(c) - For what happens typically with respect to images used with 3d
models, it's just my impression from a relatively limited set of
personal experiences. I've certainly not done an exhaustive survey! ;-)
Date: 5 Mar 2023 18:25:00
Message: <web.640523579e80f4689b4924336e066e29@news.povray.org>
> Linear(c).
I thank you for your gentle explanation. ;-)  I intend to read and re-read it,
until it hopefully sinks in.
I don't know what my trouble is with this particular subject, but I have the
most *difficult* time in trying to reconcile my 'viewpoint' with the actual
FACTS as you have laid them out (and probably Ive as well, I hate to admit...
in-between his rantings!) At *some* point, I surely hope that a light-bulb
finally turns on in my head and I see the error of my ways.
Currently, my own theory makes sense to me-- flawed as it is-- and so far, I
have not run into a 'paradigm-shifting' situation when rendering scenes in
POV-ray. But it irks me greatly that my way of perceiving this subject is not...
right.
I continue thinking about it! ...
