|  |  | This is my latest update to a rusted chrome sphere I first created in
2004; a 2006 update is posted at:
https://news.povray.org/web.523a47261b23139d306548240@news.povray.org
I took Thomas' advice in that thread and updated the texture normal.
The change quadrupled the render time.
Here is the texture used on the sphere.  Note that the final texture
adds an additional turbulence to the rust texture.
----------[BEGIN CODE EXCERPT]---------
#include "rc3metal.inc" // https://github.com/CousinRicky/POV-RC3Metal
#declare c_Chrome = rgb <0.50, 0.51, 0.55>;
#declare c_Rust1 = rgb <0.17, 0.07, 0.06>;
#declare c_Rust2 = rgb <0.30, 0.10, 0.04>;
#declare c_Rust3 = rgb <0.60, 0.24, 0.03>;
#declare RC3M_Diffuse = [your #default diffuse value];
#declare RC3M_Ambient = [your #default ambient value];
RC3Metal_Set_highlight (0)
#declare t_Chrome = RC3Metal_Texture (c_Chrome, 1.0, 0.5)
#declare t_Buckled_chrome = texture
{ RC3Metal (c_Chrome, 0.5, 0.5)
  normal { bumps 0.3 scale 0.1 }
#declare t_Rust = texture
{ pigment
  { bozo color_map
    { [0.00 c_Rust1]
      [0.20 c_Rust1]
      [0.62 c_Rust2]
      [0.72 c_Rust3]
      [1.00 c_Rust3]
    scale 0.18
  normal
  { agate 0.8
    warp { turbulence 0.5 octaves 3 lambda 3 omega 0.9 }
#declare t_Rusted_chrome = texture
{ bozo texture_map
  { [0.43 t_Chrome]
    [0.53 t_Buckled_chrome]
    [0.53 t_Rust]
  turbulence 0.7
  scale 0.2
-----------[END CODE EXCERPT]----------
 Download 'rusty_ball-2022-1080.jpg' (388 KB)
 Preview of image 'rusty_ball-2022-1080.jpg'
Actually, more than that.  Before the change I used single-pass radiosity; with
the new texture, it was taking so long that I aborted and used two-pass
radiosity. Post a reply to this message
|  |  | I really like this, especially the wrinkled effect aound the edges of the rust
patches - it makes it look like a chromed coating flaking off rather than a
rusty metal ball.
If I had one criticism, it would be that that rust 'swirls' follow the shape of
the patches, which I'm not sure is realistic. I might have tried to make the
rust texture more finely grained, and disconnected from the patch shapes.
Bill
I'd love to do that, but I haven't yet worked out how to warp a texture
map without having the constituent textures warped as well.
You could declare the chrome/buckled/rust pattern up front, then apply the
texture map at point of use. That way the warp gets applied before the map. Like
this:
#declare RustFn = function
{ pigment
  { bozo
    color_map { [0 rgb 0] [1 rgb 1] }
    turbulence 0.7
    scale 0.2
{ function { RustFn(x, y, z).x }
  texture_map
  { [0.43 t_Chrome]
    [0.53 t_Rust scale 0.1]
(That last scale 0.1 on the rust was me trying to make it more fine-grained. Not
sure if it's any better offhand)
Bill Post a reply to this message
> this:
> { pigment
>   { bozo
>     turbulence 0.7
>     scale 0.2
> [snip]
Thanks!  Here's the updated texture:
#declare c_Rust2 = rgb <0.30, 0.08, 0.05>;
#declare c_Rust3 = rgb <0.60, 0.22, 0.04>;
{ pigment
  { bozo color_map
  normal
  { agate 0.8
    warp { turbulence 0.5 octaves 4 lambda 2.7 omega 0.9 }
    scale 0.8
#declare t_Chrome_transition = texture
{ bozo texture_map
  { [0.43 t_Chrome]
  warp { turbulence 0.7 }
#declare fn_Rust = function
{ pigment
  { bozo
{ function { fn_Rust (x, y, z).x }
  texture_map
  { [0.53 t_Chrome_transition]
    [0.53 t_Rust]
  scale 0.2
-----------[END CODE EXCERPT]---------- Post a reply to this message
 Download 'rusty_ball-2022-1080.jpg' (378 KB)
