"jr" <cre### [at] gmailcom> wrote:
> - keeping "image and the code" in one place, along with the includes, bg
> image(s) etc, would be ideal. a project oriented approach. and zip would be a
> good format.
> - hate the idea/concept of "allow for editing, and re-save into the image file
> wrapper". if anything the other way round, keep everything plain human-readable
> text and include image(s) and other binary content 'base64' encoded.
> anyway, thanks, have a clearer picture now of the "silly idea".
I'm not sure I care too much exactly how it gets implemented. I was under the
impression that opening such an image file with a hex editor would result in the
text part looking like --- plain text. It's not like plain text is "special" -
it all has to get displayed on the screen by something that interprets the ASCII
values anyway. At least that's the way it works in my head.
What about:
http://textbundle.org/
https://www.macsparky.com/blog/2014/11/the-textbundle-format/
I posted about this idea a while back - there was some other file format that
sort of acted like concatenated text files.... maybe it was a 'nix format...
I can't remember.
> > It might also be possible to implement security by obscurity, to protect certain
> > parts of code that an author might not want users casually messing with. If you
> > really wanted to edit that code, you'd have to work for it, rather than just
> > "Ooops! I broke it!"
> also not keen on this. if an author feels .. so strongly, well, then don't
> publish. simples.
Right, but the idea is just to make the code available and usable, but not right
there in the editor where it can easily be inadvertently corrupted. I often
write spreadsheets with "locked" cells - but the password is sitting right there
in a documentation tab in case someone wants to edit it in the future. But in
daily use, they can't get messed up by accident, which is easy to do.
I would like a project-oriented format/editor. Open the project, and the main
file is in the first tab (Maybe the second, if there's a documentation tab) and
the includes and image files are available in other tabs.
OpenOffice allows use of hyperlinks in the spreadsheet, which I've used to
navigate around a sheet or between tabs. It would be cool to specify image
filenames, and be able to click on those and get a preview, then "go back" and
edit the SDL. Working on some code and need to find out what some value an
Lvalue has? Click it and you jump back to the last #declare for that Lvalue.
But I think just starting off with the basic bundle idea would solve a lot of
organizational and archival issues.
> > But binary copy, hexdump, Tcp, and other tools might provide a sort of
> > functional work-around / proof of concept to see how a suite of files could
> > potentially be used ....
> why binary anyway? what's wrong with a plain text (or utf8) encoding?
How do you keep the different text/SDL files separate, and maybe even package
images for mapping together? Isn't a zip a binary format?
Le 2022-03-01 à 12:06, kurtz le pirate a écrit :
> Really funny !
> <https://en.wikipedia.org/wiki/Steganography>
We see some obvious example of that in MANY movies from the 1950's to
1980's when someone use some aperture mask to reveal a hidden message in
a letter.
I've seen at least one movie where we see a character actually writing
such a message.
hi,
> > good format.
I suggested 'hexdump' because it is "safe", ie no stray control characters to
mess with yr terminal/console. for comfortable viewing one could use
'png::getComments', or even simply:
$ strings -n7 foo.png | less
> What about:
see below.
> I can't remember.
unsure. are you thinking of "literate programming"? cf Knuth.
> > > parts of code that an author might not want users casually messing with. ...
> > publish. simples.
sure. use a viewer like 'less' and only invoke the editor (by pressing 'v')
when intending to edit. something like an .inc or other data one could make
read-only.
though not using it at present, isn't that much like 'qtpovray's interface?
yes. think 'fossil'. seriously. as long as the project is a single directory
tree, that will address half of your needs. (g)vim and a 'tags' file for
navigation will provide the other half.
and each fossil "repository" is a single file too, ie the same convenience
handling/backing up.
regards, jr.
Subject: Re: A quick povr branch micro normal image.
Date: 2 Mar 2022 07:56:13
Message: <621f696d$1@news.povray.org>
On 3/1/22 07:55, jr wrote:
> hi,
> William F Pokorny <ano### [at] anonymousorg> wrote:
>> What particular commands and versions of TCL and Tcllib are you using?
> (typed)
> % set tcl_version
> 8.6
> % package require crc32
> % package require png
> % png::addComment foo.png theTag theValue
> and using a 'tcllib1.18' (though mean to upgrade to 1.19).
Thanks.
Forgot TCL breaks the patch level out... What does the shell command:
echo 'puts [info patchlevel];exit 0' | tclsh
give you?
>> It's been maybe 4-5 years since I played in the tcl/png sandbox but, not
>> too long after tcl 8.6 was first released, I found the png support from
>> within tcl/tk/tcllib buggy. Supposing you are finding it better?
> guess so, cannot recall any problem(s) with 'image' and 'photo' etc.
>> I was primarily trying to load/create/modify/save actual image channel
>> data but, I don't recall even the particular 'TCL' packages and commands
>> I tried at the moment...
> fwiw 'df3util' can split PNGs into rgba (and stored in a DF3, but there's the
> 'export' command).
Thanks for the reminder. At the time I was aiming for a set of new
commands in my TCL SDL wrapper.
Aside: I found out at some point the netpbm pam RGBA format is, less the
short pam header and the addition of a short DF3 header, an exactly DF3
equivalent file layer/plane. This means you can create / manipulate DF3s
quickly with that tool set too.
> hope to post a 'compare(1)' image in the next days, showing some/much difference
> for the sphere_sweep between 'povr' and stock POV-Ray. will need to
> systematically try with 'sturm' and 'tolerance' etc first though.
I'm interested in the results you see from compare. I'm not a big
imagemagick user.
--- sphere_sweep...
The povr sphere_sweep is substantially different in implementation being
one of the shapes which leans on the generic inbuilt solvers. I did a
large amount of work on those solvers some years ago.
There are at least a dozen numerical and control issues in that shape
alone in POV-Ray proper. Much fixed or made much better in povr - but
issues remain. Ultimately, I believe the code for sphere_sweeps needs to
be completely re-written!
With sphere_sweep 'tolerance' my recollection is it does nothing in povr
because in POV-Ray proper results are unstable due - another half dozen
reasons.
First up, being the sphere_sweep is one our shapes where transforms get
flattened (removed) if possible to improve performance. However, you
cannot always flatten depending upon the particular transforms. This
means the 'numerical meaning' of the 'tolerance' values (also things
like no_bump_scale) are not themselves stable depending upon user scene
transformations. Yep, this might be why the tolerance value was brought
out as a control originally.
...And sturm...
In official POV-Ray releases, across many shapes, you are not always
truly turning the sturm based solver on and off!
IIRC. The sphere_sweep sturm is always on internally (the polynomial
orders are beyond 4) - excepting linear sweeps where it's hard coded
always off (an unfortunate choice).
There's a general issue in official POV-Ray where, for auxiliary
internal polynomials (ie inside tests), POV-Ray isn't changing to a
sturm solver in a way aligned with the mainstream ray-surface solvers
for some shapes - and sphere_sweep is one. Probably done for better
performance too or, maybe believing the fixed solvers are 'always' the
better choice. In any case, mixing solver approaches is not the best for
'numerical alignment.'
In general! With povr, sturm off always uses a fixed solver where
polynomial order allows it. Where sturm on, povr's version of the sturm
solver is always used or, if the order is >4 'sturm on' will sometimes -
as with sphere_sweeps(1) - mean use a 'better' sturm based solver.
(1) IIRC. It's currently doing order reduction after each root is found.
The takeaway is sturm behavior in sphere_sweeps is mostly fixed in
official POV-Ray. In povr 'sturm on' always means "use a better sturm
based solver."
Encyclopedia sets worth of detail when you get into the solvers... My
head spins round and round! :-(
Bill P.
hi,
> > % set tcl_version
> > 8.6
> Thanks.
> give you?
8.6.5 (also have a 8.6.1 still).
interesting, thanks.
> imagemagick user.
will need a couple of days or so. read about sturm + sphere_sweep in
'revisions.txt', hence wanting to re-run + try things first.
@Cousin
the included-with-the-os Pinball was my .. vice, in the 3.11 heydays. :-)
regards, jr.
hi,
> imagemagick user.
unarchiving the attached will create a (sub)directory 'wfp' (;-)) with a bunch
of files. check the assumptions made (eg povray == stock POV-Ray) in the
'run-sh' file, then run that, ie 'sh run_sh', to render the images. the compare
output will be in sub-dir 'c'. cheers.
regards, jr.
Download 'sweep.tar.xz.dat' (2 KB)
forgot to say, using alpha.9945627 and most recent povr.
> > imagemagick user.
same here, rarely need/use them, except 'identify'. woke early, so made this.
regards, jr.
Download 'wfp_cmp.png' (69 KB)
Preview of image 'wfp_cmp.png'
Date: 5 Mar 2022 05:45:54
Message: <62233f62$1@news.povray.org>
>>> imagemagick user.
> regards, jr.
Somewhat busy with real life at the moment, but I did run your code
yesterday evening and saw more or less what you just posted.
I won't be able to do more until later today at best, but the short of it:
- Where you set up sphere_sweeps with orthographic cameras (or rays say
due parallel lights) is a worst case set up for sphere_sweeps because
the initial ray-'virtual-surface' polynomial collapses to duplicate
roots (at least it would always if we had infinite floating point accuracy).
- The above situation means you must use 'sturm' with the povr branch
because povr's general solvers are all a lot more accurate(a) than the
official POV-Ray solvers. :-) The detailed explanation is long...
- The color shift (the pink compare result) I'm pretty sure is due the
povr fork restoring the sRGB block to png outputs. The sRGB block got
dropped - due complicated reasons I forget at the moment - at some point
during v3.71/v3.8 development. The sRGB png block is there in v3.7 png
output and in recent povr(b) tarballs. My compares with netpbm - which
default to bt709 gamma handling for both file outputs - show no color
shift. There are other ways to test the png being missing being the
reason for the pink 'compare(c,d)' result, but not done it and not sure
I will.
Bill P.
(a) - The banding with linear sweeps (quadratic) comes from the povr
default being the common quadratic solver which - like POV-Ray's version
- has been hacked to return only one root on getting duplicate roots
where it doesn't by numerical noise see or force two - and this happens
in numerical bands with povr's more accurate quadratic solver. Where the
less capable povr sturm solver used (povr's sturm off with >4 orders) we
now get speckled results for similar, the solver is more accurate,
reasons. (The duplicate roots are blinking in and out ray to ray)
(b) - Bring both your v3.8 and povr png files up in an editor and you'll
see the text near the top 'sRGB' in povr (and v3.7) output. This test is
missing in any more recent v3.8/v4.0 output.
(c) - Like the netpbm tooling there are probably ways to explicitly
control gamma handling. Output and compare jpgs. Write linear output
files and compare via linear gamma options...
(d) - Yes. Even if the sRGB block being there and not the 'reason' for
the pink shift - how are we getting the grey-ish general background
where both input images are completely black? My first guess is the
actual pink/grey shift is a bug in 'compare' but, who knows. It might be
some other reason like compare showing differences in value results as
offsets from 50% grey or something, though the red differences within
the sphere sweep I think right! (alpha channel assumptions in compare
or?) No clue.
Date: 6 Mar 2022 06:32:36
Message: <62249bd4$1@news.povray.org>
> or?) No clue.
OK. Still busy with other things, but had the bright idea to compare an
image with itself and see what 'compare' does when images match. It's
not doing a strict difference compare on the channel values (as you
probably know). In other words, it always creates a faded image where
things compare.
Further figured out it's using a high light color where things don't
compare (to some threshold maybe? Per channel? Grey Composite?) and this
happens to default to red. This why the missing red differences are
showing up as I happen to expect the channel differences to show up on a
channel difference compare.
So, compare fine for what it does. In fact, it looks to have some cool
options and relatively easy defaults. It just isn't doing what I
expected for image comparisons.
Bill P.
hi,
if you ever recall why, please tell. now that I know about it, I do wonder what
the rationale/potential benefit is when the chunk is not written.
(sorry about red-red colour clash) the excellent documentation
('/usr/doc/ImageMagick-6/www/' on my box) uses '#rrggbb' notation but you can
use the the X ('rgb.txt') colour names (like!). re the faded image, if you
supply both lowlight and highlight colour options only the actual differences
show.
somewhat unrelated, I cannot understand why the difference in Y-axis translates,
is this a POV-Ray bug? (attached, thank you)
regards, jr.
Download 'xlates.tar.xz.dat' (2 KB)
