https://boneyard.pythonanywhere.com/360/360.htm
Original images from here:
https://publicdomainreview.org/collection/solid-objects
m@
At that webpage, all I see is a blank white screen :-(
[Running latest Firefox in Windows]
You might have to give it a minute or two - It's a large .png file.
m@
> m@
Large, but impressive.
hi,
fwiw, a tale of two Chromes. Chrome on Chromebook, the page opens with white
bg, then the image appears + all works. Chrome on Android, the page opens with
a black bg, and remains black, no image, nada (even given sufficient time).
regards, jr.
On 17/11/2021 2:59 pm, jr wrote:
> hi,
> regards, jr.
Thanks for the feedback jr and Kenneth.
I tested it on 3 different browsers and found no problem. The fact that
you get a blank white screen while loading a definite negative.
I am using A-Frame <https://aframe.io/> to display the panorama.
Possibly the fact that it needs Java may be the problem?
m@
Op 13/11/2021 om 08:10 schreef m@b:
I forgot to comment. (1) I do not have the loading problem mentioned by
others. It opened within a couple of seconds. (2) Again, an intriguing
discovery of ancient texts/illustrations. Well done indeed. I guess some
of them were harder to model than others, the lute for example.
Indeed - the lute was completed over several days, some of the models
took less than 30 minutes.
Some of the illustrations look simple but are deceptively hard to model
in POV_Ray. i gave up on at least one!
m@
Op 19-11-2021 om 08:46 schreef m@b:
>> by others. It opened within a couple of seconds. (2) Again, an
>> intriguing discovery of ancient texts/illustrations. Well done indeed.
>> I guess some of them were harder to model than others, the lute for
>> example.
Yes, I can certainly understand that indeed. Keep up the good work!
Hi(gh)!
Same with me... running Firefox 94.0.1 (64-bit) under Debian "Bull's
Eye" 11!
See you in Khyberspace!
Yadgar
Now playing: Round Again (Moving Pictures)
