![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 06/11/2021 om 01:01 schreef Samuel B.:
> Thomas de Groot <tho### [at] degroot org> wrote:
>> Latest, less inclusions, and slightly more concentrated and de-centered.
> It looks decent!
> I've got a bunch of ideas, but I need to find the proper motivation to implement
> them :/
> Only thing I want to suggest at this point is to maybe situate the light_source
> &/ sky_sphere so that it casts a highlight off either an outside or inside
> surface.
> Sam
Yes, I am fairly content. For now, I shall switch to other tasks and sit
back. :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Op 09/11/2021 om 20:02 schreef Kenneth:
> > BTW, I did not realize that an object with ior could have inclusions (other
> > objects) with *different* ior's-- I thought such constructs would be an example
> > of 'variable' ior within an object, which cannot be accomplished in POV-ray,
> > AFAIU. I had a mistaken notion that the camera ray would 'see' the outer object
> > surface first, (...)
> To tell the truth, I really do not know /how/ the different ior's are
> treated together. Afaik, this is not explained in the wiki pages. To
> keep on the safe side, I kept the inclusion's ior at 1.0 which is
> cheating of course, but at least I was not confronted to strange
> effects.
If I'm not mistaken, a ray evaluates all objects and their iors along its path
and changes its trajectory accordingly. So in a union, it is not really
'cheating' to have objects with an ior of 1 inside. They are treated as air
until the ray moves on. It's a reasonable alternative to using a difference
which - while not requiring objects with different iors - is very slow to trace.
Oh, and a while back, I found out that if you want to pretend that the camera is
inside some volume, say water, and you want to see air bubbles in that volume,
then for the air bubbles you would use the reciprocal of water's ior. So, the
bubbles would have an ior of 1/1.325, iinm.
Sam
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> effects.
> Sam
If you want to use a difference, then, you should use a blob instead of
100' to 1000's of spheres.
That way, you benefit from the blob's hierarchy and internal bounding
mechanism.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Alain Martel <kua### [at] videotron ca> wrote:
> > (...) It's a reasonable alternative to using a difference
> mechanism.
Blobs! I completely forgot about that option. And based on some experiments I
made once, I'd say you're probably right about the their higher rendering speed.
Yeah, I can see the benefit to using blobs to make air/fluid inclusions, and
then maybe applying a facets normal with metric 1 and maybe form <1, 0, 0>. This
way the clouds would refract/reflect light at certain angles only, thus giving a
more crystalline appearance. Hmm...
Sam
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
trace.
> > > mechanism.
> > Blobs! I completely forgot about that option. (...)
> Blobs, of course! Completely forgot too. ;-)
Thomas, for some reason your message appeared in my inbox. But not from any real
e-mail address (the name was pretty obvious, but I thought I'd try to reply
anyway). So I suppose if the newsgroups ever go down for good, I'll meet you in
Valhalla! :P
But yeah, blobs seem like a worthy line of investigation :D
Sam
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 13/11/2021 om 00:16 schreef Samuel B.:
> Valhalla! :P
Aargh! Did it again! :-(
Sorry Sam, I hit the wrong button in Thunderbird.
> Sam
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 10-11-2021 om 08:11 schreef Thomas de Groot:
> effects. On my ToDo list I have put some ior experiments...
Here it is. I replaced the cloud of inclusions by just one large blob
inclusion with its own ior (salt water) and its own (coloured)
absorption media. Indeed, there is no interaction between the different
media colours (crystal and inclusion) or ior differences. Good to know! :-)
Download 'nested media_test4.jpg' (62 KB)
Preview of image 'nested media_test4.jpg'
![nested media_test4.jpg](/povray.binaries.images/attachment/%3C619264fc%241%40news.povray.org%3E/nested%20media_test4.jpg?ttop=438632&toff=100&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
...And using a light probe in addition (with no_image).
Download 'nested media_test5.jpg' (65 KB)
Preview of image 'nested media_test5.jpg'
![nested media_test5.jpg](/povray.binaries.images/attachment/%3C61927e62%241%40news.povray.org%3E/nested%20media_test5.jpg?ttop=438632&toff=100&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Bravo!
Paolo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 18-11-2021 om 11:28 schreef Paolo Gibellini:
> Bravo!
> Paolo
<grin>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
