POV-Ray : Newsgroups : povray.binaries.images : Fluorapophyllite-(K) Server Time
26 May 2026 17:21:30 EDT (-0400)
  Fluorapophyllite-(K) (Message 31 to 40 of 52)
Subject: Re: Fluorapophyllite-(K)
Date: 1 Nov 2021 07:30:00
Message: <web.617fcecc4f1e127b4cef624e6e066e29@news.povray.org>
> I am not yet sure about those 'media voids'... I shall have to think about that.
Yeah, I probably spoke too soon-- such voids would not produce the same visual
effect as your own method of creating voids with actual geometry.
> The only media used here
> is an absorbing media which takes care of it all (with the ior too of
> course). I experimented with the scattering media in addition to the
> absorbing one, because Jaime did something like that in his crystal
> experiments.
> http://www.ignorancia.org/index.php/galleries/latest-images/crystals-and-mushrooms/
> However, I did not find it to work as expected.
Also, it occurred to me that any fractures or cleavage planes in a crystal would
need to have some partial reflectivity (if I understand the concept of such
planes). Thin slices of interior media certainly cannot do that. :-(
BTW, thanks for the link to Jaime's crystals; I will take a look at his examples
and code.
Date: 1 Nov 2021 08:22:02
Message: <617fdbea$1@news.povray.org>
Op 1-11-2021 om 12:26 schreef Kenneth:
Correct. I am struggling with the concept however, if I would add a
separate media to the voids (even tiny ones). The scene file I consulted
as an example is from Glenn McCarter's Plumbing suite (2003):
http://www.irtc.org/stills/2003-06-30.html (3rd Place) and he happily
does mix them, but I am not really sure he is doing things correctly,
especially now with newer pov versions.
>> experiments.
Yes, there is that too. Still, I want to experiment with it to see what
would happen.
> and code.
Jaime's work is often a treasure trove indeed.
Date: 1 Nov 2021 12:04:16
Message: <61801000$1@news.povray.org>
Warning! No photons! :-)
After a good three hours render, this is the crystal with 'fluid'
inclusions added: 15000 little hollow spheres with an ior of 1.0.
Not sure how 'natural' this is looking. I have seen crystals with
concentrations of 'bubbles' more or less like this. Maybe I have
exaggerated a bit; maybe there should be less 'bubbles'...
Personally, I like it but I am interested in your verdicts.
Download 'krystalshaper_apophyllite_006a.jpg' (64 KB)
Preview of image 'krystalshaper_apophyllite_006a.jpg'
Date: 2 Nov 2021 07:30:00
Message: <web.6181211d4f1e127bd6c295506cde94f1@news.povray.org>
hi,
very nice, "like".  :-)  I'd be interested to see a version where the "bubbles"
are confined to a smaller volume within, and also "off-centre", a little.
regards, jr.
Date: 2 Nov 2021 11:42:44
Message: <61815c74$1@news.povray.org>
Op 2-11-2021 om 12:29 schreef jr:
> hi,
Smaller volume: yes, that would be interesting
off-centre: ok
Date: 2 Nov 2021 16:50:00
Message: <web.6181a3b84f1e127b1f9dae3025979125@news.povray.org>
So, to me, it still looks a bit - murky.  Like I'm viewing the render through a
haze or slightly out of focus.
I'm not sure if it's the render settings, the lighting, or the contribution of
the textured ground plane, or what.  I just get the impression that I should be
seeing some crisp(er) edges on the front of the crystal, and instead they are
kind of muddled / blended in with the body of the crystal.
I like the bubbles - I know what you're trying to accomplish there.  Perhaps -
fewer? Slightly more spread out?
This would definitely be a great method for making a realistic ice cube with the
frozen air bubbles inside...
I would be interested in seeing a clean, crisp, clear or opaque version, which
ought to render very quickly, and also - one employing the new granite material!
 :D
This has also got me wanting to see an amethyst, with the clear-to-purple color
gradient.
Date: 3 Nov 2021 03:17:58
Message: <618237a6$1@news.povray.org>
Op 02/11/2021 om 21:46 schreef Bald Eagle:
I have no idea. I guess it could be the lighting (area light), but the
edges /are/ crisp, you can take my word for this.
I shall soon have a demo scene file ready for you to play with.
Yes, I think there are too many anyway.
Indeed.
>   :D
A /granite/ material? What are you talking about? ;-)
I shall provide that asap. Note that the bubbles will be invisible... :-}
> gradient.
Indeed. I think I shall leave that to others after I provide the code.
Date: 3 Nov 2021 12:47:42
Message: <6182bd2e@news.povray.org>
Latest, less inclusions, and slightly more concentrated and de-centered.
The complete set of files can be found now in the p.b.s-f
I added a quartz crystal to the set.
Download 'krystalshaper_apophyllite_006b.jpg' (59 KB)
Preview of image 'krystalshaper_apophyllite_006b.jpg'
Date: 9 Nov 2021 19:01:05
Message: <web.6185c5cf4f1e127bcb705ca46e741498@news.povray.org>
It looks decent!
I've got a bunch of ideas, but I need to find the proper motivation to implement
them :/
Only thing I want to suggest at this point is to maybe situate the light_source
&/ sky_sphere so that it casts a highlight off either an outside or inside
surface.
Sam
Date: 9 Nov 2021 19:01:06
Message: <web.618ac5a34f1e127b4cef624e6e066e29@news.povray.org>
I like this. AND the previous render with more bubbles. Beautiful.
BTW, I did not realize that an object with ior could have inclusions (other
objects) with *different* ior's-- I thought such constructs would be an example
of 'variable' ior within an object, which cannot be accomplished in POV-ray,
AFAIU. I had a mistaken notion that the camera ray would 'see' the outer object
surface first, which would then set the ior for the entire union-ed CSG. (Kind
of like the way media operates.) But that's not the case! :-) So I've been
experimenting with this multiple-ior CSG trick, which can produce some visually
interesting results. Thanks for the idea.
