POV-Ray : Newsgroups : povray.binaries.images : Granite_21 - the final macro Server Time
18 Nov 2025 02:32:29 EST (-0500)
  Granite_21 - the final macro (Message 1 to 10 of 30)
Subject: Granite_21 - the final macro
Date: 5 Sep 2021 07:42:44
Message: <6134ad34$1@news.povray.org>
The final version of the Granite_21 macro package can be found in
p.b.scene-files under the same header.
The image here illustrates, from the start, the principal rule of the
macro, written on the wall!
Enjoy!
Download 'granite_21_dimensions2.jpg' (216 KB)
Preview of image 'granite_21_dimensions2.jpg'
Subject: Re: Granite_21 - the final macro
Date: 5 Sep 2021 12:35:00
Message: <web.6134f119b21f010c2636f1af607c1b34@news.povray.org>
Alright! Thanks Thomas and Bald Eagle (and anyone else who may have
contributed)! This is a great day in POV-Ray history!
Kind regards,
Dave Blandston
Suggested motto: "With POV-Ray anything is possible, but nothing is easy"
Date: 9 Sep 2021 19:30:00
Message: <web.613a983eb21f010ccb705ca46e741498@news.povray.org>
Hey, is that a classic Estwing hammer I see? I've got one myself, but it's worn
down. A lot. I probably need to grind it back into shape, but I haven't found
much use for it recently. Estwing used to (and probably still does) have a free
replacement policy, but I never figured it was worth bothering them over.
Not many minerals around here except for granitic rocks, tiny grains of
opalescent quartz, almost-amazonite feldspar and maybe some horneblend. The
latter seems to exhibit some Schillerism when shaped. I think I found some
garnet, too, but it's hard to tell.
What do you plan to use the granite for, if anything?
Sam
Date: 10 Sep 2021 02:53:12
Message: <613b00d8$1@news.povray.org>
Op 10/09/2021 om 01:26 schreef Samuel B.:
Yes sir, it is! Modelled on my own, old, specimen, which has accompanied
me for the last 55 years or so. Got it for my birthday after I had
revealed to my parents that I intended to be a geologist.
It is also worn down, probably not as much as yours. Its most intensive
use was during my studies when fieldwork was in hardrock countries
almost exclusively. Later, as I switched to softrock specialisation, it
gathered mostly dust. Trowel & spade took over. :-)
However, it is still there, sometimes to be used when a rock passes by.
Never took it on a plane though; you can imagine why...
The Sierra Nevada, I assume. Fascinating geological history over there.
You did some perfect modelling of jasper and topaz.
Your Europan vacation shot still fills my background screen here, btw.
No real plans at the moment. My primary intention was to finally put
Daniel Mecklenburg's code to good use after all those years.
Date: 10 Sep 2021 16:40:00
Message: <web.613bc1ebb21f010ccb705ca46e741498@news.povray.org>
> > Hey, is that a classic Estwing hammer I see? (...)
You can be the judge of that... I've attached a photo of mine for your viewing
(dis?)pleasure. As you can see, it's fairly worn. Not too bad, but reshaping it
means losing some length from the pick. But the worst part is the condition of
the handle... It needs the for the lacquer to be removed and some oil applied.
I've dug underwater in creeks with the thing, to loosen rocks and get at
gold-bearing clay, so it's no wonder it looks like it does. (One time when I was
doing this - my chin partially underwater - an otter popped its head over some
boulders, saw me, and quickly went the other way, lol.)
> Its most intensive
Yeah, a rock hammer isn't often the best tool for everything, that's for sure.
My other main tool is a long, flat-headed screw driver. Perfect for prying apart
rocks that would otherwise be difficult to budge. (But I've chipped a bunch of
quartz crystal terminations doing that...)
Tomorrow is one of the reasons why, I'm guessing?
> > Not many minerals around here except for granitic rocks, (...)
Yep! It's just too bad there's not much interesting going on in my immediate
locale. I'd really like to spend some time in some of the more interesting
places, like Fresno Country, Inyo County and even San Diego County, even though
the latter has been heavily prospected. Inyo seems like the best bet for
undiscovered treasures.
Oh, that reminds me. I know your specialty is more on the geological side of
things, but a great tool has just become available for free: KrystalShaper (
http://www.jcrystal.com/products/krystalshaper/ ) It provides a catalog of
hundreds of minerals, plus tools to analyze and export geometry. Might be worth
checking out.
Haha, cool. I still want to update that scene with a camping tent, RV or
something.
I'm out of the loop, so I'm not sure what that entails, but I'm looking forward
to seeing it.
Sam
Download 'estwing-98.jpg' (543 KB)
Preview of image 'estwing-98.jpg'
Date: 11 Sep 2021 02:49:23
Message: <613c5173$1@news.povray.org>
Op 10/09/2021 om 22:36 schreef Samuel B.:
Well... except for the handle, mine is in the same condition, with some
serious dents in the head additionally (from hitting too many quartzitic
rocks in Scandinavia and the Alps iirc). That handle of yours needs some
refurbishing indeed. As you say, some oil for the leather to absorb.
After a hot field summer in Spain, the leather had started to shrink and
crack, a bit like yours. I used to dip it in a water pool for a couple
of hours... Otherwise, your Estwing still looks pretty operational. I
don't know about reshaping the point. Generally, it doesn't need to be
too sharp (or it looses its sharpness pretty soon anyway).
>> Its most intensive
for sure.
Screwdrivers, chisels, whatever is available. Hardware stores are little
paradises for that ;-)
Yeah...
Not sure but I guess areas on the fringes/just ouside of the granite
outcrops would be more promising, and the metamorph, ancient sedimentary
rocks?
> checking out.
I shall do that.
> something.
> to seeing it.
Sorry, my bad, you are already ;-) What I meant is that the Granite_21
macro is the result of wanting to turn Daniel's code into proper
granites for a number of years.
Date: 11 Sep 2021 18:15:00
Message: <web.613d2932b21f010ccb705ca46e741498@news.povray.org>
> Generally, it doesn't need to be too sharp (or it looses its sharpness pretty
> soon anyway).
That's probably exactly how it should be, since tools that keep an edge are
generally very brittle... a property you might not want in hammer ;)
> rocks?
You would be right, since those have always been the most interesting spots,
ime. Once in Fresno county, we found some marble. I've never seen marble with
such large grains. Right next to that we found garnet clusters (grossular,
probably). And then we began finding epidote, more garnets, and very beautiful
smokey quartz near some mines.
In the lower elevations of this general area, almost everything is hydrothermal
and metapmorphic. You'll find shale with fossils, slate a ways off from the
shale, quartz veins running through both, soapstone in one area and serpentine
(an altered form of soapstone iirc) in another. Pyrite, gold, even pure sulphur
in some places. It's crazy.
And there's an area near a river which I suspect might be harboring corundum. In
that place you can find marble outcrops above an area with granite pegmatite (I
might have found a green beryl there as a kid but it's been lost). Since I
figured corundum is sometimes found in marble, and considering the prevalence of
aluminum in the area (micas, soap stone, etc.), I thought that maybe rubies and
whatnot could be possible as well.
Sam
Date: 13 Sep 2021 10:55:34
Message: <613f6666@news.povray.org>
Op 10-9-2021 om 22:36 schreef Samuel B.:
> checking out.
Nice little program indeed! Thanks. Wulff-nets, ha! That was not really
my cup of tea... ;-)
The output could be the basis for crystal renders of quality. Not much
time at the moment, but I keep in mind.
Download 'quartz.png' (48 KB)
Preview of image 'quartz.png'
Date: 13 Sep 2021 19:15:00
Message: <web.613fdb40b21f010ccb705ca46e741498@news.povray.org>
> > checking out.
I don't even know a Wulff net is. But based on its appearance, I'm guessing it's
some sort of mapping between HKL indices and a sphere. Maybe it's a clue to help
me convert HKL values to planes...
What's your camera aspect there? The crystal looks stretched vertically.
It is a cool program, I just wish I could figure out my HKL issues so I can do
more with it. (My previous searches didn't turn up much useful info, or maybe I
wasn't comprehending what I saw...)
Sam
Date: 14 Sep 2021 02:54:50
Message: <6140473a$1@news.povray.org>
Op 14/09/2021 om 01:14 schreef Samuel B.:
>>> checking out.
That is correct. It is/was used in crystallography for mapping mineral
indices and do all sort of exciting things, calculating angles and
intersections. Only, as a freshman, I was not particularly interested in
this branch of geology! Hammering away at overturned, anticlinal rock
sections: /That/ was what life was about! ;-)
But seriously, I do not remember how it worked exactly but it certainly
could be of help to you I guess. I still have a Wulff net somewhere
here, gathering dust.
For the demo image I didn't bother with the scene details; just used the
standard scene code provided by the app.
I know what you mean. These are a couple sites which explain the use of
the Wulff net. There are more of course, but these are fairly basic.
http://www.minsocam.org/ammin/AM25/AM25_689.pdf
https://www.doitpoms.ac.uk/tlplib/stereographic/wulff_construct.php
However, to tell the truth, I remain a bit baffled when I see those
things again, after all those years. I am not really sure I understand;
I think you are more familiar with all this.
