POV-Ray : Newsgroups : povray.binaries.images : Documenting wrinkles normal pattern bias. v3.7/v3.8. Server Time
24 Aug 2025 03:42:02 EDT (-0400)
  Documenting wrinkles normal pattern bias. v3.7/v3.8. (Message 1 to 10 of 12)
Subject: Documenting wrinkles normal pattern bias. v3.7/v3.8.
Date: 5 May 2021 05:31:14
Message: <609265e2@news.povray.org>
In early January Cousin Ricky posted on the normal mechanism's scalar
value pattern's normal calculation bias.
http://news.povray.org/povray.binaries.images/thread/%3C5ff4b8da%241%40news.povray.org%3E/
Web Message: 5ff4a6cc$1@news.povray.org
There were posts in several newsgroups last fall regarding issues -
including some positionally bias related - with the quilted normal pattern.
http://news.povray.org/povray.binaries.images/thread/%3C5f830726%40news.povray.org%3E/
Web Message: 5f830726@news.povray.org
With this post I want to document a bias issue with the existing
wrinkles normal block pattern. In the attached image at left a sphere
with some phong shading. In the middle wrinkles with a bump_size of 0.5.
The two phong centers should more or less match(a), but do not. On the
right a hacked version of wrinkles removing the abs() of the DNoise
returned vector component values.  The phong position and shading has
spread some, but it's not offset(b).
(a) - Unbiased now too is the overall sphere's shading due the perturbed
normals.
(b) - The pigment_pattern { wrinkles } looks different, has at identical
scale and bump_size no noticeable bias - though the scalar value type
bias is there, and it looks correct for phong position and general shading.
The normal { wrinkles } perturbation's calc creates vector offsets which
only add to the existing normal vector values. Further, the amount of
the add/offset depends upon the bump_size value and whether
no_bump_scale is set or not.
When considered along with transformations it makes textures/materials
using normal { wrinkles } very difficult to control / set-up for general
use.
Thinking aloud: The misbehavior with wrinkles does suggest an
interesting idea. One I see as related to those using large bump_size
values to affect a materials interaction with lighting.
Might we implement a normals pattern which allows users to lean/bend
normals toward a light source as a new normal block pattern?
Suppose it would be done with a vector specifying a point in space(1)
with the bump_size then indicating how hard to bend normals toward that
point(2).
(1) - The point would have to undergo the same inverse transformations
as rays to be specified in global space I guess.
(2) Hmm, would this need to be done along with (after) other normal
perturbation patterns are applied. Maybe so...
Bill P.
Download 'nrmlwrnklissue.jpg' (21 KB)
Preview of image 'nrmlwrnklissue.jpg'
Subject: Re: Documenting wrinkles normal pattern bias. v3.7/v3.8.
Date: 5 May 2021 06:25:00
Message: <web.609271d8c711449a1f9dae3025979125@news.povray.org>
Sure (?) - would grabbing the light source position and applying the shear_trans
with the normalized inverse position, and using a normal {function {}} (like I
_just_ did for Mike H's fake shadow) not do it?
Add that (normalized) vector to whatever existing normal(s) and then
renormalize?
Date: 5 May 2021 07:38:00
Message: <60928398$1@news.povray.org>
A thought, but I'm thinking simpler at the moment. A weighted normalized
vector addition to the incoming normal in the direction of the point
light(1).
(1) - Partly because in adding the ability to pass a vector to represent
the point light, the same 'eventual keyword parsing' could be used to
specify an arbitrary axis of rotation for other types of normal
perturbation patterns I have banging around in my head.
> renormalize?
Date: 5 May 2021 13:40:00
Message: <web.6092d77bc711449a1f9dae3025979125@news.povray.org>
> light(1).
Yep - that's the revised version that I came up with during lunch, after I
scratched my initial suggestion.
Normalize the normal vector.
Normalize the Light source vector.
Have the normal function take a parameter that gets clamped to 0-1.
Then interpolate over the line segment extending between the actual normal and
the light source based on that parameter.  No angles, no atan2, no matrix
transform.
Date: 5 May 2021 19:05:00
Message: <web.609323a8c711449a1f9dae3025979125@news.povray.org>
> > light(1).
And of course that's vastly easier to do in source, since POV-Ray functions
return scalar values not vectors.
https://wiki.povray.org/content/Reference:Function_Pattern
Maybe there's a clever way to do this in SDL using the color channels and
average {} or some other method...
Date: 6 May 2021 10:11:50
Message: <6093f926$1@news.povray.org>
>>> light(1).
:-) Re: "vastly easier" - I had the thought, "not with my C++ skills..."
Not useful to most, but as mentioned elsewhere, my povr branch has
functions packing/unpacking three 21 bit / two 32 bit values into the
passed around double's 'space'. I think the 21 bit x,y,z enough for most
normals work.
This works today all in the functional space, but guess we could open up
2x/3x value paths into the map-pattern and normal pertubation spaces via
double values. With normal perturbation it more or less directly fits as
a new perturbation pattern(1), with scalar map pattern's might be
limited to specific patterns.
I'll have to let that thought cook for a bit. :-)
Bill P.
Date: 6 May 2021 13:50:00
Message: <web.60942b7ac711449a1f9dae3025979125@news.povray.org>
I was stating that from the perspective that such would be "an algorithmic
process" rather than a function {}.
What you're proposing seems awfully similar to how slope and aoi already work,
no?  Perhaps there's a way to piggyback on those in SDL, or repurpose that
already-written source code for the normal perturbation?
Thinking about this some more today reminded me that I am not at all clear about
how a scalar function perturbs a normal vector.  Maybe this got covered in the
quilted pattern thread - I will have to look.  It would be nice if this was
covered in the docs somehow.
It also caused me to wonder if there is a way to define a pattern in SDL that
has an rgb output, such that the .r .g and .b could be used.  The average {}
pattern?
If so, then could we in theory have "vector functions" by rolling 3 pigment
{function {}} statements into an average{} block, and then using function
{pigment{}} ?
Date: 6 May 2021 21:25:00
Message: <web.6094962dc711449a8e52cc8789db30a9@news.povray.org>
> pattern?
> {pigment{}} ?
Yes, you are right; something like that is possible. But patterns can only
return values from 0 to 1, so it must be done with pigments only.
Here's one way of doing it:
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.7;
#include "Gaussian_Blur.inc"
#declare FnX = function { x*z };
#declare FnY = function { y - 0.2 };
#declare FnZ = function { y + z };
#declare Fn = function { FunctionsPigmentRGB(FnX, FnY, FnZ) };
#declare vP = Fn(0.5, 0.6, 0.3);
#debug "\n"
#debug concat("<", vstr(3, vP, ", ", 0, -1), ">")
#debug "\n\n"
#error "Finished"
For this be be more useful, one can create one or more functions that one wraps
around the FnX, FnY and FnZ functions in order to map their return values into
the 0 to 1 interval and one or more functions that one applies to the returned
components from the Fn vector function in order to map them from the 0 to 1
interval into one or more desired intervals.
IIRC somebody once made some macros that did something like this.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 7 May 2021 08:13:15
Message: <60952edb@news.povray.org>
Me thinking aloud...
Patterns for map use always have access to the raw normal and the
perturbed normal as part of the ray surface intersection work as well as
the active involved ray. We calculated a scalar value based upon
intersection x,y,z. This value calculation can be an inbuilt pattern or
a function.
The normal perturbation patterns are passed the raw normal by reference
as a vector which is then perturbed before returning to the calling ray
surface intersection code. The code also has access to intersection
position.
Both scale value patterns and normal perturbation patterns have access
to all the other pattern settings - the controls, the knobs. Those are
fixed from parse time.
What I'm thinking about is 21 bit 3d vectors (in a doubles' space) as a
function calculated scalar value to a 'special' scalar value pattern.
One which perturbs the perturbed normal before returning always 0.0 as
the map value. No new overall mechanism would be needed and this
'special' nperturb 'map' pattern would be used as the first pattern in
an average with a zero weight.
There are probably ten things wrong with my thinking, but I know one
issue is the intersection usually comes into the pattern as a constant
pointer. Meaning with the usual set up I cannot update the perturbed
normal vector as I'd like to do with the 3x 21 bit encoded function value.
We've discussed it some about and once in private emails. The "pyramid"
of scalar value samples and the reason for the accuracy keyword/setting.
The reason you are perhaps not clear on how it works is the code itself
has some funky values and scaling in it not documented with comments.
It's a pyramid of 4 samples (why that type of normal's bias) but why the
extra stuff I'm not clear. And I wonder too how well the accuracy works
should the same material be variously scaled in a single scene.
> pattern?
> {pigment{}} ?
Like Tor Olav, I've played some with this and you can pass vector
information around this way, but I've found it slow. I think it's likely
all you can do in standard POV-Ray releases. The vector interface where
it exists with functions leans on / is tangled with the parser code.
Bill P.
Date: 7 May 2021 18:55:00
Message: <web.6095c51bc711449a1f9dae3025979125@news.povray.org>
Following along in /source/core/material/normal.cpp
> a function.
Seems like (most of) the internal functions and values at play are
EPoint
TPoint
Tnormal
Intersection
Layer_Normal
Warp_Normal ()
Warp_EPoint ()
Pyramid_Vect []
> position.
const Intersection *Inter
Not sure about the accuracy, and not clear why the pyramid is "biased".
I had problems using the internal sum () function, but adding the 4 pyramid
vectors by hand gave me <0, 0, 0> (out to 8 dec places) so I'm not sure what the
bias would be.
