POV-Ray : Newsgroups : povray.binaries.images : Granites Intermezzo Server Time
5 May 2026 22:27:04 EDT (-0400)
  Granites Intermezzo (Message 81 to 86 of 86)
Subject: Re: Granites Intermezzo - last test image!
Date: 13 May 2021 14:45:00
Message: <web.609d72a921b634211f9dae3025979125@news.povray.org>
> All right! This is going to be the *last* test image of the pre-macro
> Dakota Red Granite, closing also this Intermezzo.
> Shown here, is the current implementation of the quartz veins through
> the granite, using the marble pattern. Please note that this feature
> will remain /experimental/ in the upcoming beta macro which I shall
> provide tomorrow.
This is looking very nice!  :)
Just going to jot down some observations and thoughts, some which we may
address, and some we might not.
I think the pattern we have is better that the previous stock pattern.  The
grain size is still too uniform, but maybe if several adjacent grains were
textured identically, using the hexagon/bricks trick, then we could get a less
homogeneous size distribution.
Next I guess would be crafting the textures of the individual minerals composing
the grains.
Aside:
I took the boy outside last weekend - the oxygen and sunlight surely burned his
lungs and skin - and we explored the retaining wall of the local dam
https://www.nae.usace.army.mil/Missions/Civil-Works/Flood-Risk-Management/New-Hampshire/Hop-Ev/
Lots of granite, big chunks of quartz, and other things yet to be identified "Is
that andesite?" (smart kid - or maybe it's Minecraft...)
I noticed that the quartz, while appearing translucent white in small samples,
took on an agate gray/purple cast as the veins or chunks got larger and deeper
and Beer's law started to really kick in.  There were also striations
perpendicular to the vein line, and some of the quartz was bordered by a
different mineral that was more chalky / portland cement solid white, whatever
that might be.
There were also "rust spots" in some of the rocks, as well as plates of of mica.
 And mixed in with the granites were a few very smooth fine-grained/grainless
stones that had a dark grey transitioning to red color, such that they almost
looked like they were rusting.
I can return and take samples, photos, closeups if we think such would assist.
I would imagine that the quartz veins will be the most challenging to implement,
as there will be the issue of presence, thickness, number of veins, orientation,
amount of turbulence, etc.  Maybe that's best handled by an optional array that
the macro checks to see if present.
Date: 14 May 2021 04:24:48
Message: <609e33d0@news.povray.org>
Op 13-5-2021 om 17:27 schreef Mr:
>> provide tomorrow.
>> Thomas
> Artistically , I love it !  And if the geologist validates it, that's even
> greater !
Thanks. Validating... it depends on how deep you want to go into the
Uncanny Valley, or beyond into a complete and exact copy of reality. The
second, is imo, hardly possible (and certainly not recommended in terms
of workload and ultimate usage); the first would need a lot more
detailed work including close-up comparisons with real samples, but
would not be justified by the average intentions of individual users. I
doubt if even professionals would want it: they probably would opt for a
high-resolution image_map.
So, I do validate this version of the Dakota Red granite, perhaps not as
a true /Dakota Red/, but as a type of red granite. In a later stage we
shall tackle the /Canadian Pink/ and the /North American Pink/. Will
they be different from the present one? We shall see.
Date: 14 May 2021 08:07:15
Message: <609e67f3$1@news.povray.org>
Op 13-5-2021 om 20:40 schreef Bald Eagle:
>> provide tomorrow.
I had been writing an answer to this post, and then it was lost... drat!
Have to do it again. :-/
You have to realise that granites in general /are/ rather uniform in
grain size, only a certain class of rocks show marked size differences
('phenocrysts', 'porphyritic') where the large crystals are represented
by feldspars rather than quartz. So, the size distribution in the
present concept is about right.
> the grains.
No, I would advise against doing that, for the simple reason that it
would be overkill for most of the uses of the material. Additionally it
would burden memory and parser/render time to unacceptable levels. Much
better would be to find a 'fast' way to add a believable sslt
(conundrum, I know).
> Aside:
Excellent exercise! To be recommended for everybody in 'rocky' country.
Beautiful landscape btw. I like it.
As said above, the big chunks are probably feldspars rather quartz, and
no, no 'andesite', which would be a fine-grained, dark, extrusive rock
and no granite. However, a smart suggestion indeed. The big chunks may
point to a porphyry or a gabbro instead of a true granite.
> that might be.
Yes, those characteristics seem to point to feldspars. the 'chalky'
colour might point to 'weathering' of the minerals.
Hmmm... inclusions of stones... maybe we are not dealing with a true
granite here. Granites do not have such inclusions.
Well, a few photos would do no harm indeed. Remember however, that we
are dealing here with /Dakota/ granites! If taking photos, remember to
put in a coin or something recognisable for size. Good practice for such
things!
Yes, the veins are a problem. I was wondering if we should not need some
kind of function to do this well. Not sure how to do this correctly.
Date: 14 May 2021 10:48:43
Message: <609e8dcb$1@news.povray.org>
>>> provide tomorrow.
>>> Thomas
>> even
>> greater !
The uncanny Valley is rather shallow when it comes to things like the
pattern of rocks.
Date: 14 May 2021 11:02:03
Message: <609e90eb$1@news.povray.org>
Op 14-5-2021 om 16:48 schreef Alain Martel:
>>>> provide tomorrow.
>>>> Thomas
>>> even
>>> greater !
>> The second, is imo, hardly possible (and certainly not recommended in
>> terms of workload and ultimate usage); the first would need a lot more
>> I doubt if even professionals would want it: they probably would opt
>> for a high-resolution image_map.
>> as a true /Dakota Red/, but as a type of red granite. In a later stage
>> we shall tackle the /Canadian Pink/ and the /North American Pink/.
>> Will they be different from the present one? We shall see.
> pattern of rocks.
Yes, that is certainly true indeed, but you get my meaning.
Date: 17 May 2021 04:10:39
Message: <60a224ff$1@news.povray.org>
Thomas de Groot wrote on 13/05/2021 17:02:
> provide tomorrow.
It looks great!
Paolo
