POV-Ray : Newsgroups : povray.binaries.images : Granites Intermezzo Server Time
5 May 2026 20:50:28 EDT (-0400)
  Granites Intermezzo (Message 71 to 80 of 86)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Granites Intermezzo
Date: 10 May 2021 04:20:00
Message: <web.6098ec72cfb077e479819d986cde94f1@news.povray.org>
hi,
> Very soon now, I shall post a beta for everybody to shoot at. Stay attuned!
super, thanks.  looking forward to it.
regards, jr.
Date: 11 May 2021 03:55:00
Message: <web.609a36f4cfb077e479416a1f607c1b34@news.povray.org>
> And thanks for testing! In the meantime, I have finished a preliminary
> macro architecture including also the polished version and the veins.
I do have one suggestion, which is to replace "#declare" with "#local" for
everything except the finished materials. I ran into one conflict. (It was a
function denoted by the single letter "K.")
I am very excited about this project! After experimenting a little more I'm
convinced this is a major development and will certainly be replacing the old
granite in my project with this wonderful new concoction.
By the way, what is the meaning of "Granites Intermezzo?"
Have an awesome day!
Kind regards,
Dave Blandston
Suggested motto: "With POV-Ray anything is possible, but nothing is easy"
Date: 11 May 2021 04:23:31
Message: <609a3f03$1@news.povray.org>
Op 11-5-2021 om 09:50 schreef Dave Blandston:
Which is/will be done indeed in the upcoming macro version.
"K" would point to the Bald Eagle Step Noise contribution. It is not yet
entirely well-integrated. However, I never had conflicts with it, so
maybe you got a special case?
Thanks indeed. I am certainly satisfied with the results too. Still a
couple of things to take care of, but nothing really serious at this stage.
I consider this series of posts as 'intermediary' between the original
exchange, starting with the Daniel Mecklenburg code upgrade, and the
upcoming beta version of a first granite set. More will follow after
that one.
<grin>
Date: 11 May 2021 06:20:00
Message: <web.609a59ffcfb077e41f9dae3025979125@news.povray.org>
Mmm, yes.  I suppose that anything that could be released upon exit from the
include file ought to be declared locally, if for no other reason that to
practice good form going forward from this point.
K is pretty much just a straight copy-paste from from Wikipedia / Inigo Quilez /
ShaderToy / The Art of Code / GLSL ...  I just used the same variable names to
make reading and potential debugging easier upon a first read-through.
Ken Perlin has suggested an improved version, no idea how that would affect the
appearance of the texture.
I suppose there are a lot of variations that would be nice to look at, exploring
different interpolation formulas and splines.
Date: 11 May 2021 07:30:00
Message: <web.609a6a17cfb077e479416a1f607c1b34@news.povray.org>
Yep, that would be good - keep everything local that can possibly be kept local.
There is at least one other single-letter function designator ("N") so the
chance of a conflict with other variables in a scene definitely exists. The
reason I had a collision with "K" is because I use the letter "I" to control
loops (short for "Index") then for nested loops I just keep going with "J," then
"K," et cetera. "N" is probably popular because it's the first letter of
"Number." There is no downside to using "#local" wherever possible, but there is
a benefit.
Kind regards,
Dave Blandston
Date: 11 May 2021 08:05:03
Message: <609a72ef@news.povray.org>
Op 11-5-2021 om 13:27 schreef Dave Blandston:
> a benefit.
I am presently looking at Bald Eagle's code with the intention to
implement it inside the granite macro. In that case, all declares will
become locals obviously and stop giving problems like you encountered.
Another consequence will be that I shall need to define at least three
additional parameters for the granite macro: Start, End, Turbulence.
@Bald Eagle: in your original code you also defined a parameter "Scale"
which subsequently was not used. Where did you want to place it? It
might be an interesting fourth addition.
My reworking of the code would look like this:
//---start code---
#ifndef (SN_Start) #local SN_Start = 0.2; #end
#ifndef (SN_End)   #local SN_End   = 0.8; #end
#ifndef (SN_Turb)  #local SN_Turb  = 0.325; #end
#ifndef (SN_Scale) #local SN_Scale = 0.25; #end
// smoothstep function
#local K = function (t1, t2, T) {max (0, min(1, (T-t1)/(t2-t1) ) )}
#local Smoothstep = function (t1, t2, T) {pow (K(t1, t2, T), 2) *
(3-2*K(t1, t2, T))}
// mod function that plays nice when crossing 0
#local Mod = function (T) {select (T,  1-mod (abs(T), 1),  mod (abs(T),
1) )}
// smooth step function
//#local N = function (NN) {floor (NN-0.5) + Smoothstep (SN_Start,
SN_End, abs(Mod(NN-0.5)-0.5) )}
#local N = function (NN) {floor (NN) + Smoothstep (SN_Start, SN_End,
Mod(NN) )}
/* usage
#declare StepNoise =
   function {f_noise3d (N(x), N(y), N(z))}
   turbulence SN_Turb
//---end code---
Date: 11 May 2021 13:45:00
Message: <web.609ac27dcfb077e41f9dae3025979125@news.povray.org>
I personally might try to rename the parameters to make them unique to the
include file.  GranInc_K or something like that.  1000 times less likely that
someone will try to use that compared to N, NN or K.
I defined that in order to scale all of the textures at once when I was
comparing f_noise3D, StepNoise, and cells.
If you see a place where you'd like to scale the function independently of where
things might all be scaled together with the scale keyword, then it would get
placed inside the N parts of the StepNoise function like: N(x/Scale).
> //---start code---
> (3-2*K(t1, t2, T))}
> 1) )}
> Mod(NN) )}
> /* usage
> pigment {
>    turbulence SN_Turb
> //---end code---
> Thomas
Maybe rename/preface Mod and SmoothStep.
Also, to remove the dependency on functions.inc, f_noise3D id defined as
function {internal(76)}.
So maybe do:  #declare GraniteNoise = function {internal(76)}
But I think that until you release a test version "into the wild", we won't be
able to predict where some tricky problems may be hiding.
Date: 12 May 2021 08:35:42
Message: <609bcb9e$1@news.povray.org>
Op 11-5-2021 om 19:44 schreef Bald Eagle:
Done.
Ok. I shall not use it as it appears to be redundant with other scales.
>> [snip]
Done.
Hmm. Not sure yet if I want to do that. Not change for the time being.
Sure.
Subject: Re: Granites Intermezzo - last test image!
Date: 13 May 2021 11:02:41
Message: <609d3f91@news.povray.org>
All right! This is going to be the *last* test image of the pre-macro
Dakota Red Granite, closing also this Intermezzo.
Shown here, is the current implementation of the quartz veins through
the granite, using the marble pattern. Please note that this feature
will remain /experimental/ in the upcoming beta macro which I shall
provide tomorrow.
Download 'dakotagrains_test_veins.jpg' (93 KB)
Preview of image 'dakotagrains_test_veins.jpg'
Date: 13 May 2021 11:30:00
Message: <web.609d454c21b6342116086ed03f378f2@news.povray.org>
> provide tomorrow.
> Thomas
Artistically , I love it !  And if the geologist validates it, that's even
greater !
